Old 04-30-2012, 03:28 PM   #4276
warnos's Avatar
Originally Posted by Yokomo_Ant3 View Post
http://www.hpieurope.com/news.php?la...sue=2012040301
You can see the new chassis plate there, Its the same one as the one they where using at TITC, but instead of the cutouts and 2.5mm, It has no cutouts and 2.25mm. Andy believes this was the right way to go. Pictured is also the new top deck plus all the other goodies. After more testing I have stuck with that top deck, seemed to be easiest to drive and give me the best lap times overall.
Antoni
I am a bit slow.. but from that pic it looks like Andy was running the two hole steering hubs rather then the newer three. Also the split blocks up front but not in the rear. Interesting.. I have them front and rear.. heard a few ppl doing this..
Also Ant how is the new chassis outdoors asphalt..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 04-30-2012, 07:09 PM   #4277
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Andy is still using Tamiya knuckles in that pic (same as 3 hole knuckle, but less lock). I think the Tamiya knuckles are also a harder carbon material than the HB ones.
Andy only runs split blocks in the front only to get more steering. I have tested this and It does give a tiny bit more steering than running them all round. The toe is a lot more consistant with the 1 piece block as the split blocks can move when tightening them and/or small hits. In high grip i'd probably recommend the 1 piece, for low the split blocks.
The new chassis is going great! It has a lot of flex underneath the motor and the car is very consistant to drive with, but still has good steering. My car generates a lot more traction aswell, compared to the kit chassis. Although mine is still a 2.5mm with the cutouts rather than the 2.25 non cutout one.
Ill be at Muchmores in a couple weeks, come see me and ill show you all the new stuff
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 05-01-2012, 12:18 AM   #4278
Barry_Hughes's Avatar
Originally Posted by TheCoolCanFanMan View Post
Hi Barry
Ive been runing the lower towers for indoors and wlrc, with silver silver springs amd 400m oil front and rear, maybe you shoukd try heavier oil,;as not sure what make you are running. i also run 3 hole 1.2 which make for a smoother pack
cheers Makc
Thanks Malc will give that a try
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 05-01-2012, 04:38 AM   #4279
Bar
hi Malc, I see you raced at the BRCA Clubmans at WLRC and I was wondering if you have you have a set-up from their including what bits you used which are not standard tcx bits i.e chassis, top deck, 3 hole hubs, new 3 pistons and any other bits that you used would be much appreciated.
thanks
Bar is offline   Reply With Quote
Old 05-02-2012, 01:06 AM   #4280
TheCoolCanFanMan's Avatar
thanks
Hi Bar
Yea car was awesome but never put a clean run in all day, hence 9th in the A, but did manage the fastest lap of the day at 15.27 :0) didnt have good finals either.
I was using
Spec R -2 lower shock towers
Spec R geard diff with yellow star Kinetic oil
Smokem chassis
3 hole steering hubs
Tamiya 1.2 3, hole pistons
Tamiya 46 steel driveshafts, but with Spec R axles, as the pin holes in the axles are a tad smaller, therfore next to no slop, and you dont have to have the grub screw in place as the spring clip holds the pin in place :0)
Purple ali 0 degree rear hub carriers
3 Racing purple rear body supports
Roche spool
2 degree FF & FR blocks
Thats all lol
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-03-2012, 02:49 AM   #4281
Bar
Hi Bar
I was using
Smokem chassis
Roche spool
Thats all lol
Cheers Malc
thanks Malc
Old 05-03-2012, 11:02 PM   #4282
Originally Posted by goots View Post
+1 switched to parma bumper and the front end breakage just stopped
Any part number or where or who has these bumpers.
mauimaxx is offline   Reply With Quote
Old 05-04-2012, 10:11 AM   #4283
Maxxican's Avatar
Trader Rating: 65 (100%+)
i also use the Parma bumper on both my TCXs and front breakage has gone down significantly... I buy the block and cut it wider than the stock bumper.
this is the one here
http://www.amainhobbies.com/product_...ltimate-Bumper
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NORTH AMERICA || SANWA
Maxxican is offline   Reply With Quote
Old 05-04-2012, 03:18 PM   #4284
Default New TCX recommendations
Hey people building my TCX and read almost all pages.
Will upgrade front CVDS to Pro 4 MIP
Shock pistons
Rear Spec R gear diff
Anything else. Also kindly advise setup for a very tight / bumby and dirty track.
Tyanks
speed6 is offline   Reply With Quote
Old 05-04-2012, 06:48 PM   #4285
Shock pistons
Tyanks
Get Spec R V2 DCJ driveshafts, not the pro 4 MIP's. They will just be a waste of money.
Antoni Caretti
Old 05-04-2012, 10:53 PM   #4286
Why? Actually I already have the parts from my spares of my old Pro 4 kit
Old 05-05-2012, 01:23 AM   #4287
warnos's Avatar
Tried MIP's in my car as I had heaps of them from the old cyclone and also the 46mm ones.. I munch the pin holes in about 2 or 3 runs.. they become way too elongated.. even in the rear when running a gear diff.. no good.
I use the spec r spring steel shafts and really like them.. heaps of others though even the steel HB ones if u want durability.
Old 05-05-2012, 01:28 AM   #4288
AGNO's Avatar
The pro 4 mip is good for 17.5 boost or 13.5 blinky, with modified motor are not strong enough
Yesterday I tested the Spec-R DCJ V2 with modified motor 5.5 T, work very well, very durable and nothing chattering
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-05-2012, 01:38 AM   #4289
For durability in the front I have found that the Roche spool and tamiya 46mm steel shafts are hard to beat.
I tried hpi pro d steel shafts and found them to be good but then the spool outdrives would break.
markrobinson is offline   Reply With Quote
Old 05-05-2012, 02:15 AM   #4290
AGNO's Avatar
I with modified engines, I always used standard spool and Pro D shafts, and I have never been broken, have always worked very well and wear was minimal, the use for over a year...
However, the Spec-R DCJ V2 look really good and can be mounted without any modifications.
