Old 11-10-2011, 10:03 AM   #3841
Trader Rating: 16 (100%+)
Originally Posted by frk View Post
Hi Guys!
I would like to know if it is useful to put the caster to 6 (on carpet track) as commonly used with rubber wheels or sponge wheels .
Hara, Moore and company seem to have abandoned this solution in their setup on carpet.
What do you think about ?
I tried 6 degree caster blocks on my local carpet track (NorCal Hobbies). It lacked the turn in to make fast laps. It was good on middle and exit of corners but the lack of turn in was hard to overcome. I was persistant and tried many changes but went faster with the 4 degree caster blocks on my car. Perhaps on a bigger more flowing layout they may pay off. YMMV.
I also heard Hara-san saying something about only using them when he has some anti-dive in the car when we talked at the last Reedy.
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-10-2011, 05:37 PM   #3842
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
On my previus car (Xray) I used 6D blocks and it worked quite well. I was using Anti-dive, and also a front gear diff with a bit lighter oil. This worked really well and was fast. Havent tried it on the TCX yet but in higher traction conditions the spool is usually faster
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 11-12-2011, 07:49 PM   #3843
ShaunMac's Avatar
Can someone confirm this please.
Hot Bodies has no 46mm DCJ's for the TCX.
Spec-R has no DCJ's period for the TCX.
I'm using the HB 44mm DCJ's with the long cups and it seems to work well. My concern is damage to the cups as the DCJ's are still a tad short for my taste. Any other alternatives available?
ShaunMac is offline   Reply With Quote
Old 11-13-2011, 02:01 AM   #3844
Joven M's Avatar
I'm assuming your using the POM outdrives and yes they are delicate against big hits. If you don't like using the steel ones, Im using a locked up spec r gear diff up front with plastic blades on my dcj. I was told that they sell a locking kit for it. I just used epoxy in my gear diff to lock it up.
ARC USA / Team Integy/ Maclan-Racing / Xpert / Blitz / ActivRC
Joven M is offline   Reply With Quote
Old 11-13-2011, 07:52 PM   #3845
RaceAce701's Avatar
Trader Rating: 83 (99%+)
ok going to ask a vague question here
i have 2 tcx's both are stock and the setups are completley identical
17.5 blinky in both if it matters carpet track med low bite (but it does the same thing on high bite carpet as well as asphault)
one its absolutlety perfect the other is a complete pile i have no rear traction at all (on power off power and neutral power) and no matter what i chance nothing seems to fix it (i tried bodies,tires, springs front track width, roll centers, shocks (from the good car) wheelbase setting and ever different style arms and nothing) thay help a little but they just seem to mask a bigger problem.
the car used to work fine the all of a sudden one week after a regular tear down and rebuild it was like a entirely different car and not in a good way
has anyone had a similar problem or can direct me to part to check for a possable bent something
thanks its just a bit frustrating
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 11-13-2011, 09:21 PM   #3846
Trader Rating: 20 (100%+)
So I'm over the spool diff. I cracked the coupler for one of my DCJ axles. So now Ill be running dual gear diffs in the car. How heavy weight oil is everyone using up front?
goots is offline   Reply With Quote
Old 11-13-2011, 09:28 PM   #3847
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
bent bulkhead, maybe?sure you don't have the chassis tweaked when you re-assembled it, alex??
I've had my TCX and TC act similar to that - but found out the settings were just a bit off
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-13-2011, 09:30 PM   #3848
k_bojar's Avatar
i've used putty and 300k oil..I just ordered the bits to turn a gear diff into a locked spool
Old 11-13-2011, 10:32 PM   #3849
Hi
Just my way to aviod those problems , I ALWAYS change all screws in chassis after a tear down. It's almost impossible to see if one is bended. I buy a box with 200 pieces at a time , have never really liked the titanium ones
HB-forever is offline   Reply With Quote
Old 11-13-2011, 11:05 PM   #3850
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Hey,
try checking the pivot blocks ...my car felt awesome for a while then went down hill.
found that the pivot block was slightly bent made the car do little weird things.
also I've been going thru outer bearing like crazy.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-13-2011, 11:31 PM   #3851
olhipster1's Avatar
Default Steering knuckless
need a little help...tried searching on here.
1. what do the new steering knuckles do? main benefit.
I put on Xray knuckles to see if I will get a different steering feel.
had to take a shims off from the steering rack.
prior had 4mm on the rack (standard knuckles).
now have 1 mm on the rack (Xray Knuckles)
I am trying to get a bit more steering out of the car.
overall the car is very easy to drive
but need more snap into a turn without losing predictability.
2. front pivot blocks.
what is the effect of changing the front pivot blocks? low number versus higher number.
any help would be appreciated.
CAUSE and EFFECT
Old 11-13-2011, 11:46 PM   #3852
Suspended
Trader Rating: 4 (75%+)
selling my tcx chassis
tcx chassis
tryandfok is offline   Reply With Quote
Old 11-14-2011, 12:04 AM   #3853
Where can I buy this?
MrKahunaXD is offline   Reply With Quote
Old 11-14-2011, 12:19 AM   #3854
Try Tamiya knuckles with 2mm ackerman, this is what works best for us down under. We generally always use 1.5 susp mounts ff and fr and steering is pretty damn good.
Antoni Caretti
Old 11-14-2011, 11:58 AM   #3855
1.) I was told the scrub radius was different/better. As I am not smart enought to know what that is, (LOL) I just nodded my head. They are much smoother around center than the old steering knuckles. Less twitchy.
2.) Agressiveness. My car was much more agressive through turn with 2.5 than with 1.5. 1.5 felt pretty dead.
Art
SEO by vBSEO 3.5.0
