Old 11-26-2011, 01:30 PM   #3886
Trader Rating: 20 (100%+)
Originally Posted by Zooberg View Post
Any one now if hot Bodies have wheel wasers?
Like this?
I don't think they sell the washers seperate. HB has a thin wheel hex with spacers as a whole set.
goots is offline   Reply With Quote
Old 11-26-2011, 09:30 PM   #3887
18SS's Avatar
Send a message via MSN to 18SS
Default NEW
hey guys i am a offroad racer here up in Canada. I live out of toronto and am getting into onroad. im a Hot bodies guy i race the D4, D8, D8T so im going to try onroad. im getting a TCX within the next week.
im going to be running on carpet.
i have my sorax 32s with soft inderts
a LRP SXX TC spec version 1
with a LRP 17.5 brushless
and a proto foam r9 body
can u gus give me some of the following.
where I can get ofter market parts
what parts should i get spars or upgrades for
where i can get a wide range of spur gears from other then HB
and out of the build when running a 115t spur what pinion should i start with?
PMing me is the best way for me to get your info
thanks and please from everyone
everything is welcome
18SS is offline   Reply With Quote
Old 11-27-2011, 01:35 AM   #3888
Okey Thanks. Now any art nr?
Other brands have wheel spaces?
Zooberg is offline   Reply With Quote
Old 11-27-2011, 01:07 PM   #3889
ShaunMac's Avatar
Tamiya, XRAY, Schumacher, 3Racing and TOP all have wheel spacers.
I've been using the ones included with the thin HB hexes for years.
ShaunMac is offline   Reply With Quote
Old 11-28-2011, 11:12 AM   #3890
Hi,
Should the screw in the top deck above steering assembly (68735) always be used ? the maual shows it installed but on the HB site under chassis flex options they don't show it at all
What's the best way to balance the car, I'm used to an xray chassis which has holes for the balancing tool.
Where can I get the purple shock spring nuts (30004) and a purple belt tensioner.
Thanks.
S.A.W is offline   Reply With Quote
Old 11-28-2011, 05:33 PM   #3891
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by S.A.W View Post
Hi,
No this dosent have to be used, I dont think many of us run this ever, just the steering brace actross the two bellcranks.
I wouldnt worry too much about balancing your car, i havent done it for a long time now. But if you wanted to roughly see, get a piece of string and put it inbetween the shock tower grooves through the car.
Just try and find some aftermarket ones, 3racing and TOP make these items
Thanks.
There ya go
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 11-28-2011, 05:45 PM   #3892
b_recliner's Avatar
Trader Rating: 22 (100%+)
Will these work?
http://www.amainhobbies.com/product_...ollar-Purple-2
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-28-2011, 05:50 PM   #3893
Originally Posted by b_recliner View Post
Not sure, why not just get the Purple HB version?
Antoni Caretti
Old 11-28-2011, 05:52 PM   #3894
b_recliner's Avatar
Where can I find that at?
Old 11-28-2011, 11:14 PM   #3895
i got mines from rcmarket. HPI30004
Old 11-29-2011, 06:25 AM   #3896
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
Hey Antoni,
I just ordered the seperated Jet Hobby FR blocks. Got the 1 and 1.5 degrees. Have you tested both of these? What FF blocks did you use? I have heard that these wider seperate blocks and less sweep make the front a bit more settled while giving more and smoother on power steering?
Ooj is offline   Reply With Quote
Old 11-30-2011, 03:42 AM   #3897
Originally Posted by Ooj View Post
Hey Antoni,
Yea I am using the Jet blocks, they are fantastic! Better quality aluminium than the standrd parts for sure! I have used the 0 on rear and both 1 and 1.5 for the FR. I use 1.5 and 2 FF blocks. Yea it smoothens the car out a lot and makes it more consistant through a corner. The arm sweep does give more high speed steering, but overall I prefer no sweep.
Antoni Caretti
Old 11-30-2011, 05:50 PM   #3898
Trader Rating: 17 (100%+)
Just a couple quick questions about changing the toe blocks (Front Arm Sweep) in the front of the car. If I change the front block from 0 degree to a 2 degree block, the steering should be more aggressive? Is that also called adding outboard toe out or inboard toe out?
Thanks for any clearification or pointing me out to where I can get this clearified.
429racer is offline   Reply With Quote
Old 12-01-2011, 02:43 PM   #3899
Hi,
What's the kit setup like for carpet ? or is best to start with one of the others on Petitrc.
Thanks.
Old 12-02-2011, 12:18 AM   #3900
Mindux00's Avatar
Default TCX for sale
Hi there,
a good deal if you are looking for HB TCX
HB TCX and lots of parts
Kyosho MP9 TKI2,
O.S. XZ-B Speed, Hara Edition
O.S. Speed T-2090SC Tuned Pipe Set
Sanwa M12
Mindux00 is offline   Reply With Quote
