Old 11-18-2013, 09:10 AM   #4786
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by ShaunMac View Post
Yes. The TCX and TCXX bulkheads are the same. Everything on the TCX will bolt right on.
The steering racks are different though. The holes on the TCXX chassis are positioned 2mm back compared to the TCX. The TCXX uses a +2mm bellcrank design for more throw and smoother ackerman change. You can still use your TCX rack on the TCXX chassis. It will just be positioned 2mm back and you will need to add a 2mm shim to get the ackerman back to what it was on the TCX.
thanks, Shaun
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-18-2013, 09:48 AM   #4787
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Originally Posted by k_bojar View Post
will tcx bulkheads and such fit the arrowmax chassis?
everything from the TCX will bolt onto arrowmax chassis
remember if you get the Arrowmax lowered shock towers you will need to use different shocks...i.e. Xray T4 or the CSO small shocks.
Chassis is very nice....the floating servo mount is very trick.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-19-2013, 04:52 AM   #4788
k_bojar's Avatar
thanks, Orlando I already am running the lowered shock tower (spec-r's) and like them, but am running the standard shocks - didn't try a smaller shock on the car since I like how it runs at the moment. but then again, I've only run this for USVTA lately
Old 02-10-2014, 10:57 AM   #4789
theclutch's Avatar
So did everyone pretty much jump off this thread and onto the TCXX thread? I just didn't want to be double posting if so.
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 02-11-2014, 03:48 AM   #4790
k_bojar's Avatar
sadly, that's your best bet...I know I'm still running the chassis - love it -but everyone else is over there
saw your post in the tcxx thread, don't know about the bearings, but if the graphite one fits (which I have the exotek version), the the aluminum one should..my only concern would be whether it would fit under the upper deck
Old 07-06-2014, 07:26 PM   #4791
theclutch's Avatar
Originally Posted by 2xs View Post
I have a chart I made with as many brands as I could find. HPI/HB, AE, Tamiya, Yokomo, Schumacher, Xray. Currently it is in excell, but I can turn it into a pdf to share when I get home from work. If anyone is interested in it just shoot me a PM.
Hi there! Can you send me the Excel? PM sent! And thanks in advance!
Old 10-21-2014, 09:57 PM   #4792
Trader Rating: 20 (100%+)
garage cleaning after IIC
HPI Pro 4, TCX, TCXX parts lot
goots is offline   Reply With Quote
Old 09-02-2015, 11:35 PM   #4793
Schs2013's Avatar
looking for advice on how to setup my second hand tcx. will be running VTA with 21.5 at our local club.
the car was from looks of it a drift set up. where should i start setup wise for a carpet track?
VBC Lightning 10LM, Tamiya M05v2
Losi TEN MT, Traxxas 1/10 Summit LT, Vaterra K-10
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 09-03-2015, 05:12 AM   #4794
theproffesor's Avatar
Trader Rating: 55 (100%+)
Get petite rc and look for a 17.5 carpet set up for the tcx or tcxx as a starting point
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-03-2015, 08:47 PM   #4795
I have a brand new no-hole bottom chassis that's good for carpet and a few extra parts to update tcx PM me if interested
Old 09-03-2015, 10:15 PM   #4796
Schs2013's Avatar
Cool thanks for the help.
Old 09-09-2015, 01:51 PM   #4797
wayne breault's Avatar
Default Rear belt
Need Help. Got a used TCX 2 years ago, broke my rear belt. In the book the part number is 68704 ordered 2 belts part number 68704 64 tooth. It won't fit, the belts are too small. I rotated the bearing holder and it's still to tight. Can anybody give me a hand? Thank You
wayne breault is offline   Reply With Quote
Old 09-09-2015, 02:00 PM   #4798
endurohero's Avatar
check your front pulley that it is a 18 , 19 or 20 tooth and the big pulley is 39t.
endurohero is offline   Reply With Quote
Old 09-09-2015, 04:26 PM   #4799
Default Rear belt
Center pulley 20 tooth, rear def 39 tooth. New rear belt part number 68704 64 tooth. Fits so tight you have to put both hands on front and rear and if you let go of one hand one side will pop off.
