Old 05-13-2012, 10:07 PM   #4306
Originally Posted by Yokomo_Ant3 View Post
The fundamental design is the same, but there are a lot of new parts on the car
Probably like how the associated does the tc6 and tc6.1 I assume?
zenkikid is offline   Reply With Quote
Old 05-13-2012, 11:15 PM   #4307
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Yes, but different sorts of changes. This has a lot more new parts than the TC6.1 got
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 05-14-2012, 07:43 AM   #4308
kentech's Avatar
http://hpi-express.com/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 05-14-2012, 12:35 PM   #4309
They mount straight on, it uses the wider holes and narrower holes on the chassis FR and RF mounts.
Send me your email and ill send you a setup. Will need more details about your car like chassis/top deck etc. Use a Mazda speed 6 shell
Re splited block so you need the 0 and 1 right? For front and rear?
speed6 is offline   Reply With Quote
Old 05-14-2012, 06:47 PM   #4310
correct
Antoni Caretti
Old 05-17-2012, 03:55 PM   #4311
Is there anywhere else I can get those split blocks? Specifically in the US?
Old 05-18-2012, 08:50 PM   #4312
Also, whats the asphalt/parking lot setup all of you would recommend?
Old 05-18-2012, 11:29 PM   #4313
Just bought them directly from their site. Service and price is great!
Old 05-19-2012, 04:33 AM   #4314
Bar
does anybody know of any better rod ends(ballcups) that can be used with the standard turn-buckles on the tcx as i don't like the amount of play you get on the hpi heavy duty ball cups which i now have on my steering as the original ones are useless?
Bar is offline   Reply With Quote
Old 05-19-2012, 06:34 AM   #4315
jag88's Avatar
I used Assoc. TC6/6.1 rod ends. They may be a little tight but once broke in they are very good. I've also used RPM rod ends.
jag88 is offline   Reply With Quote
Old 05-19-2012, 06:59 AM   #4316
Bar
i have used the tc6 ends on my servo to the centre and really like them, very little play but i found they were to short for the rest of the car and the RPM ones are to short for the steering
Old 05-19-2012, 07:02 AM   #4317
Bar
i also had the old schumacher grey ends on my steering which had very little to no play but again were to short as they were nearly coming off
Old 05-19-2012, 11:05 AM   #4318
A_Smith's Avatar
I used losi ones which removed all the slop from steering. I can't remember the part number though
A_Smith is offline   Reply With Quote
Old 05-19-2012, 11:06 AM   #4319
jag88's Avatar
Longer turnbuckles help with the Assoc. rod ends but RPM make different lenght ball cups.
Old 05-19-2012, 05:46 PM   #4320
AGNO's Avatar
I always use the original HPI / HB are great, if they develop a little play, is easily reduced by using a small drop of CA glue into the plastic uniball.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
SEO by vBSEO 3.5.0
