Old 05-05-2012, 10:22 PM   #4291
Originally Posted by AGNO View Post
I with modified engines, I always used standard spool and Pro D shafts, and I have never been broken, have always worked very well and wear was minimal, the use for over a year...
However, the Spec-R DCJ V2 look really good and can be mounted without any modifications.
I broke the front purple drive shaft and borrowed a buddies Yokomo steel front shafts and it was a tad shorter but worked great, thought I found a set steel drive shafts, don't look like those Yokomo steel shafts so I see here there's a Pro D shafts, who makes these shaft, any part numbers?, the ones I got look like the the stock purple not like the Yokomo steel ones, interested in this Pro D stuff and where to get them
Mahalos
mauimaxx is offline   Reply With Quote
Old 05-06-2012, 02:17 AM   #4292
It's drift parts made by HPI for the Pro 4. Very popular in Japan, not so easy to come across in the UK.
markrobinson is offline   Reply With Quote
Old 05-06-2012, 12:32 PM   #4293
Barry_Hughes's Avatar
In stock at Demon Products amongst others in the UK. It is a part for the drift car which is now available in the UK the TC-FD.
Only problem with them is the pin is larger than the pin on standard TCX or the TCX steel drive shaft. After buying a set I ended up buying the TCX steel ones!
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 05-06-2012, 09:50 PM   #4294
EJ20's Avatar
Mahalos
http://www.hotbodiesonline.com/products/en/68794.html
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 05-07-2012, 01:22 AM   #4295
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Here I was thinking my car couldnt get any better, then they go and do this
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 05-07-2012, 05:02 PM   #4296
When is it coming out?
speed6 is offline   Reply With Quote
Old 05-11-2012, 06:37 AM   #4297
I'm having trouble finding a few parts/part numbers:
The fr suspension mount in 1.5 deg also the split fr mount in 1 deg or 1.5 deg.........do they even make the split mounts?
Josh Hohnstein is offline   Reply With Quote
Old 05-11-2012, 10:55 PM   #4298
Anybody know where I can get a chassis protector?
zenkikid is offline   Reply With Quote
Old 05-11-2012, 11:15 PM   #4299
TopherCabrales's Avatar
Trader Rating: 47 (100%+)
Protect your investment.
TopherCabrales is offline   Reply With Quote
Old 05-12-2012, 06:44 AM   #4300
Airwave's Avatar
1.5 block:
http://www.hpieurope.com/piw.php?lang=en&partNo=75159m
splitted block are 3rd part manufacturer like Jet hobby...
http://jethobby.com/_shop/product/pr...tail.php?id=81
Airwave is offline   Reply With Quote
Old 05-13-2012, 12:40 PM   #4301
Is that TCX-X coming out just an updated chassis or is it a whole new car?
Old 05-13-2012, 03:15 PM   #4302
Originally Posted by Airwave View Post
But you will have to drill the chassis to mount the above right?
What tools are needed?
Old 05-13-2012, 03:42 PM   #4303
Dear all, could someone forward details re a good setup for very tight technical bumby parkinglot track.
I just got the Spec R diff and will try 800 shock oil
Re Body i have no idea what the get for such a track
Kindly help
Old 05-13-2012, 03:49 PM   #4304
RC MARKET's Avatar
Yes TCXX !
RC MARKET is offline   Reply With Quote
Old 05-13-2012, 07:28 PM   #4305
They mount straight on, it uses the wider holes and narrower holes on the chassis FR and RF mounts.
Kindly help
Send me your email and ill send you a setup. Will need more details about your car like chassis/top deck etc. Use a Mazda speed 6 shell
The fundamental design is the same, but there are a lot of new parts on the car
Antoni Caretti
SEO by vBSEO 3.5.0
