Old 12-02-2011, 02:13 PM   #3901
Hi,
What's the advantage of using the 3 hole steering hubs ?
S.A.W is offline   Reply With Quote
Old 12-02-2011, 05:20 PM   #3902
spring71's Avatar
Smile
Spec-R Gear diff for TCX and parts are restocked at TQ.
Click Here
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 12-02-2011, 05:46 PM   #3903
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hello guys
Any advice on base setup for a very low grip asphalt outdoor track ?, this is the layout (70x30mts) :
thanks !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 12-02-2011, 08:26 PM   #3904
mac853's Avatar
Questions??
Could somebody give some setup advises of running on painted concrete School basketball ground with TCX, please?
Best regards
mac853 is offline   Reply With Quote
Old 12-02-2011, 10:37 PM   #3905
Trader Rating: 10 (92%+)
why don't you 2 guys run the kit setup for now?
And LEARN how to set up a car by reading the xray setup book, which you can download online. It applies to all cars, not just xray's.
This is the only way in which you will learn.
captain stacker is offline   Reply With Quote
Old 12-03-2011, 11:35 AM   #3906
Tabushi's Avatar
Captain "nice person",
In my case, i was only asking for tips on low traction tracks, my car is well set up but im looking for that little extra, thanks for your "non help",
regards,
Old 12-04-2011, 04:42 AM   #3907
Airwave's Avatar
With low grip, your car will need to take more roll...
So to do that, you can remove the spacer between the chassis and the pivot blocks... How much do you have?
Mixing setups is the worse thing you can do...
Airwave is offline   Reply With Quote
Old 12-04-2011, 07:59 AM   #3908
mac853's Avatar
Thumbs up
Nice idea, thanks!
Old 12-05-2011, 12:51 AM   #3909
What droop setting would you use or would you stay the same as before?
colin storey is offline   Reply With Quote
Old 12-05-2011, 06:30 AM   #3910
unknownmember's Avatar
Are there any HB DCJs alternatives? They just don't last, I should of taken a picture before I threw them out. Basically the cross pin snapped and in the process it ripped through the highlighted bit.
Uploaded with ImageShack.us
They lasted about 10 packs, which is a bit of a bummer. I didn't expect it to break so quickly coz I only drift with my TCX. Tho I do run a 3.5T....
unknownmember is offline   Reply With Quote
Old 12-05-2011, 10:06 AM   #3911
AGNO's Avatar
The DCJ HB are among the most durable on the market, my DCJ have two years..., with a 3.5T and high steering angles any double cardan break easy...
For a 3.5T recommend the steel CVD
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-05-2011, 10:19 AM   #3912
What's the difference between the standard knuckles, the newer 3 hole one's and using Tamiya ones ?
Old 12-05-2011, 11:05 AM   #3913
AGNO's Avatar
The behavior of the steering is less nervous and more predictable, are very similar to the Tamiya but do not require shims.
Old 12-05-2011, 12:09 PM   #3914
Tabushi's Avatar
+1 on that tip !
Old 12-05-2011, 04:24 PM   #3915
I must be doing something wrong. But I will give the steel ones a try. My only concern is chatter, but if the steel ones have less that's awesome.
