Old 08-17-2010, 12:51 PM   #586
Originally Posted by Matt W View Post
Hi,
Im just building my tcx and i notice theres alot of slop and up and down movement in the steering rack, is this right or is there a way of shimming it to stop this?
I got rid of some of the slop in the steering mechanism by doing the 'plastic bag trick' for all of the ball cups (you put a plastic bag onto the ball end and pop the ball cup over it; it cuts out a small circle of plastic which helps take out the free play). This didn't cure the up and down movement of the arms on the steering posts; for that you'd need some 4x6x0.1mm shims I think - I haven't got a clue of anywhere that might sell them though.
A.Wojtecki is offline   Reply With Quote
Old 08-17-2010, 02:37 PM   #587
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by stitchy View Post
Still waiting...
Our pre-orders will go out as soon as they arrive! Should be very soon now!
Are you gonna "verify" pre-orders before shipping them out?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-17-2010, 02:49 PM   #588
Slideaway's Avatar
Tamiya proposes some shim sets in small bags. Inner Diameter from 3 up to 12mm (maybe more). There are 30 pieces in each bag: 10x0.1mm thick, 10x0.2 and 10x0.3. Enough to get rid of extra play anywhere, anytime... Definitely a must have.
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 08-17-2010, 03:37 PM   #589
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Questions?? Setup ?
Hi All
My kit is in Australia & will be here soon
The Question is what is a good place to start with setup for mod 4.5T , should i just start with kit setup & work from there ?
Stephen
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 08-17-2010, 04:26 PM   #590
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Depends what surface your running on and with what tires,
generally I'd start with the kit set up, maybe pinks instead of golds, that's about all I'd change for the initial run
hth
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 08-17-2010, 06:35 PM   #591
BLUE 2's Avatar
Questions??
hth
Luke
Hi
I run on asphalt - rubber tyres - low to med grip - tracks are a mix of open & tech.
Old 08-17-2010, 06:58 PM   #592
Joven M's Avatar
How many tooth spur gear does the kit come with?
Joven M is offline   Reply With Quote
Old 08-17-2010, 07:16 PM   #593
JeremyP's Avatar
It looks like it comes with a 115 tooth spur.
JeremyP is offline   Reply With Quote
Old 08-17-2010, 08:17 PM   #594
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
The manual is online at the HB site, take a look and put together a list of part numbers for spares.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 08-18-2010, 01:08 AM   #595
Whats a good servo to suit the TCX ? are brushless servo good.? thanks
Peter Reardon is offline   Reply With Quote
Old 08-18-2010, 02:10 AM   #596
Ko Propo PDS-2413ICS
Old 08-18-2010, 04:19 AM   #597
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
the futaba s9551 is a good servo - there's also a BL version of this servo, i just don't use them or have a part number
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-18-2010, 05:51 AM   #598
Slideaway's Avatar
Any low profile (or narrow profile) is fine:
- KO PDS 2413 ICS (maybe the best one)
- Futaba s9550 or S9551 (s9551 got a bit more torque)
- Sanwa SDX 801.
- Team Orion Vortex Servo VDS 1007.
Ludo
Old 08-18-2010, 06:11 AM   #599
Dog Bone's Avatar
- Sanwa SDX 801.
Is a low-profile servo required?
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 08-18-2010, 06:34 AM   #600
No, the servo doesn't have to be low profile. In fact I have a Ko Propo PDS 2367 ICS in at the moment and still have plenty of room for my electronics, but that's only because the Ko Propo KR-302f and Tekin RS Pro are really small. It would get quite tight if I was trying to fit in a GM or Speedpassion ESC in there. The advantages of a low profile servo include more space and lighter weight.
