Old 10-12-2010, 05:23 AM   #1081
AGNO's Avatar
Default MIP PRO4
Council to use MIP PRO4, are installed without any changes and are very durable.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-12-2010, 07:24 AM   #1082
Is there a Lady Bird on your car :P
MChandler is offline   Reply With Quote
Old 10-12-2010, 07:48 AM   #1083
AGNO's Avatar
Where?
Old 10-12-2010, 12:15 PM   #1084
Suspended
Trader Rating: 86 (100%+)
Originally Posted by Luke Hobson View Post
Where are your bones wearing? Can you post a picture up?
With 17.5 zero boost you shouldn't have ANY wear problems pretty much ever.
I've been running mod and 10.5 (with boost) for about 40 runs so far with no wear or broken bones....
What type of grease and anti wear grease are you using?
check your front dog bones on the steering block end, the axle is made by weak aluminum which is too soft for front axles
littlealex is offline   Reply With Quote
Old 10-12-2010, 12:25 PM   #1085
Barry_Hughes's Avatar
Hmmmmm seems other people have the same problem, since yours are not wearing at all perhaps we all have faulty ones and should send them back to HPI for FOC replacement
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 10-12-2010, 01:36 PM   #1086
steveonamission's Avatar
Mine have no signs of wear either...
Admitidly i have only done 9-10 5 minute modified runs on carpet with it so far... 1 meeting and 1 test session.
It seems ace so far, loads of corner speed.
steveonamission is offline   Reply With Quote
Old 10-12-2010, 01:41 PM   #1087
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
What grease or or anti wear grease are you using Barry?
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-12-2010, 02:07 PM   #1088
Hi Luke,
Im very interested in getting a TCX, I have a cyclone andy moore edition. Do Any of the parts fit the TCX ?? Im stuck between the new Xray T3 2011 and the TCX. I cant decide which to go for
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-12-2010, 02:16 PM   #1089
Trader Rating: 77 (100%+)
Smile
ran the tcx last nigh back to back with my cyclone tc....wow even with the same electrics in both the tcx was just a hair quicker with lap times....
artoftatt2 is offline   Reply With Quote
Old 10-12-2010, 02:50 PM   #1090
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by FLAT OUT View Post
Hi Luke,
Virtually all the plastic parts are interchangeable.
  • Rod Ends
  • Bearing Holders
  • Body Posts
  • Front and Rear Arms
  • Hubs and Spindles
  • Sway Bar tip holders
  • Front and Rear Pullies
  • Outer Suspension blocks
  • Screws and Springs
  • Shock kit
  • Outer and Inner hinge pins
  • Ball Studs
  • Complete Bumper assembly
  • Bearings
  • Axles
  • And maybe a few other items I'm can't think of at the moment
I still have two Cyclone TC's in my arsenal. One for the Stock Class and the other is a BMI Foam chassis conversion. No need to get rid of them, when I can use a lot of the same parts.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 10-12-2010, 11:20 PM   #1091
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
for those running without boost (13.5)...
was able to fit a 100t spur (64p) with a 46t pinion without modifying anything... all i had to do was add 1mm spacers and use slighly longer screws to move the spur out a bit (only because i don't have a 100T RW or Xray spur that has the offset built in already). can still use bigger pinions as there seems to be enough space (maybe up to a 50T)
its just a pain to set as you need to take the whole spurgear assembly in and out to mesh the spur and pinion.
attached some pix.
Hot Bodies TCX-12102010715.jpg   Hot Bodies TCX-12102010717.jpg   Hot Bodies TCX-12102010718.jpg   Hot Bodies TCX-12102010719.jpg
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 10-12-2010, 11:48 PM   #1092
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
VooDoo, that looks very much like what was mention on page 54 or 55...
Nice work!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-12-2010, 11:51 PM   #1093
The MIPs are long enough not to come out of the spool??
V-Dezign 4.0
Old 10-13-2010, 12:01 AM   #1094
eceer's Avatar
Would anyone in Oz know where to get 3 hole Shock Pistons(HPI73524) all my fav overseas haunts are out of stock
EDIT - Never mind found http://rchobbies.com.au/
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 10-13-2010, 12:16 AM   #1095
AGNO's Avatar
The MIP PRO4 are 46mm.
