Old 12-06-2011, 12:34 AM   #3916
AGNO's Avatar
Originally Posted by unknownmember View Post
I must be doing something wrong. But I will give the steel ones a try. My only concern is chatter, but if the steel ones have less that's awesome.
The steel CVD have a little chatter, but they are more strong, to reduce it a little, advice to remove the set screw and use the universal axle pin cover http://www.hotbodiesonline.com/products/en/68759.html
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-06-2011, 05:42 AM   #3917
unknownmember's Avatar
Originally Posted by AGNO View Post
.......remove the set screw and use the universal axle pin cover
Thanks dude, I've made use of the method in the past but unfortunately doesn't do much. Definitely reduced the chatter effect but when I use the normal uni drive I have to tone down the turning travel to at least 65% to completely eliminate the chatter. Which is fine when i'm messing around on a non technical track but anything else that extra 35% of travel makes a huge difference. Should just get myself a TT01 again lol, coz as much as I can remember the TT with the stock dog-bone setup didn't chatter at full lock what so ever and it sure as hell didn't cost $30 odd bucks to replace each corner and it had a 5.5T with a spool at both ends.
unknownmember is offline   Reply With Quote
Old 12-07-2011, 12:46 AM   #3918
Hi,
Does anyone make any specific lipo holder's for the TCX other than the the kit (67841) (5) ? at the moment I'm using 4 (67841) (6), two by the belt and two at either end.
Or will this be on a new chassis
S.A.W is offline   Reply With Quote
Old 12-07-2011, 06:55 AM   #3919
18SS's Avatar
Send a message via MSN to 18SS
Default some one must know !!!!
so the HB TCX only give the option of the spurs in the range of 110T - 116T
what other spur gears will fit the TCX?? will xray/AE/any other companies??
and for a 17.5 rubber BOOSTED class what spur and pinion should I run?
right now i have a 115t spur and a 34t pinion.
18SS is offline   Reply With Quote
Old 12-07-2011, 02:09 PM   #3920
Fjeld's Avatar
Xray will fitt, I am driving it now and have done it for a year or so, you will onley be abel to fitt 2 screws but that is OK
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 12-07-2011, 03:22 PM   #3921
Trader Rating: 20 (100%+)
FDR of 6.0-6.5 should gve a good range for 17.5 boosted
110-113 spur should get you in that range
I currently running a 113 spur and 35 pinion 6.30FDR 17.5 D3
goots is offline   Reply With Quote
Old 12-08-2011, 06:22 AM   #3922
18SS's Avatar
im at the moment running the 115 spur and a 34 pinion and that gives me a fdr of 6.60 but i will switch to the 36 pinion and that gives me a fdr of 6.23
another question with 17.5 fully boosted should i run a heat sink and a fan on the motor or will it not get to hot??
Old 12-08-2011, 03:57 PM   #3923
depends on what your temping now. I run a fan and heat sink just for extra cooling. If you run a fan, make sure you get a good one.
Old 12-08-2011, 07:51 PM   #3924
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I've run as small as 90t in my TCX...right now running a 100t - forget who makes it...i think i got it from speedtechrc
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-09-2011, 08:28 PM   #3925
question... I am actually working on building the new CEFX evo sedan and it uses a sliding rack steering system like on the AE TC3, I know that the Tamiya 416/417 steering system fits but I would rather run the Hot Bodies one. I just don't know the spacing between the two pivots and the length of the steering arms part HBS68735 http://www.amainhobbies.com/product_...eering-Arm-Set
If someone could help me out with those measurements that would be appreciated, thanks.
avink007 is offline   Reply With Quote
Old 12-10-2011, 09:17 AM   #3926
stokka's Avatar
Originally Posted by b_recliner View Post
Yes they will.
If everything seems under control, you're just not going fast enough. - Mario Andretti
stokka is offline   Reply With Quote
Old 12-10-2011, 10:10 AM   #3927
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Same width as the 416.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 12-10-2011, 12:43 PM   #3928
ShaunMac's Avatar
Distance between the two pivot mounts is ~29mm. Length of arms ~17.5mm.
These measurements are from center of screw to center of screw.
ShaunMac is offline   Reply With Quote
Old 12-10-2011, 01:12 PM   #3929
Thanks for the help
Old 12-11-2011, 05:16 PM   #3930
Bubblehead's Avatar
Default Upgrades/ Hop-ups
I'm thinking of putting my TCX back on the track, what upgrades or hop-ups should I think of buying?
Bubblehead is offline   Reply With Quote
