Old 09-15-2010, 02:33 PM   #796
evostyle's Avatar
Trader Rating: 102 (98%+)
Originally Posted by JLTrinity View Post
Hi everyone !
A question, why are top drivers using the body post here?
Thanks!
Sorry with my bad english.
My guess is that it keeps the body from bending down under high aerodynamic load from the rear wing at high speeds.
The rear post keeps the body from tucking.
evostyle is offline   Reply With Quote
Old 09-15-2010, 02:33 PM   #797
evostyle's Avatar
Old 09-15-2010, 02:48 PM   #798
RC MARKET's Avatar
Hi everyone !
Thanks!
3 racing or Ride
http://rcmarket.com.hk/index.php?cPath=68_126
or
http://rcmarket.com.hk/product_info....oducts_id=5702
RC MARKET is offline   Reply With Quote
Old 09-15-2010, 04:34 PM   #799
warnos's Avatar
I think you were talking about the body posts..
The body post facing out I also use on my NT1 just to protect the rear of the car in accidents....
Hara's car had them.. not that anyone was quick enough in SS to hit the rear of him..
Anyone know if a Hara or Andy M Eddition of the TCX is going to be realesed anytime soon?
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 09-15-2010, 07:05 PM   #800
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by kobiwan View Post
At my track we currently run 17.5 with no timing or boost. Our final drive ratio is 4.77. So i'm assuming I will have problems getting the gearing I need? What is the smallest spur that will fit on the TCX? Also, what brands other that Xenon will fit? My local track is pretty small, but I do travel to bigger tracks, so need to make sure I have some room to use different size pinions. My TCX should be here Friday. But if it is going to be a big hassle to make it work I'm going to return it. Any help will be appreciated. Thanks
Where can I find the poundage ratings of the springs? and I have looked for places to buy the pink springs but can't find them. Thanks again
Hello Kobiwan,
In response to your post, I worked on a tiny project to fit a smaller spur and larger pinion. With this mod I was able to fit a 96 spur and 49 pinion giving me a final ratio of 3.84. I used a reamer to make the holes in the spur, I am sure a drill press or dremel would look cleaner.
I spent less than ten minutes to make mod.
Look at the attached pictures=>
Attachment 642810
Attachment 642811
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 09-15-2010, 07:51 PM   #801
Originally Posted by David Galdo View Post
Hello Kobiwan,
Attachment 642810
Attachment 642811
Thanks for the reply. I'll probably end up doing the same thing. What brand of spur is that? Looks like a Kimbrough.
I ordered the Xenon 110 tooth spur today hoping it would work, but I think it will still be too big. Do you think they will eventually realize that everyone doesn't run mod and make smaller Xenon spurs?
Sanwa M12S---Awesomatix A800 ---Motiv---Defy---Orca
kobiwan is offline   Reply With Quote
Old 09-15-2010, 07:53 PM   #802
Korey Harbke's Avatar
You beat me to it! I didn't have pinions big enough to test it out Thanks Dave.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-15-2010, 08:13 PM   #803
ark
Hi I just finished building up a friends TCX and thought id share some amateur photos.
A couple of things I did was add a .19 shim in between the c clips and piston as there was a bit of play.
And add a .25 mm shim to the sway bar holder screws as it was tight on the bar.
Other than that is awsome to build!
oh yeah it takes a 48p xray spur upto 87t
Hot Bodies TCX-p9160130.jpg   Hot Bodies TCX-p9160139.jpg   Hot Bodies TCX-p9160138.jpg   Hot Bodies TCX-p9160137.jpg   Hot Bodies TCX-p9160136.jpg
ark is offline   Reply With Quote
Old 09-15-2010, 08:14 PM   #804
ark
more
Hot Bodies TCX-p9160134.jpg   Hot Bodies TCX-p9160132.jpg   Hot Bodies TCX-p9160127.jpg   Hot Bodies TCX-p9160124.jpg
Old 09-15-2010, 08:15 PM   #805
I will be running 17.5 with spec speedo. (no boost & no timing) What would be a good starting set-up? I am caught between trying the kit set-up or Hara's Super Stock set-up. Any suggestions?
Old 09-15-2010, 08:22 PM   #806
Hara's super stock setup is closer to what you'll most likely end up at. When I first got my car and tuned it for my track, I ended up with a setup very similar to Hara's.
-Korey
Old 09-15-2010, 08:28 PM   #807
-Korey
Haha, I would have tried my fifty but it's in the 12X.
Kobiwan:: I used the Kimbrough for this mod. I am sure there are other spur brands you can use. Just be sure to leave something between the teeth and the hole you make so it remains firm. You don't want a soft spot. The pinion may stretch/crush the teeth with the torque these BL motors put out.
V-Dezign 4.0
Old 09-15-2010, 08:46 PM   #808
Hello Kobiwan,
Attachment 642810
Attachment 642811
What size hole did you end up with when you were done?
Old 09-15-2010, 09:02 PM   #809
It looks to be around 4mm. It only needs to be large enough to see the objective. So mine may be larger than needed.
V-Dezign 4.0
Old 09-15-2010, 09:03 PM   #810
Trader Rating: 63 (100%+)
Send a message via AIM to joey
dave hows that TCX working down at mikes?
=Joe Wright=
joey is offline   Reply With Quote
SEO by vBSEO 3.5.0
