Old 03-06-2012, 09:55 AM   #4186
j.d.roost's Avatar
Trader Rating: 27 (100%+)
What is the fastest/best way to get off power (turn in to early apex) steering into this car?
I have a loaner and don't know the current setup...but can tell you it has no sway bars/front spool/rear gear diff.
I have the option to run a front ball or gear diff but want to hold off on that if I can (like the feeling of the spool).
Thanks.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-06-2012, 03:39 PM   #4187
RaceAce701's Avatar
Trader Rating: 83 (99%+)
narrower front hexex 4mm with a .5mm spacer is wat i use and it helps turn in
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 03-06-2012, 06:05 PM   #4188
Trader Rating: 28 (100%+)
So im new to on road, just built a tcx with a 17.5 tekin and love it! Today I was testing indoors on carpet which was the second day on the kit. Everything ran smooth and then out of nowhere my car was making a nasty vibration noise when the car was turning on moderate power. It was fine in a straight line, or turning on full power. I took it apart and inspected everything cvd pins, uprights, spindles, hinge pins, front gear, outdrives, and drive shafts and nothing helped. My first thought was a cvd pin was coming out but they were fine. Any suggestions on what it could be, or how to fix it? Thanks.
TDI793 is offline   Reply With Quote
Old 03-06-2012, 08:10 PM   #4189
bukil's Avatar
Trader Rating: 37 (100%+)
Try this - no need for set screw or if you can find these coupled with this, it will even be better.
Hope this helps.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 03-07-2012, 01:09 AM   #4190
Thanks.
You need roll bars, the car is pitching to much so your losing steering. If you go to the ball of GD at the front you will gain some steering but lose drag from the corners, stick with the spool.
Have a look at my setup from this weekend gone. I would have made the A main bar for some 'help' from other drivers in all my qualifying runs
http://www.ukrcracer.co.uk/phpBB3/do...file.php?id=47
You will need to save this to you desktop and open it. Bare in mind I like ALOT of steering input, so i do run softer front springs to rear. You can balance this by puting silver or gold at the front to take some bite out of it. Also note this is with the smokem chassis, but this is not far off what i'd uise on the standard kit chassis.
Jo90uk is offline   Reply With Quote
Old 03-07-2012, 01:47 AM   #4191
AGNO's Avatar
Hope this helps.
+1
Use the DCJ is possible go with R-Spec modified diff with this http://www.spec-r.com/default/index....roducts_id=235 work very well with 17.5
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-07-2012, 08:19 AM   #4192
j.d.roost's Avatar
This car has the smokem chassis too.
I will give the bars a shot this weekend (thanks).
Btw...can't dl your setup.
I get this.
"You are not authorised to download this attachment"
F1
Roche usa
R.I.P. Jon Williams
Old 03-07-2012, 01:13 PM   #4193
transplantlife's Avatar
Trader Rating: 43 (98%+)
Any word when the TCXX is coming?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 03-07-2012, 11:36 PM   #4194
Korey Harbke's Avatar
I have been told by a little birdie around June/July. That is a very tentative release though, so don't hold me to that. Hope everyone has been doing well. I'm slammed with school and finishing up my degree. I'm graduating in June!
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 03-08-2012, 10:08 PM   #4195
I have some setup/general questions about this car. I have it setup as a 17.5 blinky and and struggling with the rear of the car. Im running on an indoor carpet track with medium to high bite, on the HPI 30c tires, using traction compound. Im struggling with lateral rear grip in high speed corners, and rear grip on power. My car is descent to drive for about 4-5 minutes and then the rear grip falls of drastically to the point that I cant drive it. I have tried everything with setup and dont know where to go from here. Is this just a trait of these cars? Here is my setup, any suggestions are greatly appreciated!!
Camber- -2 front and rear
Ride height- 5mm front and reat
droop- 9 front 9.5 rear
shock oil- 47.5 front and rear
springs- pink front, blue rear
shock length- 64mm front and rear
Bars- black front gold rear
Shock tower position- third hold from inside front and rear
lower position on arm is outer front middle rear.
long wheelbase in the rear
Old 03-09-2012, 12:09 AM   #4196
Camber change it to -1.5 front and 2.5 rear
droop- change it to 9 front 8.5 rear
shock oil- change it to 35 front and rear
springs- change to silver front, silver rear
shock length- change it to 63.5mm front and rear
What is your camber link position in rear?
Hi-LowBlow is offline   Reply With Quote
Old 03-09-2012, 09:16 AM   #4197
Tyres overheating ?
S.A.W is offline   Reply With Quote
Old 03-09-2012, 09:17 AM   #4198
How are you all measuring droop with a digital vernier ? I know how to use/measure with it but a pic would be a great help.
Thanks.
Old 03-09-2012, 09:45 AM   #4199
Thanks for the replies. I have tested at my indoor track trying to gain speed and get a handle on the setup for the last three days and have made minimal improvements. I measure the droop by putting the chassis on a flat surface and measuring from the table to the center of the outer hinge pin. Not sure if this is right or not, but how someone at the track showed me.
The tires overheating is for sure a problem in the rear and probably why it falls off so drastically in the rear. Right now I am running the HPI 30c tire and our indoor series will have a spec sweep32c. Is there a big difference in these tires, our shop has not gotten them in stock yet.
I started with the kit setup, and moved to what I posted a few posts ago. From that setup I have tried 27.5, 40, and now the 47.5 on shock oil. For me it feels like the thicker the oil the better it feels. I have also moved to the from pink front springs and blue rears, to silver front blue rear to take some steering away. Shock length was the only other thing I played with yesterday, started with minimum shock length with the ball end all the way screwed on the shaft, and moved to 64mm front and rear which didnt seem to make a huge difference. Also my camber links are in the number two position.
Thanks again for the replies and the help, it is greatly appreciated. This is my first on road car and how no idea how critical the setup is on these cars!
Old 03-09-2012, 10:10 AM   #4200
Xpress's Avatar
Thanks for the replies.....
PM sent
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
SEO by vBSEO 3.5.0
