Old 10-04-2011, 01:15 AM   #3736
AGNO's Avatar
Originally Posted by goots View Post
Hb multidiff is a direct fit to 44mm DCJ. No modding. Works perferct. I've been running this setup since I got the car.
Yes, that's right, I forgot, even the multidiff. works well with 44mm DCJ, only it's a bit heavier than the standard spool, Spec-R spool and the multidiff are same weighs , but the operation of Spec-R spool is even smoother, even if the blades wear out quickly...
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-04-2011, 03:50 PM   #3737
mazmo's Avatar
Default Front spool / axle chatter
Hey guys,
Am getting a lot of chatter in the front, would welcome any suggestions to get rid of it.
My TCX has Roche spool & yokomo 45.5mm driveshafts / TCX axles.
Should I go back to standard spool & steel 46mm exotec drive shafts?
Am running the car in mod BL 4.0T
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 10-04-2011, 04:42 PM   #3738
Trader Rating: 20 (100%+)
Originally Posted by mazmo View Post
Hey guys,
DCJ will eliminate most of the chatter. Has to be run with multidiff, spec r gear diff, or use hb long axle cups. Or you can run less steering lock and try to compensate with tuning the front end of the car.
goots is offline   Reply With Quote
Old 10-04-2011, 04:43 PM   #3739
steveonamission's Avatar
Hey guys,
Steel pin against steel outdrives will always cause chatter l'm afraid.
The POM outdrives should improve the situation a little. Though chatter isn't always a bad thing, especially in modified, helps slow the car down
steveonamission is offline   Reply With Quote
Old 10-05-2011, 12:26 AM   #3740
AGNO's Avatar
Hey guys,
When using the CVD 46mm steel HB originals, eliminating the screw pins and using the pin cover, the chattering decrease more, if using the new POM out drive decrease further, but for MOD, I prefer the standard steel out drives with steel CVD, this combo is very durable.
Old 10-05-2011, 02:30 PM   #3741
transplantlife's Avatar
Trader Rating: 43 (98%+)
Anything new coming for 2012 for the tcx?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 10-05-2011, 03:08 PM   #3742
AGNO's Avatar
2012 version already exists...
New chassis, new shock tower, new pivot, new spindle and more...
Old 10-05-2011, 03:26 PM   #3743
Thanks ANGO for the reply..
Old 10-06-2011, 10:12 AM   #3744
Suspended
Trader Rating: 86 (100%+)
selling my tcx with exotek
tcx with exotek chassis, tekin rs, lipo
littlealex is offline   Reply With Quote
Old 10-06-2011, 11:49 AM   #3745
Fjeld's Avatar
Can you give me a link to a page how is selling the 2012 edition??
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 10-06-2011, 02:16 PM   #3746
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i don't believe there's a kit per say, but there are parts out for 2012
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-06-2011, 02:22 PM   #3747
jag88's Avatar
Maybe if Hara wins Vegas they'll come out with a special edition with all the parts in one kit .... maybe ... no pressure Atushi .... lol
jag88 is offline   Reply With Quote
Old 10-07-2011, 03:48 PM   #3748
Fjeld's Avatar
I know that it is VERY much option to this car, and I want all of it, but I realy hope they will come with a new kit with all of the new parts and a gear diff and steel driveshafts as standar
Old 10-07-2011, 04:32 PM   #3749
Velocitygt's Avatar
TCX with plenty of goodies up for sale guys. Cheers
Hot Bodies TCX x 2 Kits + Heaps more
Velocitygt is offline   Reply With Quote
Old 10-08-2011, 02:33 AM   #3750
spencehotbodies's Avatar
Default tcx for sale
How much?
spencehotbodies is offline   Reply With Quote
