Old 08-22-2012, 02:52 PM   #4636
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
Selling my TCX here... Hotbodies TCX
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 08-22-2012, 03:46 PM   #4637
Trader Rating: 6 (88%+)
Originally Posted by k_bojar View Post
see my responses, below
Awesome thanks a bunch.
Would it be good to run a gear diff front AND rear? Im used to running offroad cars so not so sure about onroad. Its been almost 10 years since I ran onroad!
I think its got steel outdrives already, have to take some pictures and post them. It was used and already fully put together.
http://www.spec-r.com/default/index....roducts_id=350
Are these what your all talking about?
Ironwolf1974 is offline   Reply With Quote
Old 08-22-2012, 04:07 PM   #4638
Trader Rating: 195 (99%+)
Does anyone know if a 3mm or 3.5mm chassis is available anywhere for the TXC? I want to run foam tire sedan at my local track. Needs to have the wide topdeck layout like the carpet cars had.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 08-22-2012, 05:02 PM   #4639
Sorry my mistake it's a Roche product I was talking about. Here's a link to it
http://www.roche.hk/shopping/index.p...product_id=444
markrobinson is offline   Reply With Quote
Old 08-22-2012, 05:15 PM   #4640
Yeah my outdrives are not aluminum, there spring steel. I DO have some aluminum ones in the bag, but dont need weight reduction as Im going to be using this for a breakoutclass/usvta.
Old 08-23-2012, 07:13 PM   #4641
Can anyone tell me about the gear diffs?
Should I keep the solid front axle?
What if I use two gear diffs in my car?
Old 08-23-2012, 10:54 PM   #4642
Trader Rating: 20 (100%+)
depends on the size of the track, corners, and driving style. I currently run dual gear diffs with some tight corners.
goots is offline   Reply With Quote
Old 08-27-2012, 08:22 AM   #4643
Anyone have a pair of the spec r gear diffs for sale?
Old 08-27-2012, 08:28 AM   #4644
Is there a solid release date for the new car yet?
Hiro......whats the official word?
Before Vegas?
Josh Hohnstein is offline   Reply With Quote
Old 08-27-2012, 09:05 AM   #4645
JLTrinity's Avatar
Hi all!
Anyone knows is the tcx spec-r diff fits on the Cyclone TC?
Thank you!
Regards
JLTrinity is offline   Reply With Quote
Old 08-27-2012, 08:47 PM   #4646
Originally Posted by JLTrinity View Post
Hi all!
Thank you!
Regards
no, its not a direct swap because the bulkheads are norrower. But who knows, this is just an assumption
Old 08-28-2012, 05:25 AM   #4647
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hi all!
Thank you!
Regards
it will fit, BUT you need a ton of shims and some different bearings for the bulkheads...If i remember correctly, I had something like 15-20 shims on each side to center the diff correctly - if a big trial-and-error thing..
because its made for the narrower bulkheads of the TCX, the out drives are in the bearings and not the molder 'shoulder' of the diff case - so you need a smaller inner diameter bearing then the stock bearings the TC uses..
I've had them in my TC, but took them out because of the bearing issue
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-28-2012, 12:45 PM   #4648
JLTrinity's Avatar
Ouch!, i think i will keep with my ball diff. ;-)
Thanks for the replies
Regards
Old 08-28-2012, 01:37 PM   #4649
Before Vegas?
I was informed by our purchasing dept that we should be receving the kits in this week. I just don't know how long it will take to reach to your LHS but it wouldn't take more than two weeks i guess?
Thanks for waiting everyone!
Hi-LowBlow is offline   Reply With Quote
Old 08-28-2012, 09:09 PM   #4650
thats awesome news. Will spare parts be available the same time the car releases?
