Old 08-08-2010, 06:11 AM   #466
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Originally Posted by yokemad View Post
But on BD5 They use a Chassis just like Retail Version Tcx Chassis ! with many Cuts
At the end of the day they should find the best design works flawless on every condition because most of the racers hasn't got sponsorship deal and chassis options are not very affordable ...
but its a bit too late now...
The BD5 has about 4 different bottom decks...
Teams will always test new parts, the bottom deck that comes in the TCX kit is the best for a large number of conditions... From mod to super slow 17.5/21.5 etc
you wouldn't expect to have a car that worked perfectly on both rubber and foam tires using the same bottom deck...
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 08-08-2010, 06:57 AM   #467
Barry_Hughes's Avatar
Just built mine, ready for racing next week
Everything went together fine, couple of obsverations
1. If you use lipos with the battery bumps, they will not sit flat unless you turn them upside down. OK if you have lipos that have the ability to connect both ways - my new Nosrams allow this, my Demon Lipo's don't only battery connection is from the opposite side to the that with the bumps. Perhaps that is why Andy has the chassis he is using. It has the cutouts to fit the Lipo's with the battery locators.
2. The top deck restricts full movement of the motor for gear meshing, it can be shaved but since it is not very wide at that point
I run 13.5 and on the TC I run 74/31 = 5.16. On the TCX this relates to 74/28 which will not fit. I am going to have to go 79/30 or 82/31. Which hopefully should fit OK (77/28 is just about OK but the mesh is loose) But the way the motor mount support fits may hinder larger pinions if the motor needs to be moved to the most forward position.
Anyone using their TCX yet? are you using the same set up as your TC?
Looking at the standard kit set ups they are very similar so I presume to put my TC settings straight on to the TCX is the best way to go.
Barry_Hughes is offline   Reply With Quote
Old 08-08-2010, 08:48 AM   #468
bigz's Avatar
i think there will be a lot of version of the bottom chassis layout.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 08-08-2010, 08:50 AM   #469
yokemad's Avatar
Sorry didn't know they were using foam tyres at tc euros ...
yokemad is offline   Reply With Quote
Old 08-08-2010, 09:11 AM   #470
Airwave's Avatar
They are not!
Same problem here with the top deck, to pass a 115/28 ratio which is indicated as possible in the manual... I dremelized it (1mm by 1mm)!!!
I plan to order some quality screws, purple aluminium hex for the top, stainless steel torx for the bottom...
Does somebody knows this shop : http://www.fastener-express.com ???
It seems serious...
Airwave is offline   Reply With Quote
Old 08-08-2010, 09:16 AM   #471
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
They are using rubber.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-08-2010, 09:43 AM   #472
If your insisting on being pedantic about this, then I could have used examples of the difference between Tarmac and carpet.
I figured it would be easier for the masses the understand why the difference in bottom deck if I said foam and rubber becuase it's obvious that you wouldn't use the same for both.... Jeez
obviously they're on rubber but Yokemad is trying to stir things, just like in the yokomo BD5 thread....
Anyway, back onto something productive on this topic......
Luke Hobson
Old 08-08-2010, 10:27 AM   #473
yokemad's Avatar
Not really Luke, Im just free to write what ever my thoughts are
And don't have to promote any product...
I was looking at bd5 and they have 4-5 chassis, you think that's normal and fair enough
that's mainly because of the new tech. Stuff...
For a year old chassis it may sound ok but Its a bit too early to see that on a week old one ...
Anyway
Enjoy your new ride...
Old 08-10-2010, 03:13 AM   #474
spencehotbodies's Avatar
Default tcx kit set up
Hello
Have found the kit tcx set works well out of the box, the std tc set up is nearly the same.
The only thing I will be changing is 1.5mm spacers to 2mm spacers under the toe in blocks front and back.
hpi uk-hotbodies-brentfordrc
spencehotbodies is offline   Reply With Quote
Old 08-10-2010, 05:44 AM   #475
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
It seems serious...
those guys are decent...but this site - www.rtlfasteners.com/ - have better prices, may not have all the aluminum bits the other place has but definitely better prices
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-10-2010, 05:46 AM   #476
k_bojar's Avatar
some people aren't happy unless they are complaining or stirring up stuff
since the first day he was in this thread, he's been bad-mouthing things..
but anywho
Old 08-10-2010, 08:29 AM   #477
yokemad's Avatar
Can I ask what is this forums For?
How about that:
Tcx is Great Car
Happy now?
Old 08-10-2010, 05:38 PM   #478
Hello everyone,
As you might already know, HB factory team driver Ty Tessmann did excellent job at the ROAR paved on-road nationals this past weekend. I just wanted to share the setup with all of you guys.
Here you go.
Please let me know if you have any questions!
Hi-LowBlow is offline   Reply With Quote
Old 08-10-2010, 05:48 PM   #479
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by Hi-LowBlow View Post
Hello everyone,
Here you go.
Any spacers under the front sway bar ball studs?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 08-10-2010, 06:21 PM   #480
Dog Bone's Avatar
Hello everyone,
Here you go.
If Ty ever took on-road seriously, he'd be a force to recon with. Of course, I think he had a pretty good mechanic at the race, don't you?
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
