Old 05-20-2012, 09:11 PM   #4321
Trader Rating: 20 (100%+)
is the 3 hole aluminum spindle the same dimesnsions as the new 3 hole carbon ones? Im tired of trying to hunt down #68796
goots is offline   Reply With Quote
Old 05-21-2012, 02:47 AM   #4322
AGNO's Avatar
Yes,they are very similar
The graphite spindle have only the three holes slightly closer to the wheel.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-22-2012, 08:37 AM   #4323
Let me jump into this a little bit. I know many people get confused with the new steering knuckles that has very similar design shape to the existing aluminum kuckles. The steering linkage positions (three holes) on the new knuckles are different from the aluminum one. Please be careful with that when you use them.
Thanks,
Hiro Kasuya
HB/HPI Team Manager
Hi-LowBlow is offline   Reply With Quote
Old 05-22-2012, 08:45 AM   #4324
Trader Rating: 194 (99%+)
Thanks,
Hiro Kasuya
HB/HPI Team Manager
Hello Hiro, Will yourself or anyone else from the HB team be attending the Reedy race this weekend. I will be there running my TCX and could use a little setup advice. Do you recommend a starting setup for 17.5/13.5 for the Reedy race?
Thanks,
Kevin
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-22-2012, 08:57 AM   #4325
The image of TCX speaks for itself.It's obvious that the design is marvellous.Also, therefire I am sure it will be in great demand.Does anybody over here know its price?
I like the features of bateaux télécommandé
erricsimmons457 is offline   Reply With Quote
Old 05-22-2012, 05:09 PM   #4326
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Hiro, any word on the Hara TCX?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 05-23-2012, 02:07 AM   #4327
AGNO's Avatar
Thanks,
Hiro Kasuya
HB/HPI Team Manager
Yes, Hiro, there is a difference of offset holes, about 1.5 mm, I do not know what can effect on the handling, I found very similar ... slightly more reactive those in aluminum.
Old 05-23-2012, 08:15 AM   #4328
Thanks,
Kevin
Hi Kevin,
Unfortunately, most of our team drivers will not be at the Reedy race this year except Tyler Vik and JJ Wang. I'm sure they they will be happy to help you out. Please don't hesitate to stop by their pits and ask questions for setups!
As for the starting setup for the reedy race, i would recommend to start from the Hara's setup from last year. It would be good to start with.
I hope you will do well at there. Good luck!!
Hiroyuki Kasuya
HB/hpi Race Team Manager
Old 05-23-2012, 08:25 AM   #4329
Hello,
We are looking at middle of July for the release. Please give us little more time to wrap it up. We have very much confidence with the performance of the new car.
Old 05-23-2012, 08:35 AM   #4330
Hi AGNO,
First of all, i would like to thank you for your support as always.
Like you mentioned in your comment, there is a difference of offset holes about 1.5mm and the amount of the differece affects to the steering caracteristic A LOT. With the optimized asckerman setup on the new steering knuckles (#68796), you should be able to get more linear steering feeling which helps to put your car under the control while the car is cornering from entering through coming out of the corner.
Hope it helps.
Thank you.
Hiroyuki Kasuya
Old 05-23-2012, 02:34 PM   #4331
AGNO's Avatar
Hiro, thanks for the answer and explanation
Old 05-24-2012, 11:13 AM   #4332
theatriks's Avatar
Hey guys i want to buy a tcx touring car but im just curious to know if or when u guys think they might be coming out with there new model?
theatriks is offline   Reply With Quote
Old 05-24-2012, 03:49 PM   #4333
theatriks's Avatar
also does anyone know where i can get the hara tcx edition
Old 05-24-2012, 06:06 PM   #4334
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hello,
Theres your answer I dont think there will be a Hara Edition, The new car will be the TCXX
For those interested, New setup is on petitRc http://www.petitrc.com/reglages/hotb...tBodiesTCX.htm
The car was pretty good, I set the 3rd fastest lap time of the weekend, but the finals got rained out so didnt get to see how it was in racing. It was very easy to drive and had ton's of rear grip. I was struggling to achieve an optimum balance for steering and corner speed, so i am now experimenting with chassis plates again.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-24-2012, 07:56 PM   #4335
louielou's Avatar
Trader Rating: 16 (100%+)
Default TCX
Where can I find a website here in the USA that sells TCX split blocks, thinner top deck, etc.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
