Old 10-05-2010, 06:36 AM   #976
AGNO's Avatar
Originally Posted by Luke Hobson View Post
that last pic isnt one of hara's cars i beleive, maybe Ty's?
luke
The car is of Hara...
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-05-2010, 07:32 AM   #977
Barry White's Avatar
Hara's? Difficult to believe.
Carstand not his paintsheme
Transponder on top of bumper! He would never do that. BTW he uses a PTX.
Red + wire. Hara has better taste then that. Black all the way.
LRP. Hara uses Nosram.
Tiny motor heat sink.
It's all in the details but this one looks really ugly and not from a pro like Hara.
Barry White is offline   Reply With Quote
Old 10-05-2010, 07:52 AM   #978
Korey Harbke's Avatar
It is possible to use the Tamiya steering knuckles in combination with no shims on the center bellcrank. I am told it gives some different Ackerman characteristics, but I have yet to try it. The newer steering geometry is such an improvement over the older single bellcrank style it haven't seen the need to try it just yet.
There are several suspension blocks that are just older, slightly higher, or slightly wider, ect and they are usually the silver ones. Again, they are just for testing. The difference they make is so small it is barely noticeable. They ran the stock suspension blocks that came in the kit by the end of the week.
The setups Hiro posted are the final setups at the end of the race, and they wrote those down in full detail right after the race. Those are the things that proved to be the fastest for each of those drivers. They will always try different things at the race for the sake of research and development. Just because they are trying it doesn't mean it is any faster... trust me.
Oh... that car stand is Hiro's . He was working as the team mechanic at the IIC. Totally his colors haha.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-05-2010, 07:54 AM   #979
Originally Posted by san. View Post
Thanks for the prompt reply, Korey. One other question. What do you gain from running longer links in the rear?
It makes the car a ton smoother overall. I usually find it makes the rear end a lot more stable, while also giving a little more mid-exit rotation. Especially in higher speed corners.
-Korey
Old 10-05-2010, 07:55 AM   #980
Hiro, assuming the picture below is Hara's car, you've posted on his setup sheet that he was using hole 2 in the rear hub. But the picture shows he's using hole 1.
I'm guessing he changed it for the main or is the setup sheet incorrect?
Yes like Korey said, we have tried many different setups in practice and qualifiers. The setup i have posted is the best setup we have found and actually used on the main day. Therefore, the setup sheets are all correct.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 10-05-2010, 08:40 AM   #981
san.'s Avatar
Trader Rating: 60 (100%+)
Thanks, Hiro and Korey.
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 10-05-2010, 09:08 AM   #982
AGNO's Avatar
Official photos of car Hara ... there was some confusion, many TCX to IIC.
You can see that he has not Tamy steering knuckles .
Old 10-05-2010, 03:38 PM   #983
RaceAce701's Avatar
Trader Rating: 84 (99%+)
is anyone running the TCX attending the Halloween Classic at the Gate
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-05-2010, 03:49 PM   #984
johnny boy's Avatar
Trader Rating: 265 (100%+)
http://shop.highvelocityracing.com/p...&categoryId=29
JOHNNY CHASE
Team associated, Reedy, schelle racing, Lunsford, Lead finger racing
johnny boy is offline   Reply With Quote
Old 10-06-2010, 07:17 AM   #985
rendcool's Avatar
is this a good car ?
rendcool is offline   Reply With Quote
Old 10-06-2010, 07:26 AM   #986
Airwave's Avatar
The best HB has never produced...
Airwave is offline   Reply With Quote
Old 10-06-2010, 07:31 AM   #987
hey!, ive just ordered a lrp Brushless Combo SXX TC spec/ Vector X12 Modified 3.0T kit and plan to run this with 50C 2S 5000mah 7.4v LiPO batteries. all this is hunky dory but i was wondering what gearing setup will i need? i am building this project solely for drifting, gunna run lp32-front/lp35-rear drift tyres from hpi on a hb tc d. and also will i need to change the diffs to tougher items or will the tc d parts work fine? so puting long story short, i would like to know what gears i should have and if necassary, what diffs will i need?
if you can help me out, send to [email protected]
please dont send me measages saying stuff like "um im not shure..." i realy dont like cleaning out my inbox.
thanks.
DEIGIMA is offline   Reply With Quote
Old 10-06-2010, 07:48 AM   #988
Exclamation ???????
ummmm...... someone explain what the heck that means.... if it said "the best HB has EVER produced..." it would make sence to me but "the best HB has NEVER produced doesnt make any sence. "never produced" seems to refer to it not being available... but it is...
IM CONFUSED!!!
Old 10-06-2010, 08:30 AM   #989
Cool heck! why not!
heres a complete spec list of what im planning on getting.
The following item is from hpiracing.com
LED SUPER LIGHT SYSTEM
THE FOLLOWING IS FROM HPIEUROPE.COM
-Hot bodies TC D
-TOYOTA SUPRA AERO BODY(200mm)
-LP32 T-DRIFT TIRE YOKOHAMA ADVAN NEOVA AD07 (2pcs)
-LP35 T-DRIFT TIRE YOKOHAMA ADVAN NEOVA AD07 (2pcs)
-LP35 WHEEL RAYS VOLK RACING RE30 CHROME (2pcs)
-LP32 WHEEL RAYS VOLK RACING RE30 CHROME (2pcs)
-ADJUSTABLE STABILITY CONTROL SYSTEM/DRIFT ASSIST d-box
-HB Aluminum Steering Servo Horn (25)
-ANTENNA PIPE SET 400mm (3pcs)
The following are from venom-group.com
-50C 2S 5000mah 7.4v LiPO Hard Case
-Venom Pro Charger w/ Power Supply
following from LRP
-BL Combo SPX Bullet Reverse/ Vector X12 8.5T
-LRP A3-STX Deluxe 2.4GHz F.H.S.S. Radio-Set
following from futaba-rc.com
BLS451 Brushless Digital High-Torque High-Speed Servo
i think i have done a pretty good job of finding good parts. im open to suggestions on a better (not necisarily cheaper) parts
if you see problems in this set-up then feel free to give me a pointer by replying
remember, this is solely for drifting.
thanks again
Old 10-06-2010, 09:49 AM   #990
Hebiki's Avatar
Trader Rating: 26 (100%+)
IM CONFUSED!!!
calm down dude.. it was more than likely a typo. he probably meant "ever". cut back on the caffeine.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
