Old 08-16-2010, 03:25 AM   #556
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
any news if 46mm steel universals will be available soon? if not, what alternative can we use?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-16-2010, 03:48 AM   #557
AGNO's Avatar
You can use MIP CVD HPI PRO 4 are 46mm, good and strong, are installed without problems
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-16-2010, 04:55 AM   #558
Send a message via AIM to Matt W
Hi,
just finished building my tcx and was wondering what position is best for the rear hubs (wheelbase), short or long. The kit said short, same as the tc but most people used to run long. Also when in the short position the driveshafts seem to be very angled,
any thoughts?
Matt W is offline   Reply With Quote
Old 08-16-2010, 07:22 AM   #559
M3Armand's Avatar
Originally Posted by chastro View Post
Generally happy with the kit. I have two other observations:
1: A 540 motor wont fit (540 is still a popular class here in Oz). Looks like I'm going to have to dremel the anodised motor mount =(
Can someone confirm this? I.e. - that "540" style brushed motors won't fit? So we can only run brushless motors in these cars?
Originally Posted by Luke Hobson View Post
hey guys...got the photos for the tcx build up onto photobucket, ...
Thanks for the posting the pics! I have some questions:
1) How many screws do you need to remove to change the spur gear?
2) How did you mount the Lipo battery? Is it "shoe gooed" into place? I can't see any mounting posts or tape.
M3Armand is offline   Reply With Quote
Old 08-16-2010, 07:46 AM   #560
For mounting the battery you either use the supplied 'lipo locator' (the plastic strap and guard thing + alloy posts) or you use tape (not supplied) - the slots to use are the end triangular ones.
A.Wojtecki is offline   Reply With Quote
Old 08-16-2010, 09:15 AM   #561
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
If you look hard enough he has the battery double sided taped in, most believe that it helps with equal chassis flex.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-16-2010, 09:30 AM   #562
Jim_1987's Avatar
My TCX is on order. Any recommend upgrades I should buy to improve strength and performance? Does anyone have a base setup for low grip asphalt?
Jim_1987 is offline   Reply With Quote
Old 08-16-2010, 11:52 AM   #563
Barry_Hughes's Avatar
TCX Kit set up
except 3 hole 1.1 pistons, 40wt oil frt & rear - lengthened the shocks to get a bit more droop ft & rear (5mm on a Hudy gauge), I measure the distance between shock case and top of ball end cup, this was 12.6mm.
Shock top mount in holes 3 front & rear.
1.5 camber ft & 2 rear
As for strength, they are very strong out of the box.
Barry_Hughes is offline   Reply With Quote
Old 08-16-2010, 11:54 AM   #564
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
anyone know if the tcx's manual is available online anywhere?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-16-2010, 11:58 AM   #565
Yep on the Hotbodies website
http://www.hotbodiesonline.com/instr...0&Submit=Go%21
Built it !
Raced it !
Wrecked it !
Old 08-16-2010, 12:25 PM   #566
Jim_1987's Avatar
Originally Posted by Barry_Hughes View Post
TCX Kit set up
Thanks for that. Does it come with purple servo posts?
Old 08-16-2010, 12:27 PM   #567
Just finished kitting mine all out and it weighs in at 1329g with GM motor, Tekin RS Pro, Ko Propo PDS-2367 and IP 5600mah 50C lipo. This is a serious improvement on my Moorespeed Cyclone which was about 30g overweight. I've checked the balance and it seems that actually the battery side has a greater moment around the centreline so I might have to add some masses behind the motor to balance it out.
This is with the kit totally as standard apart from the pistons which I've changed for the 3 hole items. I imagine that further significant weight savings could be made by replacing the steel turnbuckles and screws with titanium versions and replacing the spool with a Litemodz version.
Old 08-16-2010, 12:29 PM   #568
No, the kit servo posts are plastic. However I was surprised at just how solid they feel - I don't feel any urgent need to change them for the aluminium items.
Old 08-16-2010, 12:32 PM   #569
k_bojar's Avatar
thanks...didn't realize it was online yet
Old 08-16-2010, 01:08 PM   #570
Jim_1987's Avatar
I'm a sucker for purple aluminium bits.
