Old 03-10-2012, 08:07 AM   #4201
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Korey Harbke View Post
I have been told by a little birdie around June/July. That is a very tentative release though, so don't hold me to that. Hope everyone has been doing well. I'm slammed with school and finishing up my degree. I'm graduating in June!
-Korey
summer!? were talking about the hara tcx right?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 03-12-2012, 05:18 AM   #4202
TChan's Avatar
Send a message via Skype™ to TChan
Does anybody know where I can get setup sheets for the TCX for different tracks?
TChan is offline   Reply With Quote
Old 03-12-2012, 05:31 AM   #4203
Coldn's Avatar
Send a message via MSN to Coldn
Hello!!
somebody tested the Top Photon universal cvd to use with rear diff SpecR?
I'm thinking to use because the hb blade is to hard to find, and very weak. and others brands sell a package with many blades, and hb sell only 1.
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-12-2012, 06:22 AM   #4204
tomracing's Avatar
Originally Posted by Coldn View Post
Hello!!
spec-r also has blades for HB drive shaft in bulk package(4pair):
http://www.spec-r.com/default/index....b34b983c2bc6f6
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 03-12-2012, 08:17 AM   #4205
Coldn's Avatar
you save my life!!
Nanotech 6000mah
Old 03-12-2012, 12:01 PM   #4206
Barry_Hughes's Avatar
try herehttp://www.petitrc.com/reglages/hotb...tBodiesTCX.htm
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 03-13-2012, 10:05 AM   #4207
Hi,
What does everyone set their length of shock too ? I need to get more droop but finding the shock too short.
Thanks.
S.A.W is offline   Reply With Quote
Old 03-13-2012, 02:09 PM   #4208
Originally Posted by S.A.W View Post
Hi,
Thanks.
64.5mm if i need more droop
markrobinson is offline   Reply With Quote
Old 03-13-2012, 02:58 PM   #4209
bukil's Avatar
Trader Rating: 37 (100%+)
Hi,
Thanks.
Are you using the low shock tower mounts?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 03-13-2012, 03:44 PM   #4210
No standard ones. Do the lower ones allow a lot more droop at the standard shock length ?
Old 03-13-2012, 04:48 PM   #4211
TV
The low shock towers are 2mm lower, so if you keep the shock length the same, you'll have more droop.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
Old 03-13-2012, 05:36 PM   #4212
bukil's Avatar
Yes.
☆ ActivRC ☆
Old 03-15-2012, 07:37 AM   #4213
Originally Posted by Ooj View Post
The thickness of the shims on the sway bar holder is a fine tuning aid for the angle of the sway bar holder. Angle also fine tunes the stiffness of the bar. Most people try to run it as vertical as possible but when you change the wheel base it will also affect the angle of the standard sway bar holder. if you go larger than 2mm as the gap, you should use a longer ball stud as the standard one is not that big.
Hi,
Do you mean keeping the roll bar level when looking from the side of the car ? So you would change the shim thickness depending on the ride height ?
Thanks.
Old 03-15-2012, 06:18 PM   #4214
Korey Harbke's Avatar
The main reason is to move the piston further up in the shock body. this reduces the volume of oil on top of the piston, which reduces the amount of "pack". When you reduce the "pack", it makes the car roll more and generally makes the car float around the corner more.
I generally find the car rotates much harder with the lowered towers, but can make the car more unstable. This is probably due to the more aggressive weight transfer and body movements.
Give it a try and see how you like it! If you like a more stable car, the standard shock towers might be more your style.
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-16-2012, 06:40 AM   #4215
Hi,
What sort of ride height do people run on asphalt if its bumpy ? as most of the set ups I've looked at are for smooth tracks.
I also noticed that alot of the setup sheets on the front of the car people run 2mm shim at the front and the .75mm at the rear on the arms, why is this ?
Thanks.
