Old 11-15-2011, 05:43 AM   #3856
RaceAce701's Avatar
Trader Rating: 83 (99%+)
Well thanks for all the advice guys i just re rebuilt the car last night and all I found was a bent rear iner hinge pin. All the bulkheads look good. I did swap out some screw tho just because as well as swapped the front and rear bulkheads hoping to maybe move the problem I am wondering If I have a main deck or a top deck issue
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 11-15-2011, 08:05 AM   #3857
portyansky's Avatar
Trader Rating: 54 (100%+)
Doing research for my buddy. What things must be done right away so he doesn't have issues off the bat.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 11-15-2011, 09:46 PM   #3858
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
the only thing is probably change the front bones to steels....for a new driver.
extra pivot blocks for setup changes.
other than that..nothing...kit comes fully loaded.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-16-2011, 03:27 AM   #3859
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
Has anyone tested with gear diffs front and back in mod? I'm particularly interested in low turn mod (4.5-6.5t) on asphalt. I'm trying to see if it is any smoother or faster while on power in slow-medium corners.
Ooj is offline   Reply With Quote
Old 11-16-2011, 04:47 PM   #3860
Mickey Silver's Avatar
I dunno if anyone here has tried yet but I took my TCX over to a friends place and we fitted a front steel drive shaft from the Serpent TC and it fits very nicely.
http://www.amainhobbies.com/product_...iveshaft-Set-2
Havnt tried the car yet, but will let you know as soon as I do.
Tim
Little bit of this... little bit of that....
Mickey Silver is offline   Reply With Quote
Old 11-18-2011, 11:45 AM   #3861
M3Armand's Avatar
Default HB DCJ Driveshafts For Sale #67699
I have 2 DCJ driveshafts for sale. There are unused and are new in the bag. PM me if you're interested!
M3Armand is offline   Reply With Quote
Old 11-18-2011, 03:11 PM   #3862
Trader Rating: 20 (100%+)
Is tuning with ackerman on this car totally track specific. Ie technical vs open flowing track.
I've been trying to read on how ackerman works but it still confuses me. Any tips or advice before I start playing with the shims on the bellcrank?
goots is offline   Reply With Quote
Old 11-18-2011, 03:47 PM   #3863
ShaunMac's Avatar
More washers = Less Ackerman change- aggressive feeling - better in 180's
Less washers = More Ackerman change - smoother feeling - better in flowing sections
ShaunMac is offline   Reply With Quote
Old 11-18-2011, 04:25 PM   #3864
Thanks. So the kit setup is neutral at 4mm. Most of the setups I have seen is either untouched or has less washers. By having less ackerman change with say 4.5 or even 5mm on the bellcrank can there be any negative effects to the car?
Old 11-18-2011, 05:03 PM   #3865
ShaunMac's Avatar
You have to be sure you know what steering blocks are being used when you read a set-up sheet. The new HB blocks are longer so you take out washers to keep the same ackerman as before. Between 0 - 2mm is what I use depending on how the car feels.
Some like more ackerman some like less. Add 2mm and see how it feels. Then take out 2mm and compare. After you experience it on the track for yourself you will have a better idea of when to make an ackerman change.
Old 11-20-2011, 09:13 AM   #3866
Hi,
looking to change cars and the TCX has been out a while, is there a new version out soon ? before I spend my 's on a old model
Thanks.
S.A.W is offline   Reply With Quote
Old 11-20-2011, 04:55 PM   #3867
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by S.A.W View Post
Hi,
Thanks.
There was a new kit for the asian market i believe that had some of the new parts. Not sure if it is available anymore. The car from the box is good but does require a few option parts
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 11-21-2011, 10:33 AM   #3868
Just picked up a second hand one with quite alot of extra's including the new thinner chassis, top deck and 3 hole steering hubs.
What chassis/top deck is best for low traction asphalt ?
Anyone got a good base set up for low traction asphalt ?
What do the 3 hole steering hubs do over the standard and do I need to change anything on the ackerman to compensate ?
Anything else I should know about the car ?
Thanks.
Old 11-21-2011, 11:42 AM   #3869
Hi
Can you please tell what parts is needed ?
best regards
Andy
HB-forever is offline   Reply With Quote
Old 11-21-2011, 01:24 PM   #3870
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by HB-forever View Post
Hi
best regards
Andy
the biggest - steel from CVD bones (46mm steel)...which are now made by exotek and HB/HPI
nothing else is hughly required to make this car go good well, aside from skill
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
