Old 08-23-2010, 01:33 PM   #646
jag88's Avatar
Originally Posted by Barry_Hughes View Post
Korey or Hiro,
Am I reading this set up sheet correctly ? Is Andy running a 1 deg front rear block along with a 1.5 deg front front block ?
With the new TCX bulkheads moved in 3 mm (total) I thought that these mods wouldn't be needed !!
OR am I missing something ?
Thanks.
jag88 is offline   Reply With Quote
Old 08-23-2010, 01:39 PM   #647
ark
Originally Posted by ali_g View Post
he is using thinner wheel hubs and 1.0deg FR blocks, wonder what's the effect like?
Looks like he is widening the front of the car?
ark is offline   Reply With Quote
Old 08-23-2010, 02:19 PM   #648
Originally Posted by jag88 View Post
Korey or Hiro,
Thanks.
Hello jag88,
Yes you are reading the setup sheet correctly.
It looks like he had 1deg in FR and 1.5deg in FF. Even though the new TCX has longer camber links than the cyclone tc, there still is some benefit to use the wider blocks. Please don't forget that it also changes the shock mounting position on the arms too.
Thanks,
Hiro Kasuya
Hi-LowBlow is offline   Reply With Quote
Old 08-23-2010, 11:24 PM   #649
tomracing's Avatar
Hiro Kasuya
Hiro,
if we only look at changing over to the wider blocks with everything else remaining the same the lower shock mounting point is shifted outwards. but so is the inner pivot and outer pivot point on the arm.
so effectively the motion ratio doesn't change right?
only if the upper shock position is kept the same the shocks are now angled slightly more and that lowers the wheelrate a bit.
the main thing that changes with this mod is track width, arm sweep and roll centres.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 08-24-2010, 08:36 AM   #650
OI82lose's Avatar
Default TCX tekin gearing
I am waiting for my TCX ( maybe today?) and am going to run
stock 17.5 (LRP) motor with a Tekin RS 208 vegas software.
Can someone recommend gearing?
The TCX manual says to go between 6 and 7.3 FDR.
I was going to run 116/35 (1.95 internal gearing) = 6.46 right in the middle to start, but I'm not sure if I should go lower (like 6.00) with the Tekin.
Thanks in advance.
OI82lose is offline   Reply With Quote
Old 08-25-2010, 11:08 AM   #651
Jim_1987's Avatar
I tried the TRF piston's, they fit like a glove. I want to get the titanium coated piston rod, but they appear to be out of stock everywhere. Does anyone know if the tamiya TRF piston rods will fit?
Jim_1987 is offline   Reply With Quote
Old 08-25-2010, 11:25 AM   #652
EJ20's Avatar
Yes, both are 28mm long, and the OD is same.
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 08-25-2010, 12:11 PM   #653
Jim_1987's Avatar
Excellent. Thanks for that.
Old 08-25-2010, 01:25 PM   #654
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Hahaha
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-25-2010, 02:18 PM   #655
Dog Bone's Avatar
Originally Posted by Owen RaCing View Post
Awesome!
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 08-25-2010, 02:28 PM   #656
san.'s Avatar
Trader Rating: 59 (100%+)
Will HB ship Priority Mail?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 08-28-2010, 05:04 AM   #657
ali_g's Avatar
Hello jag88,
Thanks,
Hiro Kasuya
Hi Hiro,
Do u guys drill a small hole on the shock caps? And what rebounds settings you guys will normally use?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 08-28-2010, 08:11 AM   #658
Default info
Hello,
I plan to buy one TCX, I have heard that Moore at the EC was using new chassis and new shock towers, is this true? where can I see this and other options?
Thank you
RC Racing addict
Roedor is offline   Reply With Quote
Old 08-28-2010, 10:35 AM   #659
Hi Hiro,
I have been using the shock caps and each cap has two 1.2mm holes. It kills the shock rebound no matter where the shock piston is when the caps are closed.
Old 08-28-2010, 10:39 AM   #660
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Are we out of customs yet?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
