Old 08-31-2010, 07:41 AM   #676
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by joey View Post
spot 1...
Thanks "J Smooth"
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 08-31-2010, 06:08 PM   #677
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
WooHoo, placed my order. Should have my kit soon!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 09-01-2010, 12:49 PM   #678
stitchy's Avatar
TCXs have arrived at Speedtech....
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 09-01-2010, 06:22 PM   #679
tha Beast's Avatar
Trader Rating: 100 (99%+)
wooooohoooo mine shipped today
tha Beast is offline   Reply With Quote
Old 09-01-2010, 07:31 PM   #680
trf415msx's Avatar
Trader Rating: 14 (100%+)
thank you speedtech my ship it today ....cant wait
trf415msx is offline   Reply With Quote
Old 09-03-2010, 09:01 PM   #681
transplantlife's Avatar
Trader Rating: 43 (98%+)
came across this on youtube dunno know if any of you have seen this.. ENJOI
http://www.youtube.com/watch?v=WDfpp...eature=related
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-03-2010, 09:26 PM   #682
Be sure to jump on LiveRC.com next week and watch all the excitement. GO HB!
V-Dezign 4.0
Old 09-03-2010, 09:50 PM   #683
ark
Can someone tell me how the finish on the shock tower was achieved. Was it filed sanded and glued?
ark is offline   Reply With Quote
Old 09-03-2010, 09:56 PM   #684
Trader Rating: 66 (100%+)
Send a message via AIM to joey
this will show you how to do that sanding and sealing method...
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
=Joe Wright=
joey is offline   Reply With Quote
Old 09-04-2010, 10:11 PM   #685
Thumbs up Hot Bodies TCX Ceramic Bearings
Well since this is probably one of the first if not the first RC car to come standard with Ceramic Diff Balls, it's only proper that we offer a Hot Bodies TCX ceramic bearing kit! Only $88.99 delivered FREE to your door worldwide!
ACER Racing: the Fastest, Smoothest, Lightest & HARDEST BALLS in the INDUSTRY.
acerracing is offline   Reply With Quote
Old 09-05-2010, 03:32 AM   #686
ali_g's Avatar
Anyone tried cen racing ct5 gear diff on the TCX?
Their pulley are 39t, same as our ball diff pulley
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 09-05-2010, 11:03 AM   #687
Thraex's Avatar
Originally Posted by Hi-LowBlow View Post
Yes we are able to put the spec-r gear diff on the TCX if you would like to.
These are what you will need,
1. Spec-R gear diff for Tamiya 416x
2. Tamiya 416x front drive pulley
3. HB Cyclone TC front and rear drive belts
4. Tamiya 416x rear drive shafts
*For the rear drive shafts, you can also use our HB universal drive shaft (44mm) with plastic blades w/some dremel work on the drive cups on the gear diff.
I would suggest to start with #1000 diff lube.
Please let me know if you have any questions.
Thank you.
I've read some people would like to install a Spec-R geardiff (for the 416), but aren't trying it because at the front a tamiya pulley needs to be used and is a bit of a hassle to make sure it's center.
There's an easier solution;
I used a ball diff pulley instead of the one-way/spool pulley of the 416, used a reamer to make the center hole bigger (ream it from both sides) so that it fits snug over the HB spool. One screw hole will line up so the other 3 can be marked rather easily.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 09-05-2010, 10:44 PM   #688
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
since the 416 rear diff fits, why not fit a 416 spool as well? so no modifications are needed?
anyway, just sharing some snaps of my ride.
Hot Bodies TCX-21082010648.jpg   Hot Bodies TCX-21082010649.jpg   Hot Bodies TCX-21082010650.jpg
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-06-2010, 12:28 AM   #689
AGNO's Avatar
Because the spool 416 is not strong like TCX...
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 09-06-2010, 01:17 AM   #690
VooDooPH's Avatar
can try fitting the steel outdrives from the TA05 spool to make it stronger
