Old 03-26-2012, 06:18 AM   #4231
John Doucakis's Avatar
Default TCX full option for sale
Hi guys.
I am selling my beloved TCX, chassis only but with all the options installed.
It has only run in three races with very little practice.
In total I would calculate that it does not have more than 25 runs in it and any worn out parts have been replaced.
The relative post is here:
HPI / HB TCX - FULL OPTION FOR SALE
John Doucakis is offline   Reply With Quote
Old 03-26-2012, 02:56 PM   #4232
warnos's Avatar
Originally Posted by j.d.roost View Post
http://www.arrowmax-rc.com/index.php...roducts_id=459
I assume the arrowmax ecs will work with the longer diff cups (or a locked one way).
Has anyone ordered from them...and how long does it usually take for the parts to come in?
Using them with the standard diff cups and they are pretty awsome.. Have to change one bearing in the hub which come with the shafts. I gather they would work with the longer diff cups but they are no longer needed when using these..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 03-30-2012, 01:20 AM   #4233
Originally Posted by John Doucakis View Post
Hi guys.
To anyone who already ownes a TCX, you may want to have a look at the list of spare and option parts I have for sale.
Please check this thread for the full list
Old 04-03-2012, 10:16 PM   #4234
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Bump, need to get this thread back on P1
Just built up the new HB gear diff, I dont think this thing will EVER leak, has the biggest O-ring I have ever seen. The diff also has bearings in the case that the outdrives go through, hopefully it goes as good on track as it looks The new Top deck(s) work very well also, I used one of them on the weekend and my car was very good, probably the best its been apart from too much rear grip! Which caused a bit of understeer but hopefully I can get rid of that over the next few test days at the track.
Hopefully they release it all soon Exciting times ahead
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-04-2012, 03:02 AM   #4235
warnos's Avatar
Default Gear diff
Want to get my hands on one of these diffs.. Bearings in the diff sounds like the way to go..
Come on hb release the diff already..
No-one needs help lately as their cars are so dialed
Old 04-04-2012, 10:02 AM   #4236
Hi,
For those using the 3 hole steering (HPI 68796) are you using full steering throw ? As I can't get that, or are you just using 100% EPA.
Thanks.
S.A.W is offline   Reply With Quote
Old 04-04-2012, 10:23 AM   #4237
A_Smith's Avatar
SAW I am struggling to get enough steering lock with the 3 hole arms as well. Hopefully some one knows a solution. Looking forward to the new parts being released and also the new TCXX. Hope it come with all the new parts that are being developed at the minute.
A_Smith is offline   Reply With Quote
Old 04-04-2012, 11:27 AM   #4238
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Marcel View Post
It's a Photon belt in front and a Serpent belt (front belt from a nitro car) in the rear.
Does anyone know the Serpent belt part#? Did you have to change the center pulleys?
I'm trying to fit a Yokomo gear diff in my TCX.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 04-04-2012, 11:29 AM   #4239
I don't know which parts they are, but we will have final samples (almost production spec) very soon. We have norrowed down to determine the production spec and almost ready to go.
They will be even better now. Stay tuned!
Hi-LowBlow is offline   Reply With Quote
Old 04-04-2012, 11:41 AM   #4240
AGNO's Avatar
One pics...
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-04-2012, 07:31 PM   #4241
Originally Posted by S.A.W View Post
Hi,
Thanks.
With the 3 Hole knuckles you cannot get full lock, its because the steering arms are too short. Thats why they have designed the new longer ones. They are 2mm longer and allow full steering throw. Just use the maximum steering lock you can with those knuckles, I have found it to be enough lock anyway (around 28d). With the new steering posts you can get up to 32d lock.
Also just a note for everyone on the new chassis on the TCXX, the steering rack and servo has been moved back 2mm, allowing for the same ackerman spacing as the old steering setup
Hiro,
The stuff I have is all from TITC still, so its definatly not final production stuff yet. I know the guys have already been testing new parts again since then
Originally Posted by AGNO View Post
One pics...
I can post pictures of the stuff, but its probably not worth it as I guarantee a lot of the production stuff will be different! I also forgot to mention they have been working on a new layshaft design with plastic pulleys! Think this is a much better design and it has no slop. And when the pulley itself wears out you can just put another one on (it locks onto the layshaft as it has a nut shape and the pulley just goes onto that)
Cheers,
Antoni
Antoni Caretti
Old 04-05-2012, 12:58 AM   #4242
AGNO's Avatar
Hiro,
Cheers,
Antoni
Ok, I'm just very curious
However, I also use the new knukle with three holes for a long time, I noticed a steering more predictable and consistent than those with two holes.
And I noticed no problems turning, even in very narrow tracks, normally I just use steering: about 22/25d, 32d seem very many
Interesting new layshaft, although I prefer the aluminum pulleys...
Regarding the frame, good changes, but they make old my new narrow chassis
Old 04-05-2012, 09:39 AM   #4243
Hiro,
Cheers,
Antoni
Thanks Antoni for the info.
Old 04-05-2012, 05:07 PM   #4244
You can always do what I have just done, I have dremeled 2 of my narrow chassis to be more like the new one (still not exactly the same as design has slightly changed) but its close
Antoni Caretti
Old 04-05-2012, 10:17 PM   #4245
Trader Rating: 20 (100%+)
Hi,
Thanks.
I had this problem too initially. I ended going above 100% epa on my radio to get more steering lock
goots is offline   Reply With Quote
