Old 08-15-2010, 08:43 AM   #541
Originally Posted by trigger View Post
The v3 spool is a hot bodies part and is very durable. i think its standard on the TCX. Correct me if i'm wrong about it being standard on the TCX.
That's pretty much correct - though the spool in the TCX is not actually the v3 spool from before, as the bulkheads are 3mm closer together. I think the outdrives are the same, just the central portion is narrower and it is also made from purple anodised aluminium rather than black steel.
A.Wojtecki is offline   Reply With Quote
Old 08-15-2010, 10:13 AM   #542
AGNO's Avatar
Yes, V3 spool is standard in TCX (just close) and the out drive is on steel, very, very strong.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-15-2010, 10:59 AM   #543
Barry_Hughes's Avatar
First run out with TCX today
Fan tast ic
So much more planted than my TC, the corner speed is something else, inproved my best lap times by 3/10ths of a second.
Just need to get used to how sharp the steering is.
Barry_Hughes is offline   Reply With Quote
Old 08-15-2010, 11:42 AM   #544
bigz's Avatar
Originally Posted by Korey Harbke View Post
Yes, I'm pretty sure that is hat Ty used at Nationals last week.
-Korey
Thanks Korey.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 08-15-2010, 11:45 AM   #545
bigz's Avatar
Fan tast ic
is it really that sharp? had my kit done but still haven't done any run with it due to work and stuff. hoping that i can run it this weekend.
did you use your tc set up with the tcx or its a brand new set up from scratch? tips will do as i don't have that much time to test it before our club race.
Old 08-15-2010, 12:11 PM   #546
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JayBee View Post
When can I get my grubby hands on one of these???????
I repeat....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-15-2010, 12:13 PM   #547
Hebiki's Avatar
Trader Rating: 26 (100%+)
I repeat....
jaybee... call up Jeff or Albert at www.speedtechrc.com
tell him i sent you. he'll hook you up.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-15-2010, 12:26 PM   #548
JayBee's Avatar
Just pre-ordered it....I'll call him up tomorrow Thanks buddy. Now where can I get some 32 & 36 SJR's OR black-spoked Solarises?
Old 08-15-2010, 12:57 PM   #549
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
hey guys
got the photos for the tcx build up onto photobucket, the linkk is in the bottom of the post.
they'll be going up on the blog at some point this week aswell as a bit of a step by step process
well anyway heres the the pics
http://s3.photobucket.com/albums/y96/gazdesigns/tcx/
cheers.
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 08-15-2010, 01:28 PM   #550
Dog Bone's Avatar
Still waiting for the TCX in Canada...another couple of weeks, methinks...
Ken Miller
T4 2014, 10r5.1 (F/S), 12r5.2 (F/S)
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 08-15-2010, 03:28 PM   #551
Yep it was that good.
Used the set up from my TC but ran the kit gold front springs rather than Assoc Blues I use on the TC.
3 hole 1.1 pistons, lengthened the shocks to get a bit more droop ft & rear 5mm on a Hudy gauge, I measure the distance between shock case and ball end cup, this was 12.6mm.
Shocks in holes 3 front & rear otherwise as kit settings.
1.5 camber ft & 2 rear
My car was not quickest in a straight line but awesome through the turns.
Old 08-15-2010, 09:10 PM   #552
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Luke Hobson View Post
hey guys
cheers.
luke
im curious, did you use Andy moore shocks or did you hop up the TCX shocks with the titanium shock shaft, purple M3 nuts and the purple pre-load collar?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 08-15-2010, 10:22 PM   #553
bigz's Avatar
Thanks Barry. will do that.
Old 08-16-2010, 01:37 AM   #554
Forget 40W oil all round
Racing outdoors on asphalt track
Old 08-16-2010, 04:11 AM   #555
Yep I used the shocks off the previous car.
And the purple nuts...... well how could I not add more purple lol
Luke Hobson
SEO by vBSEO 3.5.0
