Old 09-16-2010, 09:37 PM   #826
EJ20's Avatar
Default Tips
Originally Posted by transplantlife View Post
Hey guys should have my tcx tomorrow i hope. Wanted have you got any build tips? Thanx.
Originally Posted by Hi-LowBlow View Post
Hello guys,
I thought i should share some tips for the TCX building with you guys.
1. Front Sway bar Holder
When you install the sway bar holder on the bulkheads, I recommend you to shave the fitted groove a little bit for better sway bar fit especially for larger size such as 1.2mm and 1.3mm. Please see a picture attached. Without doing this, it might be too tight for those sway bars.
2. Recommendation of 46mm drive shafts
The kit comes with black composit diff outdrives. We will also have aluminum diff outdrives but with using those composit diff outdrives, you will be able to use the 46mm drive shafts in the rear as well. 46mm drive shafts don't fit with the option aluminum outdrives as they require to use with the plastic pin blades. Those composit outdrives are very strong and durable enough to use in modified racing. And the main benefit is that we can use 46mm drive shafts in the rear.
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 09-17-2010, 12:21 AM   #827
windstar's Avatar
I do not have a TCX yet, but looking forward to get me one.
Can someone please tell me the measure between the two bearings of a diff?
Thanks a lot!
windstar
No TC at the moment, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), VBC Lightning 12M, Sanwa M12
windstar is offline   Reply With Quote
Old 09-17-2010, 01:18 PM   #828
Does anyone know where I can get some steel 46mm dogbones that will fit?
Also, what does running 46mm dogbones in the rear do?
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 09-18-2010, 07:12 PM   #829
Will27's Avatar
Had some more track time with the TCX last night. Its getting better and each adjustment I made seemed to go in the right direction. Should get to race it properly next week
Just a quick note: Don't get as lazy as me! If your running the soft flex setting, check the remaining top deck screws for the lower bulkheads after each run. I found the screws for the rear ones were loosening themselves slightly. I caught one of them half way undone
Will27 is offline   Reply With Quote
Old 09-18-2010, 07:29 PM   #830
Am I missing something, or is it correct to say the only way to adjust the diff when it is in the car is by popping of a rear camber link and taking the dog bone out of the out drive?
Old 09-18-2010, 07:40 PM   #831
Will27's Avatar
Yep thats right.
Old 09-18-2010, 07:41 PM   #832
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
tamiya 46mm bone can fit....
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-18-2010, 09:08 PM   #833
Originally Posted by Will27 View Post
Yep thats right.
DUMB!
Old 09-18-2010, 09:09 PM   #834
Yep thats right.
STUPID!
Old 09-18-2010, 11:18 PM   #835
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
You don't have to...
I have a small flathead screw driver that can fit in the outdrive. Once the slot of the screw is visible and inline with the opening of the outdrive, I can place the screw driver in and turn the other wheel. Just need a small jeweler type driver. I thought the shank of a 1.5 hex driver would work also... I will look at that in the morning.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 09-18-2010, 11:42 PM   #836
Will27's Avatar
Hehe didnt think to say Im running 46mm rear shafts, so its hard to get to the screw on a angle because theres not much space and the screw head seems too far in on mine.
Old 09-19-2010, 07:57 AM   #837
I too am using 46 mm in the rear...
V-Dezign 4.0
Old 09-19-2010, 08:45 AM   #838
Dog Bone's Avatar
STUPID!
You're complaining about something that only takes a few seconds to do? Really?
How often are you messing with the tightness of the diff, anyways? It's trivial to set the correct tension when you build the diff - you can then check the tightness once every race day...
The only time I change the tension on the diff is when I rebuild it, which is, due to the quality of the diff and the materials therein, about 2, maybe 3 times a season.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 09-19-2010, 04:17 PM   #839
Airwave's Avatar
Are you sure that Tamiya dogbones fit?
If this is the case, the Spec R double joint dogbones for Tamiya could dit too... So we don't have to wait on Hotbodies to produce new DCJ...
http://www.spec-r.com/specrr2/module...products_id=11
No?
Airwave is offline   Reply With Quote
Old 09-19-2010, 08:22 PM   #840
peter_robinson's Avatar
Trader Rating: 21 (100%+)
No?
God I hope so... I hate the CV chatter.
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
