Old 08-02-2012, 02:36 PM   #4591
Originally Posted by moraccio View Post
Hiro, a few questions:
- what is the rear toe in in Andy's set up? 3 deg as usual?
- how many mm under rear pivot (FR RR)?
- I noticed Andy reduced the shocks lenght to 62.0 and 62.5mm why? Maybe to reduce the oil pack during the open corners?Sorry if i'm saying something totally wrong
Thank you so much!!!!
Hi moraccio,
Sorry, the setup sheet was missing (again) some info. Please see below.
Yes it was 3 deg as usual.
Andy's car had 1.5mm on RF/RR.
Basically, we change the shock length to adjust the piston position mainly. Making it shorter lets the piston sit lower, so in this case, the shocks have more pack as they are set shorter. Once we find the good shock piston position, we try to adjust the legth front and rear differently to let the piston sit about the same on both front and rear. (the same shock length needs to be different front and rear when you want the same piston position for both front and rear as they both have different leverage.)
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 08-03-2012, 02:49 AM   #4592
Bar
Hiro, how come the guys are running tamiya rear hubs and not the new hot bodies ones? And how come the shock oil being ran is so thin, was it because the track was really smooth? Sorry i always run associated or schumacher oil which is measured differently so i believe this is actually really thick
Bar is offline   Reply With Quote
Old 08-03-2012, 02:50 AM   #4593
peter.'s Avatar
when we can preorder the tcxx
peter. is offline   Reply With Quote
Old 08-03-2012, 07:21 AM   #4594
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Originally Posted by peter. View Post
We can already preorder the tcxx
Where are you pre-ordering from?
OnRDPassion is offline   Reply With Quote
Old 08-03-2012, 08:23 AM   #4595
peter.'s Avatar
sorry my mistake it should be (when we can preorder the tcxx)
Old 08-03-2012, 09:16 AM   #4596
Hello Bar,
The reason they used the Tamiya rear hubs on their car was that the rear camber link position on the hubs. Out side hole on the tamiya rear hub is actually right in the middle of two holes on our new rear hub and the position worked the best at the world.
Please donít take this info incorrectly, we used the Tamiya one this time but that doesnít mean that our new rear hubs donít work as good as Tamiya hubs. This kind of things is tuning option such as shock springs, etc. The best setup may vary depends on the condition. We might have another rear hub set later as an option item for the TCXX so we can pick off-set camber link positions on each hub.
As for the shock setup (thicker oil), we used the setup at the worlds because it has been proven. We have been trying/testing it at many different tracks and it seems the setup works really well at most of the condition. Of course we make finer adjustment to suit the track condition by changing piston hole size, oil, etc everytime we go to different track though.
Hope it answers to your question.
Old 08-06-2012, 01:18 AM   #4597
peter.'s Avatar
when can the HB tcxx preorder
Old 08-06-2012, 12:51 PM   #4598
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
any one looking for aluminum knuckles and/or rear hubs?
I have a set of 3Racing ones up for sale
Kaybo's Garage Sale - Lots of Stuff
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-06-2012, 07:30 PM   #4599
louielou's Avatar
Trader Rating: 16 (100%+)
Default pistons
what conditions r shortening the shocks n lowering piston postion advantages?
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 08-08-2012, 08:36 AM   #4600
I know some people simply say that lowering the piston position gives more traction, but in my opinion it is really hard to say it's "more" or "less" as it really depends on other factors.
Piston position changes the dampaning characteristic drastically. You can control the rigidity effect (mainly for the roll of the car for both front to back and side way) by adjusting piston position. This adjustment actually doesn't change the dampaning, it changes how the piston compress the oil (above the piston) before the oil pushes up the bladder eventually. (rebound)
To answer to your question, I would shorten the shocks and lower the piston position when i want more roll rigidity on the car.
Hope it helps. (and sorry if i make you confused by the bad english explanation....)
Old 08-08-2012, 09:01 AM   #4601
k_bojar's Avatar
probably more of a question for your local hobby shop - unless you're going to order direct from HB
Hiro can only say when its going to be available to the shop/distributors - its then up to your local place to decide when they want to accept pre-orders
Old 08-08-2012, 11:07 AM   #4602
RC MARKET's Avatar
HB New Arrived !
RC MARKET is offline   Reply With Quote
Old 08-08-2012, 06:01 PM   #4603
eceer's Avatar
Does anyone know of a 3rd party replacement for the A302 Ball cups?
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 08-09-2012, 07:59 AM   #4604
k_bojar's Avatar
you can use Losi A6017 rod ends from the JRXS-R - was recommended a while ago to take out some of the slop. plus they are open, so you don't need to keep poping them off for shim adjustments
only downside, you'll need longer turnbuckles all over:
camber links need the 3x34mm turnbuckles (steering) 61247
steering links need to be longer as well - but i don't know the length off hand...i did this 'mod' when i was building my car, so don't remember what size i used
you can search thru this thread for posts from MikeHaynes - i think he said what size you need for the steering links once you do this
Old 08-09-2012, 08:03 PM   #4605
Trader Rating: 194 (99%+)
I use the Losi HD ballcups the really firm ones. I trim them a little on the end then use a body reamer to open a hole above the ball so I can use a 2mm to remove them without popping ballcups.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
