Old 12-11-2011, 05:19 PM   #3931
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Smokem chassis
just wanted to throw out a word on the Smokem chassis.
Couldn't find the HB lipo chassis...so I decided to buy the Smokem chassis.
cut quality is fantastic, everything lined up perfect.
Gave the car a bit more steering, felt very planted. I thought the chassis would create a traction roll problem but worked very good on mid-high bite carpet
The original chassis was good but this makes the car feel more direct.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 12-11-2011, 08:30 PM   #3932
granty110's Avatar
Hi this is my first time on this tread I just pick up the tcx and just want to know what are the do and the don't whit this car and what I should get to make it work to It's full potential.thanks in advance .
Thanks to all my sponsors Barnstormers Raceways Team/ Mugen Seiki Racing /Novarossi /Bruckner Hobbies / Team Epic / Phat Skeemz Paints / Redline Hobbies NY / Freds Auto Repairs / Hitec / FT KNOX RC PARK/Race AKA
Rohan Grant
granty110 is offline   Reply With Quote
Old 12-11-2011, 08:48 PM   #3933
olhipster1's Avatar
Originally Posted by granty110 View Post
Hi this is my first time on this tread I just pick up the tcx and just want to know what I are the do and the don't whit this car and what I should get to make it work to It's full potential.thanks in advance .
you won't need much to get this car working great. The car is great out of the box.
probably
2.5, 1.5, 1.0 toe blocks
spring set
3 hole pistons
front steel bones (must get these)
optional
lower shock towers
gear diff
that's pretty much it...
CAUSE and EFFECT
Old 12-12-2011, 06:42 AM   #3934
granty110's Avatar
probably
spring set
3 hole pistons
optional
lower shock towers
gear diff
Ok thank you much I will getting some run time on the car this Wednesday so I will see
Rohan Grant
Old 12-12-2011, 10:51 AM   #3935
Hi,
What do the 0.5deg and 1.0deg pivot blocks do handling to the car when mounted front rear or rear front ? what surface are they best used for asphalt/carpet ?
S.A.W is offline   Reply With Quote
Old 12-12-2011, 01:05 PM   #3936
olhipster1's Avatar
Originally Posted by S.A.W View Post
Hi,
What do the 0.5deg and 1.0deg pivot blocks do handling to the car when mounted front rear or rear front ? what surface are they best used for asphaly/carpet ?
I would like to know that one also.
I was waiting on new blocks to come in to test it out.
CAUSE and EFFECT
Old 12-13-2011, 08:24 AM   #3937
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
did you try the split blocks jet racing makes??
more importantly - are you going to be at horsham for the slowbirds?? i wanna finally meet you face-to-face I think I know who are
where did you get the smoke'em chassis from?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-13-2011, 10:11 AM   #3938
olhipster1's Avatar
I haven't gotten my hands on a set of Jet racing split blocks. need to order a set for sure. Next thing on my X-mas list.
I ordered the chassis direct from Smokem
http://www.smokem-racing.com/Home.html
Believe I will make it to the SlowBirds this year. I am sure our paths have crossed before. Looking forward to meeting.
CAUSE and EFFECT
Old 12-13-2011, 11:03 AM   #3939
k_bojar's Avatar
yeah, we've been out to horsham and jackson at the same time a few times orlando, right?
Old 12-13-2011, 11:15 AM   #3940
k_bojar's Avatar
and are you running all the screws in the top deck? I know I removed a couple to make some better rear traction outside - haven't run mine inside on carpet yet
Old 12-13-2011, 11:56 AM   #3941
olhipster1's Avatar
Yes...It's Orlando
with the original chassis. I removed 2 screws from the rear, everything else installed.
the biggest changes from outside to carpet was the roll centers. removed all shims under the rear blocks.
0.5 shims in the front.
with the Smokem chassis, decided to run all upper deck screws. Chassis produces more flex but very even front to back.
CAUSE and EFFECT
Old 12-15-2011, 11:41 AM   #3942
LIUK82's Avatar
Default new car for 2012?
new car for 2012?
LIUK82 is offline   Reply With Quote
Old 12-15-2011, 06:15 PM   #3943
granty110's Avatar
probably
spring set
3 hole pistons
optional
lower shock towers
gear diff
Thank you I will be on the track on Sunday to do some test run I let you know how things go
Rohan Grant
Old 12-17-2011, 02:52 AM   #3944
Trader Rating: 20 (100%+)
anyone want to sell me a roll of purple strapping tape? It seems it's sold out everywhere.
goots is offline   Reply With Quote
Old 12-17-2011, 04:36 PM   #3945
halfempty's Avatar
Does any one run the 6 hole pistons on carpet? or are they more for asphalt?
halfempty is offline   Reply With Quote
