Old 08-14-2010, 07:54 AM   #526
Send a message via AIM to Matt W
Hi,
just finished building my tcx and was wondering what position is best for the rear hubs (wheelbase), short or long. The kit said short, same as the tc but most people used to run long. Also when in the short position the driveshafts seem to be very angled, any ideas?
Matt W is offline   Reply With Quote
Old 08-14-2010, 08:01 AM   #527
bigz's Avatar
will xray spurs work with the tcx?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 08-14-2010, 08:05 AM   #528
Jim_1987's Avatar
Iím interested in getting a TCX, but I have a few questions regarding the kit. Iím currently running the tamiya 416x, itís an excellent car. But my main problem with the tamiya the front drive shafts and spool outdrives are very weak and i keep breaking them.
My question is, do you think the TCX is a stronger car than the 416x? Is anyone having any problems with the car?
Jim_1987 is offline   Reply With Quote
Old 08-14-2010, 09:47 AM   #529
AGNO's Avatar
V.3 spool mounted on the TCX is definitely stronger on the market .
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-14-2010, 09:56 AM   #530
Korey Harbke's Avatar
Yes, I'm pretty sure that is hat Ty used at Nationals last week.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-14-2010, 02:45 PM   #531
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
-Korey
Yup, they have 2 holes that work with the Cyclone and 416 spur hub.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-14-2010, 08:25 PM   #532
Any bright ideas about how to get to the inner motor screw (i.e. the one hidden behind the spur) if your spur doesn't have access windows in it?
As it stands, to change a pinion I'll have to: fit the pinion, put the motor in the right position using the outside screw, remove the top deck, remove the spur, do up the inner screw, replace the spur and top deck.
p.s. I know other cars have this layout... including x-rays... but I have no experience as the cyclone-black had motor screws above and below the pinion.
chastro is offline   Reply With Quote
Old 08-14-2010, 08:29 PM   #533
Slideaway's Avatar
Drill a 4mm hole in the spur gear like many other drivers already did. Easy and cheap.
Never leave any loose screw on a RC car, especially the motor's ones.
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 08-14-2010, 08:34 PM   #534
Yeah, I figured that might be the only option. I'll have to get a bigger spur. I wanted to use a 96 tooth (64 pitch), but my 4mm hole would have drilled out the teeth
Thanks.
Chas
Old 08-14-2010, 09:22 PM   #535
Thanks.
Chas
If it's that close, would a ball-tip wrench work?
-Mike
Old 08-15-2010, 01:15 AM   #536
AGNO's Avatar
I use RW Racing Spur and with them no problem.
http://www.rwracing.co.uk/about.html
Old 08-15-2010, 03:59 AM   #537
-Mike
Makes things easier, but I still needed to put holes through the spur. There is so little space.
Thanks Agno. If it works for you, it should for me.
C
Old 08-15-2010, 06:51 AM   #538
Jim_1987's Avatar
Is that an after Market spool?
Old 08-15-2010, 07:14 AM   #539
trigger's Avatar
The v3 spool is a hot bodies part and is very durable. i think its standard on the TCX. Correct me if i'm wrong about it being standard on the TCX.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 08-15-2010, 07:34 AM   #540
JayBee's Avatar
Trader Rating: 31 (100%+)
When can I get my grubby hands on one of these???????
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
