Old 06-03-2012, 06:33 PM   #4381
theatriks's Avatar
Wow this thread finally got a pulse lol
theatriks is offline   Reply With Quote
Old 06-06-2012, 01:12 AM   #4382
Seriously ! The ETS is a who's who of the RC touring world most of the time. Past world champions, and past worlds podium placers. 3 cars in the top 10 out of 10, thats nearly 1/3rd of the grid.
Seriously, go have a word with yourself in a corner, and dont come out till you have !
On a different note I saw someone mention the Exotech chassis. I have been using the smokem chassis and found that also to be excellent. Not using the steering brace and the turn in and precice handling is excellent. I also run the -2mm towers by SpecR. It's a great combo. Will likely put the steering brace back on once I go back to carpet this winter though.
Jo90uk is offline   Reply With Quote
Old 06-06-2012, 08:58 AM   #4383
Trader Rating: 48 (100%+)
I hate to do this but I have to get rid of my TCX and I want to see it go to a good home. If you or your buddy needs a really nice one with tons of spares check mine out. Hot Bodies TCX with tons of extras and tires
awdtsi is offline   Reply With Quote
Old 06-06-2012, 09:13 AM   #4384
Originally Posted by Hi-LowBlow View Post
We have full team drivers at the ETS Rd-5 here in Holland.
Any setup sheets from the ETS to share?
Would like a stock one but I'll take Hara's or Moore's
vassago is offline   Reply With Quote
Old 06-07-2012, 01:03 AM   #4385
Barry_Hughes's Avatar
Must admit I don't have a turn in problem running the brace, only slight improvement I would like is a bit more mid corner high speed steering, low speed is excellent.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-07-2012, 03:16 AM   #4386
Hi Barry, I think being a different chassis they react very differently. I've found the mid and high speed steering is imense, the car just grips at speed and can be pushed out of a corner safely.
Current setup I ran at WLRC the other week (Q2 for the finals behind Ashley Wiffen and in front of Malc Hall)
Front
Roche Spool
2mm under wishbone FF/FR
1mm under top link (inner hole)
Hole 3 on shock tower (from inside)
Hole 2 on wishbone
Medium wheelbase
2degree FF & FR suspension blocks
-1.5 deg camber
4 deg caster
4mm shims on steering link
-1 toe out overall (0.5 per side)
400Wt Much More
Silver Springs
65mm shocks, full rebound, no foam insert
Rear
SpecR GearDiff with Kinetic Yellow* oil
Hole 4 on shock tower (from inside)
Middle hole on wishbone
Long wheelbase
2.5 Deg RR suspension block
-2.0 deg camber
400Wt Much More
Silver Springs
Worked a treat on Sorex 32YG's using MR33 Tarmac additive.
Old 06-07-2012, 04:13 AM   #4387
Front
Roche Spool
Hole 2 on wishbone
Medium wheelbase
-1.5 deg camber
4 deg caster
400Wt Much More
Silver Springs
Rear
Long wheelbase
-2.0 deg camber
400Wt Much More
Silver Springs
I am using long wheelbase at front
1.5 under FF/FR and 2RF/1.5 RR
kit FF FR blocks 2.5/??
1.2 Fr roll bar, no rear roll bar
and gold springs all round
as the back end was loose
1000cst in Spec R diff - what is the Kentic oil, I saw Malc is using it as well, googled it and came up with nothing
Built it !
Raced it !
Wrecked it !
Old 06-07-2012, 10:36 AM   #4388
theatriks's Avatar
I gotta tell you guys ...i got an xray t3 and an awesomatix...but for some reason the excitment i have for the release of the TCXX is almost unbearable......any sneak pics of the tcxx the hotbodies crew was running at the euros
Old 06-07-2012, 01:20 PM   #4389
M3Armand's Avatar
Originally Posted by Korey Harbke View Post
Usually races like this are seen as research and development opportunities. Just because they may not have performed to some's expectations doesn't mean they won't come back with something better the next time around. HB is always testing new things and documenting their findings for later use.
As a person that works in research and development and as a race engineer for a Formula SAE Team, this is a common experience. We sacrifice certain things to get testing done. Information and data are power
I don't think so. So you think it makes sense for them to "sacrifice" this race for the sake of data collection? Really? Like they can't collect data at any other tracks/times and where the top drivers in the world are not also competing and that it's not a highly publicized race? Nope, the simple answer could be is that they just got spanked by Tamiya... You don't "sacrifice" a highly publicized race against top drivers for data collection...
M3Armand is offline   Reply With Quote
Old 06-07-2012, 03:17 PM   #4390
warnos's Avatar
Default 2mm lower shock towers
Little confused with these shock towers as I find the orginal ones are better on Medium Grip Asphalt.
Back when I was using the TC it was a good idea to have higher towers to have more shock oil packing on the piston. Now with the TCX are ppl preferring the lower towers on high grip or low grip conditions..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 06-07-2012, 09:12 PM   #4391
Trader Rating: 20 (100%+)
well if they have their new car coming out soon. I think it would be appropriate to test many things with the worlds coming up. Isnt the ISTC worlds at the same track? correct me if im wrong
goots is offline   Reply With Quote
Old 06-08-2012, 02:35 AM   #4392
AGNO's Avatar
No, the track of Apeldoorn where he ran the ETS is not the track ISTC.
The track of the world ISTC is Heemstede.
However, it seems that the team HB has taken advantage of ETS to test new material and also to test the track Heemstede.
New chassis tested by Adachi at the ETS.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 06-08-2012, 10:10 AM   #4393
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
remember, the ETS is a series of races, not just a one time shot
where else would you get the chance of testing new stuff against REAL competition?? can't re-create real competition and events that happend during a race...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-08-2012, 10:36 AM   #4394
Attachment 932418
Good lord thats a narrow chassis.
zenkikid is offline   Reply With Quote
Old 06-08-2012, 11:41 AM   #4395
theatriks's Avatar
Attachment 932418
Yes sneak peak just what the doctor ordered ..thanks dude
