Old 08-29-2012, 12:58 AM   #4651
Mitropoulos Jim's Avatar
Originally Posted by JLTrinity View Post
Ouch!, i think i will keep with my ball diff. ;-)
Thanks for the replies
Regards
The new bulkheads are 3mm narrower than the cyclone ones, meaning 1.5mm each side.
You won't need any different bearings, just need to add some shims.
You can buy 0.3mm shims and not use the 0.1 hpi ones.
Add 2 or 3 shims each side maximum. Also, you can reverse the bulkheads, because there is a pattern on the inside of them, and if you reverse them it makes them a little norrower.
I had this layout at my cyclone and raced with no problem at all.
Hope this helped
Mitropoulos Jim is offline   Reply With Quote
Old 08-29-2012, 01:00 AM   #4652
Forgot to mention that the diff will have a little play, but there wont be a problem
Old 08-29-2012, 06:14 AM   #4653
JLTrinity's Avatar
Thank you very much Jim, i try it.
Regards
JLTrinity is offline   Reply With Quote
Old 08-29-2012, 09:40 AM   #4654
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hope this helped
you need the different bearings - because when you shim out the diff, the part of the case that's made to ride in the bearing, isn't where its supposed to sit..
so you need different bearings in the bulkhead so that the diff actually rides on something - without the different bearings, the diff kinda just hangs there and causes a lot of drag...that's why I took mine out of the TC
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-30-2012, 01:22 AM   #4655
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I got an older cyclone a while back. Can someone tell me what the difference between these two caster blocks is? The plastic is totally different.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 08-30-2012, 03:46 AM   #4656
When i bought and installed the gear diff, I couldn't find such bearings, so I put 2-3 shims each side, and left much of play left-right. Also reversing the bulkheads helps a lot. With this layout the diff doesn't have where to "hang", so there is not a problem.
Of cource, if you can find wider bearings, it would be nice-but not necessary. Thats what I am saying.
Old 08-30-2012, 05:16 AM   #4657
Think he means the inner diamiter of the bearing not thickness
bob33 is offline   Reply With Quote
Old 08-30-2012, 09:56 AM   #4658
M3Armand's Avatar
I believe one is actually plastic and the other (as with the parts on the TCX) is graphite and more brittle.
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 08-30-2012, 01:46 PM   #4659
is there a part number for the hb gear diff yet? i have had a look but cant see one.
Old 08-30-2012, 08:37 PM   #4660
Trader Rating: 20 (100%+)
the block on the right is the plastic ones that come with the cyclone s. The left is the graphite piece that came with the cyclone, tc, tcx, tcxx
goots is offline   Reply With Quote
Old 08-31-2012, 12:23 AM   #4661
JLTrinity's Avatar
Hello all again,
I have seen the setup of Atsushi Hara at the worlds and he uses in the shocks:
2000 cst oil and 1.3mm x6 ?
You can see this http://www.petitrc.com/reglages/hotb...728/index.html
I never see this setup on the shocks, is it better? I never uses an oil > 60 wt.
Anyone has tested this setup?
Thank you very much
Old 08-31-2012, 09:50 AM   #4662
Fred Hubbard's Avatar
Hey everyone,
I just wanted to let you all know that the kits did arrive a couple of days ago and are shipping to the distributors/local shops but like Hiro said it may take a couple of weeks for them to arrive.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-31-2012, 10:29 AM   #4663
k_bojar's Avatar
Originally Posted by Fred Hubbard View Post
Hey everyone,
very cool...
not sure I've ever met you - but see that you switched from the 'dark side' (xray) cool
Old 08-31-2012, 10:51 AM   #4664
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
Fred running a HB??? Wow...Fred...Ken Brumblay is weeping rightnow..LOL. I see him crouch down in a corner crying.
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 08-31-2012, 10:54 AM   #4665
very cool...
Not sure we have either Yep
Yep LOL, sorry Ken
