Old 06-09-2012, 06:34 PM   #4396
A buddy of mine who is sponsored by Hot bodies was telling me that the major points of the tcx-x is it will come with a gear diff, narrow chassis, and lower mount shock towers.
I got a hold of some TC-FD front knuckles and they made a world of difference in stability on this car. I highly recommend the 3 hole knuckles!
zenkikid is offline   Reply With Quote
Old 06-10-2012, 06:11 AM   #4397
theatriks's Avatar
You got a part number?
theatriks is offline   Reply With Quote
Old 06-10-2012, 06:25 AM   #4398
Trader Rating: 194 (99%+)
They are the 3 hole knuckles, the rear hubs are also lower at the camber rod mount that come with the set.
68796
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 06-10-2012, 06:35 AM   #4399
vadersing's Avatar
Default TCXX
This is what I got from a Chinese RC forum. Most detailed leak so far.
vadersing is offline   Reply With Quote
Old 06-10-2012, 08:50 AM   #4400
Definitely going to get that front pivot block, rear split block, steering arm, narrow chasssis, and motor stay/servo mount.
Old 06-10-2012, 10:08 AM   #4401
Looks good - but why on earth have they decided to change the rear driveshafts to steel but leave the front ones as aluminium. That's the opposite to what most people have actually done to the TCX - changed the front driveshafts to steel and left the rear as aluminium. If they leave the design like that it'll be double the cost as both the front and rear driveshafts will need changing out of the box, rather than just the fronts as before - madness!
A.Wojtecki is offline   Reply With Quote
Old 06-10-2012, 09:55 PM   #4402
If your going to copy the Tamiya, go all the way!
Realtek is offline   Reply With Quote
Old 06-11-2012, 12:30 AM   #4403
AGNO's Avatar
Pictures from Holland
ISTC warm up
TCX-X
Hot Bodies TCX-sun-andychassis.jpg Tested two types of chassis
Unfortunately the race was not lucky for the team HB, all in the final B.
However, Hara scored twice in qualifying the second position, very fast.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 06-11-2012, 06:50 AM   #4404
theatriks's Avatar
Why are there so many tamiya chearleaders in this thread....this is a hot bodies thread if its got nothing to do with the tcx or new tcx-x ....beat it!!!!
Old 06-11-2012, 06:50 AM   #4405
jag88's Avatar
New motor mount has four positions for motor screws !!
Very smart !!
jag88 is offline   Reply With Quote
Old 06-11-2012, 10:51 AM   #4406
M3Armand's Avatar
Originally Posted by mac gregor View Post
for granty110:
HPI-68770 SOLID AXLE LONG CUP (POM/2pcs)
HPI-68769 SOLID AXLE LONG CUP (STEEL/2pcs)
HPI-68720 FRONT ONE-WAY SET (TCX)
Model: SPR009-HB spec -R Gear Differential Set 39T (For HB-TCX)
Does anyone have any durability experience with the 68770? I've just used the 68769 for ONE DAY and one of them already broke. Note that I usually break suspensio arms, knuckles or hubs. But I've never broken any of the stock "short" cups. I am using the DCJ 44 mm driveshafts which is why I am using the long cups. It seems like once I swap out one part for another to prevent breakage, the new part is then the part that breaks. So I don't want to try the 68770 at $15 when the steel ones are $8 especially if the aluminum ones end up breaking even faster...
M3Armand is offline   Reply With Quote
Old 06-11-2012, 11:46 AM   #4407
The 68770 are fine if your using the standard frt blocks (2.0 and 0).
When I ran 1.5 and 1.5 (no sweep) the 44mm dcj's will pop out and wreck the pom outdrive. They are plastic with an aluminum sleeve.
The steel outdrives seem to be much more durable. I did crack one but it was a freak thing.
Josh Hohnstein is offline   Reply With Quote
Old 06-11-2012, 12:50 PM   #4408
M3Armand's Avatar
Hmm... plastic for $15...steel for $8... I guess "steel is still real"...
THANKS for the input!!!
Old 06-11-2012, 12:51 PM   #4409
KWT-NITRO's Avatar
Hey guys,
Askin for a friend!! What gear diff will fit the older TC?
Cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 06-11-2012, 01:06 PM   #4410
Why are you still trolling in this thread? Go back to the xray forums. We don't feed trolls here.
