Old 12-03-2012, 06:20 AM   #4726
Kabul_RC's Avatar
Will TCX parts fit on a cyclone S? I am scouring the Internet for parts and can't seem to fine a site that has parts for the cyclone s in stock. Thanks..
DLIKE RER weightshiftmeister - RWD drift car
OUTCLIP Yokomo Drift Package conversion
Kabul_RC is offline   Reply With Quote
Old 12-03-2012, 08:20 PM   #4727
Trader Rating: 20 (100%+)
You can use cyclone TC parts.
goots is offline   Reply With Quote
Old 12-04-2012, 11:41 PM   #4728
SuperFastSnail's Avatar
Trader Rating: 77 (100%+)
Default tcx for vta
Hey everyone, I'll be using my TCX for VTA racing using a Ballistic 25.5 motor. Anyone has a rollout they like to share; what pinion and spur are people using on a moderate 35 degree of timing on the Ballistic motor. I know temping the motor is the safest way to go about but I like to get a good start since I brought the TCX down from the shelf. I was running a a TC4 previously and I was running a 55t pinion with a 78t spur. Motor temp was around 120' fahrenheit. Any help is greatly appreciated.
JU KE
Sponsor by Makita Li-Ion Brushless Power Tools. Eat the power!
Selling something but no pictures, goodbye.
SuperFastSnail is offline   Reply With Quote
Old 12-05-2012, 12:23 AM   #4729
why not just use the same FDR from your TC4 and apply it to your TCX. That would be a good starting point
Old 12-06-2012, 04:54 AM   #4730
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
shoot me an email (won't remember without one )and I can give you the setup I have on my TCX from the last time I ran it...Car was hooked up and ballastically fast!!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-19-2012, 08:28 AM   #4731
cheehtae's Avatar
Trader Rating: 15 (100%+)
Anyone have a good set up for blinky 17.5 carpet, with the narrow chassis and the new shock mounts? Thanks.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-19-2012, 09:56 AM   #4732
M3Armand's Avatar
Default Rear Gear Diff, Front Ball Diff or Spool for Carpet?
Originally Posted by AGNO View Post
For carpet I recommend 500K, same hardness works very well also on asphalt, yesterday I used to race in one track very small and technical, I won the TQ and won the race, very fast car and easy to drive, I used two differential Spec-R with 500K ant. and 1K post. with the front differential I have combined with the DCJ 44mm resulting a truly exceptional steering with the total absence of chattering.
Hey guys, I'm running the Spec R gear diff in the rear with a Losi 1000 wt oil. First, when doing searches, I keep seeing "500k" or "300k", etc. Can I assume that this is 500 wt and 300 wt oil?
Also, I'm tired of the chattering in the front when running the spool. I put the ball diff in the front and this certainly eliminated the chattering. But it seems that the car lost some "turn in" and generally less traction on the front. I then tightened the ball diff more and more and it seems to correct it little by little, but still not the same turn in as the spool. Is this the normal reaction of ball diff vs. spool in the front? I'm running the stock springs all around (front gold, rear silver) but will be trying the pink springs in the front.
One of the other benefits to running the ball diff for me is that there a little "give" when hitting a corner. I've busted way too many diff cups; both the stock cups (for 46 mm) and the long cups (for 44 mm drive shafts or DCJ's). This happens significantly more now that it's cold vs. when it was warm.
Any comments on my setup and if I'm better off running the spool in the front vs ball diff?
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 12-19-2012, 10:47 AM   #4733
AGNO's Avatar
Also, I'm tired of the chattering in the front when running the spool. I put the ball diff in the front and this certainly eliminated the chattering. But it seems that the car lost some "turn in" and generally less traction on the front. I then tightened the ball diff more and more and it seems to correct it little by little, but still not the same turn in as the spool. Is this the normal reaction of ball diff vs. spool in the front? I'm running the stock springs all around (front silver, rear gold) but will be trying the pink springs in the front.
The post mentioned it was my very old post, one of the first tests with the front differential
Now recommend minimum 1000K (one million)is the right way.
To completely eliminate the chattering with spool, I suggest you use the doube cardans shafts Spec-R 46mm, really good, smooth and robust!
Possibly, with geard diff ant, use HB DCJ 44mm shaft.
I do not recommend the Ball diff on the front...
What kind of tyres you use on carpet?
With Sweep 32 tires, at the Italian carpet championship, I've had good results using HB spring Hara spec, Black at the front, Gray at rear.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-19-2012, 11:01 AM   #4734
M3Armand's Avatar
Hi Agno, thanks for the quick reply!
So is 1000 wt oil = "1000K"?
Why not ball diff at the front? I am running the Sweep 32 OR the HPI #4495 X-pattern radial belted 26mm Pro Comp tires for "GT Class".
Lastly, I though Hara's (and all the HB pros as per the downloadable setup sheets) were Pink at the front and Silver at the rear?
Old 12-19-2012, 11:31 AM   #4735
AGNO's Avatar
Yes, 1000K is a one million (500K is half million...)
The gear diff at the front is more efficient and durable of the ball diff
For carpet, I found, best springs Hara spec, similar to Yokomo Pink/blue spring, but slightly more harder.
They are also excellent HPI spring Pink/silver, but with too much bite, there is a tendency to roll over
Old 12-19-2012, 05:06 PM   #4736
Airwave's Avatar
You also can use RIDE springs, they are quite perfect and around the famous HPI silver...
Airwave is offline   Reply With Quote
Old 12-31-2012, 11:31 PM   #4737
Does anyone know which DCJ's I would need to use with the new HB68833 gear diff in the front and rear of my TCX?
Does this gear diff support the old 61333 diff cup addaptors?
TypeR01 is offline   Reply With Quote
Old 01-01-2013, 04:11 AM   #4738
I'm using specR v2 dcjs. Then use the 2.3mm blade that come with the gear diff set. Works a treat.
bob33 is offline   Reply With Quote
Old 01-01-2013, 10:14 AM   #4739
cheehtae's Avatar
which one's? there are several, super soft,soft,medium,h and sh.
Old 01-01-2013, 10:54 AM   #4740
AGNO's Avatar
Grey Soft #66962
Black Medium #66963
