Old 08-12-2010, 03:31 PM   #496
AGNO's Avatar
Originally Posted by Hi-LowBlow View Post
Taking out some spacers on the crank gets less ackerman. We tried many different but 0 spacer was the best this time. Please note that this adjustment also depends on what kind of front arm sweep you have on the car.
Thanks,
But with less thickness should increase Ackermann?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-12-2010, 03:38 PM   #497
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Talking
Hi
Decrease Ackerman buy removing spacers - Add spacers to increase Ackerman.
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 08-12-2010, 03:38 PM   #498
AGNO's Avatar
TCX has finally arrived!
Old 08-12-2010, 03:47 PM   #499
AGNO's Avatar
Hi
Maybe I'm wrong, but I am convinced to the contrary ... less spacers, more Ackermann.
Old 08-12-2010, 03:47 PM   #500
BLUE 2's Avatar
Questions?? 48P Spur ?
Hi All
I have a TCX on its way & I was wondering what is the biggest 48P spur that will fit in the TCX .
Also when Building is there anything i need to look out for .
Old 08-12-2010, 03:56 PM   #501
AGNO's Avatar
Originally Posted by BLUE 2 View Post
Hi All
A 86 T 48P has a diameter identical to the 115T 64p of series.
Old 08-12-2010, 04:02 PM   #502
BLUE 2's Avatar
Talking
Thanks for that
See ya
Old 08-12-2010, 04:32 PM   #503
BLUE 2's Avatar
Hi
I know on the Cyclone TC you add spacers to add ackerman .
I just looked at the TCX pics & you could be right about the ackerman adjustments .
Can someone that has a TCX confirm this .
Old 08-12-2010, 04:35 PM   #504
Hi
Yes, less spacers means more ackerman. It's for both Cyclone TC and HB-TCX.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 08-12-2010, 04:44 PM   #505
san.'s Avatar
Trader Rating: 59 (100%+)
Thanks,
Thanks,
Hiro, which one is correct?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 08-12-2010, 05:18 PM   #506
Hahaha, sorry.
Less spacers is more ackerman. So sorry for the confusion.
Thanks,
Old 08-12-2010, 05:45 PM   #507
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
'was supposed to have my TCX's maiden run last night...couldn't even get half a pack of run time coz i kept stripping the spur gear. could because the orion motor i was running didn't have a bevel at the end so i couldn't get it to mesh right with a 31t (was supposed to run a 7.2 fdr with the stock 115t spur, we run 13.5t with tekins). geared up to 32t and 33t but it still kept stripping the spur. seems the xenon spur that comes with the kit is soft and can't handle the torque... will try running a 118t x-ray spur and pray to the high heavens that it holds up.
wondering if anyone has the same problem.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-12-2010, 07:51 PM   #508
defcone's Avatar
Trader Rating: 15 (100%+)
I've been running the same spur for almost a month now, with 10.5t and 4.5t motors and no such problems. Maybe your mesh isn't right?
defcone is offline   Reply With Quote
Old 08-12-2010, 09:07 PM   #509
VooDooPH's Avatar
must be the case. problem is it's near impossible to mesh an Orion motor using a 31t pinion using the stock 115t spur unless i dremel part of the top deck.
Old 08-12-2010, 09:57 PM   #510
bigz's Avatar
must've been your meshing. you must install the pinion the other way otherwise it will wobble. need to make my maiden run but...... damn.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
