Old 12-21-2011, 07:39 PM   #3961
Originally Posted by John Doucakis View Post
I uploaded a video from our annual National Cup race.
all info here:
Hi
Have read in your set up , that you use the news steering knuckles , but what about chassis,top plate and the shock towers
thanks andy
HB-forever is offline   Reply With Quote
Old 12-22-2011, 12:50 AM   #3962
John Doucakis's Avatar
Originally Posted by HB-forever View Post
Hi
thanks andy
Hi Andy,
HB Narrow chassis felt great but to be honest have not tested back to back with standard or Smokem that I have. If I get a chance I will do so.
Top plate is std kit, not the optional one.
Shock towers are also standard. I am not convinced yet I need the lower version and I hate the look of the front shock tower with the middle body post holes.
John Doucakis is offline   Reply With Quote
Old 12-22-2011, 10:48 PM   #3963
Trader Rating: 20 (100%+)
Originally Posted by unknownmember View Post
Are there any HB DCJs alternatives? They just don't last, I should of taken a picture before I threw them out. Basically the cross pin snapped and in the process it ripped through the highlighted bit.
Uploaded with ImageShack.us
They lasted about 10 packs, which is a bit of a bummer. I didn't expect it to break so quickly coz I only drift with my TCX. Tho I do run a 3.5T....
here's how mine broke. 17.5 boosted class
goots is offline   Reply With Quote
Old 12-23-2011, 10:41 AM   #3964
ShaunMac's Avatar
YIKES!!! I've been running the same set of DCJ's for years with a spool and now with a putty filled gear diff. They are a little slopped out, but feel smooth on the track. How long did you get out of it before it let go?
ShaunMac is offline   Reply With Quote
Old 12-23-2011, 01:16 PM   #3965
Maybe about 7-8 months. I've cleaned and grease them everyother raceday. Been running it with the spool when it gave out. I bought 2 extras and very noticable play with old vs new.
I also run a gear diff with putty and a little oil now so to put less strain on the drivetrain.
Old 12-23-2011, 02:45 PM   #3966
Trader Rating: 15 (100%+)
Send a message via AIM to DJGonzo69
If anyone is interested Im selling my 2nd TCX. It has all the new updated parts.
HOTBodies TCX- with New Chassis/Shock Towers
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 12-26-2011, 07:36 AM   #3967
Bubblehead's Avatar
all info here:
John, did you drill a hole in your spur gear? Are you removing your top deck to adjust your gear mesh?
Bubblehead is offline   Reply With Quote
Old 12-26-2011, 08:59 AM   #3968
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
not answering for him...but i know I've found it easier to remove the top deck to adjust the gera mesh...
I run 17.5 blinky with mine, so i normally have 100T or less in mine - and even the one 100t I have with the holes (like the stock one), i still can't easily adjust the gear mesh...one screw is always 'just outside' where i can reach with my wrench
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-26-2011, 10:36 AM   #3969
Correct that is how I adjusted it by removing the top deck but I do not recomend for frequent ratio changes as all the trouble ain't worth it. For me it is OK as I only race at tracks that require same FDR.
Main reason I chose these spurs is that being black they always look clean...
Old 12-26-2011, 01:48 PM   #3970
JamesHealey's Avatar
I'm thinking of getting a TCX how does it fair against the Schumacher Mi4?
Jim.
JamesHealey is offline   Reply With Quote
Old 12-26-2011, 02:42 PM   #3971
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default Compare
Jim.
Funny I just ordered a MI4CX....just to test setups...
but I will say my HB TCX is the best car I've ever had...and for those who know me...I've tried them all.
the TCX is the most stable and predictable car to drive.
Responds to the slightest changes (good in my book)
you won't need much as far as option parts.
steel front bones. is a must.
and HPI spring set.
that is all you'll need for a starting base.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 12-26-2011, 04:27 PM   #3972
Bubblehead's Avatar
I'm going to drill a hole in my spur gear, I hope it works.
Old 12-26-2011, 04:41 PM   #3973
ShaunMac's Avatar
Try a ball-end 2mm wrench. It works fine on my 100T spur and I don't have to remove the topdeck to set the mesh.
Good luck.
Old 12-26-2011, 04:46 PM   #3974
RaceAce701's Avatar
Trader Rating: 83 (99%+)
Jim.
just go with the tcx its a fantastic car to drive and easy to setup i love mine best car i ever drove it makes me feel like im a better driver than i am
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 12-26-2011, 05:29 PM   #3975
warnos's Avatar
Ordered a set of Spec R spring steel HB 46mm swing shafts for the front of the car.
What are people experience with these running a spool compared to say the exotek ones?
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
