Old 08-01-2012, 05:38 PM   #4576
Originally Posted by Hi-LowBlow View Post
Hi all,
Team HB's world setups! (From Teemu, Shin and Hara)
I will post Andy's later.
1.3mm 6 hole piston?????
Do we know why?
Do you know what fr block hara was using?
Josh Hohnstein is offline   Reply With Quote
Old 08-01-2012, 05:57 PM   #4577
theatriks's Avatar
Do we know why?
Im just guessing but maybe its a rain set up?
theatriks is offline   Reply With Quote
Old 08-01-2012, 06:41 PM   #4578
Do we know why?
Probably relates to this:
Originally Posted by Korey Harbke View Post
Still 1.1mm. The diameter of the newer pistons is increased in comparison to tamiya or the older HB pistons. They fit SUPER SUPER DUPER AWESOME in the shock body. Little to no fluid will pass over the edges of the pistons. It will mainly be focused through the piston holes. They seem like they fit a smidge tight, but DO NOT sand the pistons. They smooth out when oil is introduced into the shock .
6 hole pistons are great on tracks where there is a good mix of different kinds of corners. They let the car flop around a little more at low speed, and pack up really good in high speed chicanes and such. They seem really effective on higher grip tracks!
-Mike
Old 08-01-2012, 09:36 PM   #4579
Trader Rating: 20 (100%+)
what are the specs to the ride s-3 yellow springs compared to the pro4 springs?
goots is offline   Reply With Quote
Old 08-01-2012, 10:43 PM   #4580
Matthijs's Avatar
Do we know why?
look at the oil wt..... 2000 cSt
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 08-02-2012, 12:13 AM   #4581
Ecxellent!
Thank you so much Hiro!!!!!!
Hi all,
moraccio is offline   Reply With Quote
Old 08-02-2012, 01:48 AM   #4582
rbalint's Avatar
Dear Hiro!
Can You please let me know of the FR and RF block Atsushi used? My assumptions are FR 1 and RF 0, but his (setup) sheet is a little different then the other 2.
Balint
rbalint is offline   Reply With Quote
Old 08-02-2012, 08:38 AM   #4583
Do we know why?
Actually, we have been trying this shock setups with many different suspension setups combined for long time and been getting very good results. We have also tried this on Ty Tessmann's car in some of qualify rounds of the US nationals in New Jersey and kept trying more and more to make the improvement after that.
As for the suspension blocks that AH used were 2pcs 1deg blocks on FR and 1deg on FF. Sorry, the setup sheet was missing this part.
Thanks,
Hiro Kasuya
HB/hpi
Hi-LowBlow is offline   Reply With Quote
Old 08-02-2012, 08:49 AM   #4584
When will the hb gear diff be out and is there a part no for it? And the split blocks?
Also what is the benifit of runing tamiya rear hubs?
bob33 is offline   Reply With Quote
Old 08-02-2012, 09:11 AM   #4585
peter.'s Avatar
when can we expect the tcxx in europe
peter. is offline   Reply With Quote
Old 08-02-2012, 09:13 AM   #4586
Trader Rating: 17 (100%+)
Tamiya hubs allow you to have a slightly shorter or slightly longer upper camber link. Depends on what hole in the hub you use.
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-02-2012, 10:59 AM   #4587
over gear's Avatar
Trader Rating: 15 (100%+)
did i read that right? 6 holes piston with 2000wt shock oil?? that's diff grease, isn't it?
over gear is offline   Reply With Quote
Old 08-02-2012, 11:19 AM   #4588
Thanks,
Hiro Kasuya
HB/hpi
Thanks Hiro, I guess thats something I will have to try.
The first 3 setups all seem to be pretty different from each other.
I look forward to seeing Andy's setup also.
Old 08-02-2012, 11:59 AM   #4589
Here is Andy's setup from the worlds.
Old 08-02-2012, 01:44 PM   #4590
Hiro, a few questions:
- what is the rear toe in in Andy's set up? 3 deg as usual?
- how many mm under rear pivot (FR RR)?
- I noticed Andy reduced the shocks lenght to 62.0 and 62.5mm why? Maybe to reduce the oil pack during the open corners?Sorry if i'm saying something totally wrong
Thank you so much!!!!
