Old 08-06-2010, 10:40 PM   #451
ekim628's Avatar
The Hotbodies team is running strong here at the Nats. Ty is running well with the new TCX, remember he hasn't run On-road asphalt in a long time. There are also 3 Hotbodies in the top ten of Expert 17.5 We are all working together and getting faster every round.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 08-07-2010, 05:19 AM   #452
Airwave's Avatar
HI guys, please take a look ok Andy Moore EC car:
It seems that he's using a different chassis... A narrower uncuted chassis...
Airwave is offline   Reply With Quote
Old 08-07-2010, 08:56 AM   #453
yokemad's Avatar
They always use different chassis looks like mi4lp or bd5W chassis...
I was thinking about the new tcx but I don't want to buy a tc that not even in team spec !
yokemad is offline   Reply With Quote
Old 08-07-2010, 09:14 AM   #454
bigz's Avatar
is that a gear diff from HB???
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 08-07-2010, 09:30 AM   #455
tomracing's Avatar
looks like the same car he ran in andernach at the ETS (and also appeared at the worlds possibly the car referred to as reacting more aggressive):
it is still the gear diff for the 416 probably he also used this in andernach.
for the people looking to convert with the tamiya front pulley stop using the white one.
i think tamiya part number 84050 is the same 37t pulley but in black!
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 08-07-2010, 10:29 AM   #456
RC MARKET's Avatar
is Square alum. pulley !
RC MARKET is offline   Reply With Quote
Old 08-07-2010, 11:40 AM   #457
ali_g's Avatar
anyone tried xray nt1 gear diff on a TCX?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 08-07-2010, 04:27 PM   #458
jag88's Avatar
Originally Posted by Hi-LowBlow View Post
Both front and rear belts are from Cyclone TC not the tamiya belts. Since the gear diff and the front pulley are 37tooth, those belts fit perfectly with the 20tooth center pulleys.
As for the drive shaft blades, if you use hb drive shafts the blades should also be the hb. If you use tamiya drive shafts, the blades should be the tamiya blades. I just don't know if those blades are compatible with hb drive shafts.
Hiro, I now this is the TCX thread but can you put the Tamiya gear diffs in the TC ? Actually my biggest worry are the belts. Will the TC belts work with the Tamiya gear diffs in the TC ?
Thanks.
jag88 is offline   Reply With Quote
Old 08-07-2010, 04:28 PM   #459
Airwave's Avatar
Yeah!
Just the ESC to re-solder and let's go for the first try!
Old 08-08-2010, 01:00 AM   #460
windstar's Avatar
Does anyone knows which geardiff fits to the TCX (or TC)?
windstar
No TC at the moment, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), VBC Lightning 12M, Sanwa M12
windstar is offline   Reply With Quote
Old 08-08-2010, 01:07 AM   #461
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
There was a post a couple pages back regarding the Spec-R and all other parts to fit it in the TCX.
Hot Bodies TCX
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 08-08-2010, 03:30 AM   #462
warnos's Avatar
This car looks allot like the new Yokomo BD5 World Spec with the battery bump slots on the battery side.... Wonder which feels better... might be the TCX Moore Edition.. due in 6 months..
Originally Posted by tomracing View Post
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 08-08-2010, 04:00 AM   #463
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Or, more likely, if the bottom deck is found to be better in some conditions then it'll get released as an option part....
Jeez, some people really let thier minds wonder, when sat infront of a computer screen.
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 08-08-2010, 04:12 AM   #464
yokemad's Avatar
But on BD5 They use a Chassis just like Retail Version Tcx Chassis ! with many Cuts
At the end of the day they should find the best design works flawless on every condition because most of the racers hasn't got sponsorship deal and chassis options are not very affordable ...
but its a bit too late now...
Old 08-08-2010, 04:49 AM   #465
mac853's Avatar
Questions??
Did he use 40T pulley, which is the only aluminium which i saw in Square catalog, isn't it?
mac853 is offline   Reply With Quote
