Old 03-03-2013, 02:48 PM   #4756
theproffesor's Avatar
Trader Rating: 55 (100%+)
Ive been out of touring for a while now and wondering what advantage these floating servo mounts offer over the standard mounts?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 03-03-2013, 04:40 PM   #4757
Dog Bone's Avatar
By attaching the servo at one point, you allow the chassis to flex consistently across it's width.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 04-07-2013, 04:39 PM   #4758
Trader Rating: 25 (100%+)
hello i just picked up a tcx and was wondering if there were other battery holders that will work with this car? and as for the floating servo, which one will fit for this car also? Thanks.
bomber9 is offline   Reply With Quote
Old 05-30-2013, 03:43 PM   #4759
theclutch's Avatar
Check out the hotbodiesonline.com website and you will see all the parts that you are looking for.
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 08-06-2013, 11:00 AM   #4760
New to on road and picked up a second hand tcx my problem is the car doesn't want to drive straight, servo, steering rack, and wheels are all straight any help would be appreciated
MUGEN SEIKI -PANTHER TIRES -AIRTRONICS -LRP -ADVANTAGE RACING PRODUCTS -LFR -RC PIT SUPERCROSS -(the difference between average and excellence is effort)
hardcorr76 is offline   Reply With Quote
Old 08-06-2013, 11:51 AM   #4761
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Welcome to on road.
To your question there are so many variables..no one person can give you a definite answer. Tweaked, balance, bad bearing, etc,etc
The best advice I can give is download the manual and tear it down all the way then have fun building it.
As you rebuild check for any possible tweaked parts, etc.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 08-15-2013, 05:44 PM   #4762
Hi all Just picked up a TCX second hand and just wanted to know what kind of setup you guys would suggest for a small tight carpet track. I dont need it to go super fast but to be more balanced for this type of surface. I have never run on carpet ever.
JQ The ECar, Hot Bodies TCX, Team losi 8ight 2.0 truggy, Trex 700 nitro heli, Outrage Velocity 50 N2 heli, ProBoat Impulse 31.
agentorange is offline   Reply With Quote
Old 09-11-2013, 06:37 PM   #4763
RCworks216's Avatar
Trader Rating: 26 (96%+)
whats a good place to get set up info for the tcx? picked up a use TCX and im new to TC racing. How do you ADJ the belt? seems loose to me and most pics ive seen have the tension/ belt is set high. sometimes when im running the car the belt comes out and is sitting on top of the tension bearings.
Racer Distribution- trackside mobile hobby shop.
Tires, Kits, Bearings, Wheels, Oils, Servos, Engines,
RCworks216 is offline   Reply With Quote
Old 09-11-2013, 07:25 PM   #4764
Trader Rating: 20 (100%+)
Petit rc for setup sheets. This thread for info. As for belt tension you need to rotate the cams on the diff front and rear. I think also hb gives two different sizes for a possible 10 setting? Not quite sure
goots is offline   Reply With Quote
Old 09-14-2013, 12:48 AM   #4765
any new updates for the TCXX! is there development for this car?
Old 09-14-2013, 06:43 AM   #4766
Fred Hubbard's Avatar
Wrong thread.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-17-2013, 05:43 PM   #4767
Bump so I don't have to dig so deep to find this thread anymore.
gordondude24 is offline   Reply With Quote
Old 11-04-2013, 09:46 AM   #4768
Hi guys. Thanks for keeping up this thread. I have a 2nd hand TCX and one of the steering arms is missing a bearing. Does anybody knows the size of this bearing? I was trying to put a new bearing instead of buying the whole set. Is in backorder wherever I try to buy it.
Thanks for your help in advance.
MYM Racing is offline   Reply With Quote
Old 11-04-2013, 10:24 AM   #4769
theclutch's Avatar
Do a search in the Hot Bodies website for the electronic manual. This way, you will 1) know about the Hb website, 2) you will have the electronic manual and find all the parts you need. I'd post the manual here for you, but that won't "teach you how to fish".
Old 11-04-2013, 10:30 AM   #4770
olhipster1's Avatar
manual does not show the bearing size for the bell crank
it shows as one whole part number...since the bearing comes installed with the bellcrank.
but they fall out sometimes...
you can only fish if you're in water
from manual
b012 = belt tensioner bearing
b017 = layshaft bearing
b020 = diff bearing
b021 = axle bearing
b030 = outdrive bearing
CAUSE and EFFECT
