Old 06-13-2012, 10:58 AM   #4426
Trader Rating: 17 (100%+)
cyl-112 0degree
cyl-113 .5 degree
cyl-114 1 degree
cyl-182 1.5 degree
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-13-2012, 10:58 AM   #4427
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by olhipster1 View Post
which split blocks would be recommended?
Here ya' go bud. BTW, hope to see you soon @ T&L! I need some onroad fix soon!
http://www.jethobby.com/_Jet%20Racin...X%20Parts.html
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 06-13-2012, 11:06 AM   #4428
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
thank you...much appreciated.
Track is ready.
Sat 12noon is the usual start time.
Now to decide to buy them all. or just 0 and .5 split block
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 06-13-2012, 03:33 PM   #4429
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Track is ready.
Orlando - I ordered the 0* and 0.5* ones...I put the 0* one mine - and I did that mainly before my spec-r gear diff was rubbing on the rear block and had to dremel a huge chunk of the block out...the split block works perfectly to get around this issue
I had them on my USVTA car at the Slowbirds - and I think i did pretty well with it in VTA
just wish i could find a cheap TCX to have for normal TC racing
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-13-2012, 08:01 PM   #4430
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
0 and -0.5 for rear. -1 for front with 1.5ff block
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-13-2012, 08:15 PM   #4431
olhipster1's Avatar
I took a gamble and ordered all of them
CAUSE and EFFECT
Old 06-14-2012, 07:08 PM   #4432
k_bojar's Avatar
Old 06-15-2012, 12:02 AM   #4433
ok, dumb question time. What is the degree of the standard HB FR block then (given the degree amounts for the Jet Racing split blocks) ?
here in the UK right now im running a 2.0FF block, and a 2.0FF (but modified to fit in the FR location). This put the wishbones dead level to the bulkheads.
Any idea what blocks I should order to get the same, but using the JR split blocks ?
Cheers
Jo90uk is offline   Reply With Quote
Old 06-15-2012, 06:34 AM   #4434
MINT condition Hot Bodies TCX with tons of spares including a second set of shocks, spare arms, knuckles... etc. Only ran on carpet with a 17.5 blinky 3 races. It has many hop-up parts including aluminum knuckles (tamiya 417 for better geometry), aluminum rear hubs (also tamiya 417).
Roller only (with parts) $300 + shipping
Almost Ready to Run (with a Speed Passion LPF Speed control and a 21.5 trinity motor) set-up for blinky 21.5 $450 + shipping
duckman996 is offline   Reply With Quote
Old 06-18-2012, 07:54 PM   #4435
transplantlife's Avatar
Trader Rating: 43 (98%+)
any news on the TCXX
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 06-19-2012, 04:44 AM   #4436
Bar
i run my tcx pretty standard except 3 hole 1.1 pistons 3 hole hubs(using extra hole) and tcx lower shock towers. I am trying to get more low speed steering on my car, i always seem to end up running 2 deg rear toe-in at the end of the day otherwise the car is just not fast enough and pushes wide.
my setup for 13.5 open
FRONT
pink front springs
45wt shock oil
camber 1.5deg
0 deg toe
droop 5 measured using associated plastic droop gauge
1.5 FF pivot block
1.5mm spacers FF RR
shock position no 2 from inside
Rear
silver rear springs
40wt shock oil
camber 1.5deg
2 deg rear toe-in
droop 4 measured using associated plasic droop gauge
1.5mm spacers
shock position no 4 from inside
ball diff
sorex 32's
usually racing on medium grip asphalt tracks in UK
Bar is offline   Reply With Quote
Old 06-19-2012, 05:05 AM   #4437
Jim_1987's Avatar
FRONT
pink front springs
45wt shock oil
camber 1.5deg
0 deg toe
1.5 FF pivot block
1.5mm spacers FF RR
Rear
silver rear springs
40wt shock oil
camber 1.5deg
2 deg rear toe-in
1.5mm spacers
ball diff
sorex 32's
What roll bars and roll centre’s you running? I would run softer shock oil, I usually run Much More 400 to 450 in the front and 350-400 in the rear. What tracks are you struggling with?
Team MMR Flux - www.mmrflux.co.uk
Jim_1987 is offline   Reply With Quote
Old 06-19-2012, 06:58 AM   #4438
Bar
roll bars are 1.4mm front 1.2mm rear
roll centres are 1.5mm all round
i use fastrax shock oil i don't know how that compares to your much more oil. I race on most tracks in the UK the only place i have had the car how i like it was at stafford's BRCA Clubmans. I guess the setup is mostly for Bedworth as this is my local track
Old 06-19-2012, 08:33 AM   #4439
theatriks's Avatar
I know but theres no hype build up for this kit i think
theatriks is offline   Reply With Quote
Old 06-20-2012, 05:58 AM   #4440
FRONT
pink front springs - try silver
45wt shock oil - perhaps try 40wt but id go no lower
camber 1.5deg - shuold be ok, but how is the tyre wearing ? across the face or just the inside half, if only inside half go to 2deg
0 deg toe - 0.5 toe out either side (1mm total overall)
1.5 FF pivot block I normally run 2.0ff & Fr)
1.5mm spacers FF RR
shock position no 2 from inside - try 3 or even 4, seems wierd but actually induces more turn in due to pressure on the arm)
Rear
silver rear springs
40wt shock oil
camber 1.5deg - try 2.0deg
2 deg rear toe-in - try 2.5 or even 3
1.5mm spacers (make the car just short of long wheelbase (put the small spacer behind the wishbone at the pivot block and the same on the rear hub)
ball diff - Do you have a GearDiff at all ? If so build this with 55wt schumacher oil or a loose GD oil
sorex 32's - what trye prep and additive ?
See my changes above mate, give them a try and see which way it goes for you. PS less rear toe actually take rotation away.
