Old 10-08-2010, 10:14 PM   #1036
rendcool's Avatar
is HB TCX a good car ??
I wanna get 1, but still thinking about it ..
rendcool is offline   Reply With Quote
Old 10-08-2010, 10:35 PM   #1037
hanzo3's Avatar
Trader Rating: 55 (100%+)
Of course it's good, hence the thread title.
hanzo3 is offline   Reply With Quote
Old 10-08-2010, 11:32 PM   #1038
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by timmig View Post
HB just does not support their cars with enough parts. Too bad, Photon was my latest choice as a result. Great car--good manufacturing support--easy to get parts.
FWIW
T
It's a bummer, but I recall past kits that freshly released were lacking spares. A very popular brand in the past released and I had to wait 7 weeks for the spares. This does not need to be a debate so I will not mention the brand. But the pool of parts made to complete kits are exhausted and then made available. I suspect we are nearing the arrival of the spares in question. I have only had my kit just over two weeks so I am good with it.
Besides, there is an alternative copy of the original...
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-08-2010, 11:49 PM   #1039
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by ark View Post
Dude seriously! Go start your own thread about whatever you want to talk about other than HERE. This is the TCX thread and Im sick of seeing s... that you write that is of no value to the TCX thread. Please p... off
+1
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 10-09-2010, 12:05 AM   #1040
Hello, i race some years a go with cyclone (not TC), i like this car, very fast in track, i change to another brand, im team driver for this brand, but now i thinking in change to HB again, im not team driver for HB, but not problem.
My question is about setups and behavior of the car in track, is similar to the old cyclone ?, fast in turns, a litle leak of grip rear, the CVDs are stronger that the olds ones?, the diff is the same of TC (Pro diff i think), but if there a gear diff, i see Andy Moore car in Euros, with very good performance, Andy is a very good driver, of course ...
Well, i would appreciate all help, for make a decision.
Thanks in advance, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 10-09-2010, 12:22 AM   #1041
Hebiki's Avatar
Trader Rating: 26 (100%+)
i drove the Cyclone Andy Moore edition and did NOT like it at all. this car is a definite improvement and more suited to my driving style. I think you'd be pleasantly surprised.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-09-2010, 12:49 AM   #1042
AGNO's Avatar
The TCX is very similar to drive to the TC with the related advantages of a much better steering and more,more rear grip, no loss of grip.
The CVD is equal to CT (I've replaced him with MIP), the differential is equal to TC, then the best.
I mounted the diff. Gear of the 3Racing, but I have yet to try it.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-09-2010, 01:56 AM   #1043
ali_g's Avatar
Originally Posted by Hi-LowBlow View Post
We lowered the front suspension block by 0.5mm because we wanted to have more roll in the front. It also reduced some tire pressure to the track surface so eventually less tire heat too. As a result It didn't make any push in the end of the race.
Thanks,
Hi,
will it work for asphalt?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 10-09-2010, 08:50 AM   #1044
Default Blog
Is there any blog of HB team drivers, to see the parts they use etc?
Thank you
RC Racing addict
Roedor is offline   Reply With Quote
Old 10-09-2010, 12:26 PM   #1045
Airwave's Avatar
I just looked on the Sakura thread... It comes with 38T, so we will have to use a 38T gear on the front spool...
But could you confirm that the Sakura gear diff has a good size and fit directly in the rear of the TCX?
Airwave is offline   Reply With Quote
Old 10-09-2010, 10:35 PM   #1046
Hebiki's Avatar
isnt the Spec-R gear diff for the TCX scheduled to be released in November?
Hebiki Design Works
Old 10-09-2010, 10:50 PM   #1047
Default sakura gear diff
I have tested the sakura gear diff in the tcx.
the only thing you have to buy with it is a pulley from the sakura.
You have to put also 3mm shims
The blades are a little bit tight in the outdrives but its oke.
And you have to dril 3 holes in the front pulley.
I've seen they gonna release 39 and 40 teeth pulley for the gear diff also.
stofke is offline   Reply With Quote
Old 10-10-2010, 02:08 AM   #1048
Airwave's Avatar
Thank you for these informations...
Old 10-10-2010, 02:09 AM   #1049
AGNO's Avatar
Default 3 Racing gerad diff. on TCX
Picture of the 3 Racing diff. gear mounted on TCX.
You should add about 2.5 mm in thickness (it is better to leave some space), to use the HB drive shafts should broaden into the out drive of 0.2 mm
Of course you have to mount a pulley Sakura on the front spool because the diff. gear has 38 teeth (maybe 3Racing it will produce a gear diff. with pully 39 teeth)
Old 10-10-2010, 02:11 AM   #1050
Airwave's Avatar
Cool photos and explanations... What about the belts? Could you reuse the TCX ones or did you mount the old TC ones?
