Old 06-23-2012, 03:39 PM   #4456
thanks for the reply. the tamiya shafts is that just the bones and use the hb axels or is it full tamiya set up? you got a part number for the pro4 whishbones? thanks.
bob33 is offline   Reply With Quote
Old 06-24-2012, 02:19 AM   #4457
Hi bob
Yes just the tamiya bones and pro 4 arms are part no. 67717
markrobinson is offline   Reply With Quote
Old 06-24-2012, 04:25 AM   #4458
AGNO's Avatar
Hello Bob33, I use the spec-R C.V. universal swing shaft V2 46mm, with the original HB spool, very strong and work very well, zero chattering.
Here's also a setup that I use for 13.5 Boost, it works for me very well.
In my second TCX for tests, use the arms Pro4/Cyclone item # 73506, are more resistant, but with these the general behavior of the car is slightly less rapid
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 06-24-2012, 04:55 AM   #4459
thanks for the reply both of you
. out doors are the std tcx wishbones weak then or will they be fine? when i had a wce and tc back in the day i cant remeber ever braking a front arm indoors either.so if there the same as them i should be fine.
wil give the set up ago and work from there. as the track i race on is pretty low traction so need a good rear!
is there any thing els the tcx will benifit from while im ordering some bits?
and is threr a flexy top deck/chassis made for this?
Old 06-25-2012, 04:31 AM   #4460
AGNO's Avatar
With the arms TC-TCX never had a problem outdoors, but some break on indoor wood dividers.
With standard chassis I prefer standard top deck, with Smokem chassis I prefer Spec-R V2 top deck, which is slightly more rigid.
Old 06-25-2012, 06:58 AM   #4461
Barry_Hughes's Avatar
I use the Exotek Extra soft chassis & top deck - very impressed with them
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-25-2012, 12:13 PM   #4462
Agno would that set up be any good for low/medium tight outdoors? And on the set up sheets what's the wheel hub spacer? Sorry for all the questions.
Just looked at the exotec chassis they look pretty good. Where did u get urs?
Old 06-25-2012, 01:36 PM   #4463
DMS Racing are the UK importer, and they are listed on their site - price is very good too! as cheap as mine which I imported!
Built it !
Raced it !
Wrecked it !
Old 06-25-2012, 01:54 PM   #4464
AGNO's Avatar
The setup is good for low / medium grip and medium track.
At front use 4mm hub and 0,5 mm spacer item #7244 http://www.hpieurope.com/piw.php?lang=en&partNo=72044
The Exotek chassis is very interesting ... in the future will prove it
Now I'm using the original HB narrow chassis
Old 06-25-2012, 02:21 PM   #4465
will stick that on the car then ill see if i can get hold of them hexes. thanks
just looked on dms the prices are good may give one a go.
Old 06-26-2012, 02:31 AM   #4466
Airwave's Avatar
Did you try to cut the end of the wheel axle? Just to ensure they don't overstep the bolt?
I had similar problem with indoor wood track because the wheel axle plant in the wood and stop the car...
I have no picture of that modification on my TCX, but I've done the same on my Awesomatix...
Credits: www.overrc.com
Airwave is offline   Reply With Quote
Old 06-26-2012, 05:27 AM   #4467
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
If anyone is interested in a TCX package, message me! All of my stuff is for sale, cars have so many upgrades plus tons and tons of spares
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-26-2012, 05:57 AM   #4468
AGNO's Avatar
Yes, of course, I always made ​​the cut the end of whell axle
Only that the edge of the wood is hard...
Old 06-27-2012, 07:31 AM   #4469
theatriks's Avatar
I think i found the part number we are all gonna need in a few weeks ....hot bodies 68299....
theatriks is offline   Reply With Quote
Old 06-27-2012, 04:35 PM   #4470
Sam9's Avatar
Why won't you sell your spares to me?
Beware of Shane Cornish, don't do deals with him.
Sam9 is offline   Reply With Quote
