Old 03-16-2012, 07:06 AM   #4216
Originally Posted by S.A.W View Post
Hi,
What sort of ride height do people run on asphalt if its bumpy ? as most of the set ups I've looked at are for smooth tracks.
I also noticed that alot of the setup sheets on the front of the car people run 2mm shim at the front and the .75mm at the rear on the arms, why is this ?
Thanks.
I usually run 5mm at least on bumpy surfaces, 5.5 at the most. There are 2 things I notice when switching the front suspension shims front to back.
#1. You shorten the wheelbase of the car, increasing overall steering when going through turns.
#2. You change steering Ackerman. In this case, increasing initial steering making it a little more twitchy.
Realtek is offline   Reply With Quote
Old 03-16-2012, 02:19 PM   #4217
Hi,
I've got 1.5, 2.0 and 2.5 deg brackets for the front (FF) I've only used the 2.0 as this seems the most popular on the setup sheets. How does it effect the car changing these. All I know is it adjusts the inboard toe.
Thanks.
S.A.W is offline   Reply With Quote
Old 03-16-2012, 03:53 PM   #4218
Joven M's Avatar
Hi,
Thanks.
Going from 2.0 to 2.5 will sweep the arms back a little. As you increase arm sweep, you decrease initial turn in while increasing mid to exit steering.
2.0 to 1.5 will do the exact opposite.
ORCA USA / 1UP Racing / ActivRC
Joven M is offline   Reply With Quote
Old 03-17-2012, 02:01 PM   #4219
Barry_Hughes's Avatar
Default Exotek TCX-XS chassis
Anyone running one of these?
for ashpalt is it better than the Smokem chassis?
Thinking I might go ultra narrow chassis while wating for the TCXX to arrive, but not sure which way to go.
So any comments would be helpful, not only for me but also othet TCX users
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 03-17-2012, 08:39 PM   #4220
Trader Rating: 39 (100%+)
Just got a tcx going to be running mod touring i have a 112spur what is a good pinion size to start with. thanks for any help.
btown is offline   Reply With Quote
Old 03-19-2012, 05:37 AM   #4221
j.d.roost's Avatar
Trader Rating: 28 (100%+)
I messed around with the front upper camber links this weekend.
I noticed a HUGE change in rotation by removing a 1mm shim from the inner link (lowering the inner front link).
From what I can tell the car reacts to small changes. I would think this is a good thing.
I have two questions.
If I wanted the car to be more snappy (not snap loose mind you) around 90 and 180 corners. Should I experiment with shortening the front or rear of the car? I already messed with droop and car width and pretty much just need quicker rotation and less scrub off in speed mid corner,without making the car too loose.
What other things to try? From what I can tell the xrays at my local are KILLING me through the twisties (when I am not hitting things).
Also,does a one way work in this car? Pulley or diff? Are they legal at most tracks?
I am new to the t-car deal so please forgive any redundant questions.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-19-2012, 06:37 AM   #4222
TheCoolCanFanMan's Avatar
I am new to the t-car deal so please forgive and redundant questions.
you could try a little toe out on the front, maybe 1mm over all, but remember this will give you initial turn in but less to mid and exit speed, or try a 2.5 bar at the rear instead of the 3 degree stock one.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-19-2012, 08:12 AM   #4223
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Smokem chassis is spot on....one of the best cuts. Exoteks are okay.
Smokem will have a ton of traction.
I would go with a Smokem or wait on the TCXX.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-19-2012, 10:23 AM   #4224
First thing i would suggest is that move the front suspension arms to the front by moving the shims on the hinge pins. I would not suggest just to shorten the front camber link as it would take away overall front grip unless you try to make it balanced again by making other adjustments. However, the outter camber link position on the bulkhead is not a bad idea if you can balance it with other adjustments such as hinge pin width, shock positions, etc. We can reduce the tire heat a lot by using the outter hole.
For the problem you have, it would depnds if it's coming into the corner or coming out but i would try the shorter "rear" camber links but stay out side hole on the rear hubs. So outer hole on the rear bulkheads and outer hole on the rear hubs.
You can also remove the aluminum plate on the steering post (the one that is conncting side by side) to get some extra flex on the front. It should give you some more overall steering.
Hope it helps.
Hi-LowBlow is offline   Reply With Quote
Old 03-19-2012, 12:01 PM   #4225
Does anyone run the front Dampers Max Soft in the front with a Stiff Spring?
Jay105 is offline   Reply With Quote
Old 03-19-2012, 01:25 PM   #4226
wwddww34's Avatar
Trader Rating: 9 (91%+)
Tony Phalen drove a Hot Bodies TCX this last weekend when he won Champion in the Vintage Trans Am class at the 2012 ROAR Carpet Nationals. Tony used a Novak Edge ESC and Novak Ballistic 25.5 motor. He painted a 1969 Camaro Z28 body light blue and orange and the body won 2nd place in the Concourse.
Keep your eyes open for the article that Tony is writing about VTA for RC Driver Magazine. Also I wish Tony the best of luck in getting a VTA Race Club started at his local track in Southern California.
wwddww34 is offline   Reply With Quote
Old 03-19-2012, 03:13 PM   #4227
Hi Barry
Im running the Smokem chassis now, but not tried it out doors yet, but was a vast improvement on the wide TCX chassis
Old 03-25-2012, 08:47 AM   #4228
j.d.roost's Avatar
What is the advantage/disadvantage to the way the hing pins are mounted (one piece front and rear mounts) as to the newer cars (x-ray,6.1,top) with the individual f/r/l/r. Why did most everyone else do away with this style of mounting? Is this just older technology or is there a specific reason that hpi uses it?
F1
Roche usa
R.I.P. Jon Williams
Old 03-25-2012, 09:15 AM   #4229
AGNO's Avatar
What is the advantage/disadvantage to the way the hing pins are mounted (one piece front and rear mounts) as to the newer cars (x-ray,6.1,top) with the individual f/r/l/r. Why did most everyone else do away with this style of mounting? Is this just older technology or is there a specific reason that hpi still uses it?
Really the old solution is that the cars you mentioned (6.1 really old ...) Tamiya, Yokomo and HB using pivot system, allows the suspension to be released from bulkheads and offers the possibility of various combinations like this:
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-26-2012, 06:04 AM   #4230
j.d.roost's Avatar
http://www.arrowmax-rc.com/index.php...roducts_id=459
I assume the arrowmax ecs will work with the longer diff cups (or a locked one way).
Has anyone ordered from them...and how long does it usually take for the parts to come in?
F1
Roche usa
R.I.P. Jon Williams
