Old 04-05-2012, 11:50 PM   #4246
A_Smith's Avatar
That's how I got my steering sorted. Moved mine up to 130.
A_Smith is offline   Reply With Quote
Old 04-06-2012, 01:54 AM   #4247
AGNO's Avatar
Originally Posted by Yokomo_Ant3 View Post
You can always do what I have just done, I have dremeled 2 of my narrow chassis to be more like the new one (still not exactly the same as design has slightly changed) but its close
I too thought I use the dremel ...
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-06-2012, 02:17 AM   #4248
AGNO's Avatar
I use the servosaver Tamiya/3Racing, has a linkage greater than 1mm.
Using less EPA to achieve the maximum steering angle (90/95%)
Old 04-09-2012, 09:14 AM   #4249
ali_g's Avatar
Whats the latest update for the new TCX?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-09-2012, 11:14 AM   #4250
Barry_Hughes's Avatar
JUNE/JULY
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 04-09-2012, 05:28 PM   #4251
Don't know if this has been answered, 1st time on here. Is there another option front a-arms that will fit the TCX?, man it seems like a small hit and front arm breaks. I've heard another local guy mention there is another HPI arm that is stronger but he could not recall the part.
Any input on a stronger a arm besides stay away from the boards.
Thaniks
mauimaxx is offline   Reply With Quote
Old 04-09-2012, 05:44 PM   #4252
bukil's Avatar
Trader Rating: 37 (100%+)
Thaniks
Try these. If you use these arms, you will have less tuning options.
The one thing that helped me was to put a wider front bumper.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 04-09-2012, 06:13 PM   #4253
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thaniks
the arms from the Pro4 will work as well -they are the ones that came on the original Cyclones...
i've got to say, i've been very lucky with my TCX - only broke 1 arm in the year that I've run mine..and i've had some good crashes and brushes with cinderblock walls...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-10-2012, 01:16 AM   #4254
Trader Rating: 20 (100%+)
+1 switched to parma bumper and the front end breakage just stopped
goots is offline   Reply With Quote
Old 04-10-2012, 02:08 AM   #4255
AGNO's Avatar
The Cyclone/PRO4 arms work well on TCX, are also in the otions list
They have fewer regulations, are heavier, make the ride slightly less precise, but they are very resistant
I recommend the graphite arms http://www.hotbodiesonline.com/products/en/73506.html as hardness are similar to the arms TCX (TCX are harder)
The nylon arms http://www.hotbodiesonline.com/products/en/31420.html is very soft to be used exclusively on carpet and hig traction.
Old 04-12-2012, 05:27 PM   #4256
Thanks guys for the a arm info
Old 04-13-2012, 05:41 PM   #4257
bigblack's Avatar
im looking for a good setup for my tcx. running sedan on carpet. any help would be greatly appreciated!
Brandon
i tend to learn lessons the hard way.. man this is gonna get expensive.
bigblack is offline   Reply With Quote
Old 04-14-2012, 04:51 AM   #4258
ali_g's Avatar
Bump, need to get this thread back on P1
Just built up the new HB gear diff, I dont think this thing will EVER leak, has the biggest O-ring I have ever seen. The diff also has bearings in the case that the outdrives go through, hopefully it goes as good on track as it looks The new Top deck(s) work very well also, I used one of them on the weekend and my car was very good, probably the best its been apart from too much rear grip! Which caused a bit of understeer but hopefully I can get rid of that over the next few test days at the track.
Hopefully they release it all soon Exciting times ahead
Hi Ant,
How thick is the new top deck? do you need the cut the top deck?
☆ JU.C RACING ☆
Old 04-14-2012, 10:11 AM   #4259
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hi Ant,
The new top deck is 2mm. Out of all of the designs I have tried (tested a lot of custom, smokem, HB) topdecks, its definately the best one. You dont need to cut it.
Pretty much the only 2 top decks iI use now are the new one, or 2.5mm. The 2.5mm makes car way easier to drive, so I start with this especially when starting at a new track.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-14-2012, 11:39 AM   #4260
ali_g's Avatar
what about the lower shock towers? what are their effects ?
☆ JU.C RACING ☆
