Old 10-10-2010, 02:44 AM   #1051
AGNO's Avatar
Originally Posted by Airwave View Post
Cool photos and explanations... What about the belts? Could you reuse the TCX ones or did you mount the old TC ones?
TCX belts are used, just increase the tension.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-10-2010, 09:18 PM   #1052
Suspended
Trader Rating: 86 (100%+)
does anyone know the part number of dcj for tcx?
i am looking for dcj that will fit tcx
also looking for 102-105 spur that will fit, any suggestions?
thanks in advance
littlealex is offline   Reply With Quote
Old 10-10-2010, 09:26 PM   #1053
bigz's Avatar
Default steel universals
will there be a steel front dog bone in the near future???
paging hb......
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 10-11-2010, 07:40 AM   #1054
jag88's Avatar
thanks in advance
I don't believe there is a DCJ available just yet.
I use a 104 Xray.
jag88 is offline   Reply With Quote
Old 10-11-2010, 11:25 AM   #1055
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Default Timezone GP results
Open Modified TC Triple A-Main Result
1. Paul Lemieux
2. Kevin Hebert
3. Travis Schreven
4. EJ Evans
5. Kody Knudtson
6. Peter Robinson - Hot Bodies TCX
7. Korey Harbke - Hot Bodies TCX
8. Darren Shank
9. Weylin Rose
10. Richard St. Cyr
Setup sheets will be available soon.
My first real race back in 3 or so years, finally got the car going good and shook the rust off by the final A-Main. A little late to get anything done but the car was great.
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 10-11-2010, 12:13 PM   #1056
Jim_1987's Avatar
Does anyone know when the spares for the tcx will be out? Everything i want is out of stock!! I really need 46mm drive shaft and spool out drives, can anyone help?
Jim_1987 is offline   Reply With Quote
Old 10-11-2010, 12:25 PM   #1057
JamesReilly's Avatar
Trader Rating: 56 (100%+)
I use a 104 Xray.
Part # 67699 I think that Marc has a set hanging on the wall. I could be wrong, I thought I saw them.
James
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint (reillypaint@gmail.com)
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 10-11-2010, 12:39 PM   #1058
jag88's Avatar
James
Hey James. No those are for the cyclones up to and including the TC. They have a 44 mm dog bone and the TCX requires a 46 mm because they moved the bulkheads in 3 mm. 1.5 per side.
See you Wednesday ?
Old 10-11-2010, 12:49 PM   #1059
paging hb......
yesterday at the castle classic at nor-cal, i broke both of the front dogbones on my tcx. a buddy gave me 2 complete dogbones/axles to try from his T.O.P. car. i used my dremel to narrow the plastic blades a bit, but it was a perfect fit,,,,46mm, and the best part, they are steel dogbones.
gdcopbdcop is offline   Reply With Quote
Old 10-11-2010, 03:29 PM   #1060
Murdock's Avatar
Originally Posted by rendcool View Post
is this a good car ?
Best car I built so far.
★ MST: MS-01D Pro
★ Tamiya: TA05VDF, Gold TA05VDF, DF03RA
★ HPI-HB: Pro-D, TC-FD, TCX, Cyclone S
★ Team Magic: E4FS ★ Academy: STR-4 Pro II
★ Yokomo: Hyper SSG DRB, BDM, SD SSG, DP Type B
Murdock is offline   Reply With Quote
Old 10-11-2010, 03:31 PM   #1061
Murdock's Avatar
I'm having some pinion gear/motor mounting issues.
I am running 115t Spur with 35t pinion. I want to run a 30t or 31t pinion, but the top carbon piece is not allowing my motor to back into the Spur. I dont want to dremel the top carbon piece.
Any ideas or experience with this?
★ MST: MS-01D Pro
Old 10-11-2010, 04:36 PM   #1062
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Tekin GP 2010 - Ardent Raceway: 10/10/2010
TC 10.5 PRO STOCK - A Final
Pos Car Name Result Ave Best
1 2 Andy Moore 25 / 301.86 12.07 11.67 HB TCX
2 1 Elliot Harper 25 / 306.35 12.25 11.65
3 3 Jonny Aird 25 / 307.04 12.28 11.83
4 6 Stefan Chodzynski 25 / 309.30 12.37 11.80
5 5 Luke Hobson 24 / 300.65 12.52 11.73 HB TCX
6 4 James Hart 24 / 310.02 12.91 11.78
7 8 Aaron Morley 24 / 311.18 12.96 12.18
8 7 Ryan Edward 24 / 311.47 12.97 12.08
we had the Tekin GP at Ardent at the weekend, heres the results for 10.5, ignore Elliott out of the results as he was testing Mod for the ETS series this coming weekend.
car was great all weekend just too many mistakes in final (for me anyway lol)
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-11-2010, 05:03 PM   #1063
luke
Good result Luke !!
Was Andy Moore using a 10.5 or Mod
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-11-2010, 05:04 PM   #1064
andy was using 10.5
Luke Hobson
Old 10-11-2010, 05:08 PM   #1065
Good Job Andy !! Im on the market for a new car but cant get a TCX in the Uk At all, I rang Mirage or what ever there called today and they said there wont be any more in the UK till end of November !!
