Old 10-03-2011, 05:55 AM   #3721
Dog Bone's Avatar
Originally Posted by AGNO View Post
Very disappointed...
Attachment 815725
Used with 44mm DCJ and 17.5 DCJ booster, unfortunately, DCJ are still short, the new out drives are useless .
We need 46mm DCJ .
Those bent bits of steel were these
http://hotbodiesonline.com/products/en/68769.html
Really? If a 17.5 can do that, what will a 13.5 do? What will a lower turn motor do?
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Old 10-03-2011, 06:19 AM   #3722
AGNO's Avatar
Yes, are those, and the engine was an old Novak SSpro 17.5
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-03-2011, 07:05 AM   #3723
hi-tech-redneck's Avatar
Default in stock
att. the part i've been waiting for is finally in stock at the hot bodies website=68796 front spindle/rear hub carrier,of course i announce it after i made my order!
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 10-03-2011, 08:42 AM   #3724
jag88's Avatar
Attachment 815725
We need 46mm DCJ .
WOW ! What did you hit and how many times did you hit it ?
46mm DCJs would be great.
jag88 is offline   Reply With Quote
Old 10-03-2011, 09:16 AM   #3725
Dog Bone's Avatar
If that damage occurred simply due to engine torque, then yes, those out drives are completely useless.
Wonderful.
Ken Miller
T4 2015
CRC Twenty5
Old 10-03-2011, 09:38 AM   #3726
masterhit's Avatar
Trader Rating: 15 (100%+)
Wonderful.
I have about 20 runs on mine with the 44mm DCJ with zero issues and barely any wear. I have ran both 17.5, and 17.5 boosted on a tight mid-west 4"x4" & PVC good bite carpet track.... And I have definitely had some scary hits!
In fact, here is last weeks main, my car is the purple/pink/green...
+ YouTube Video
Mike Slaughter
masterhit is offline   Reply With Quote
Old 10-03-2011, 10:38 AM   #3727
AGNO's Avatar
Wonderful.
I do not think depends on the torque, I think depends on the brakes, I used FR +1 and with this configuration the head of shaft works very on the edge of out drive, when braking, the suspension is compressed and the head of shaft escapes and breaks the out drive...
I'm not a super driver, but I drive pretty well, I have not given us great shots
However, for me the best solution would be to DCJ 46mm
Sorry for my bad English
Old 10-03-2011, 01:26 PM   #3728
jag88's Avatar
Put about 3mm of spacers on the shock shaft on the OUTSIDE of the shock. This will limit the amount of compression and keep the dog bones and blades from pulling out while still allowing the car to roll.
46mm DCJs are still the correct answer to this problem.
Old 10-03-2011, 03:00 PM   #3729
AGNO's Avatar
Up stop in the shock of could be a good idea...
The only trouble-free use of DCJ, I've had with the differential Spec-R also excellent used as a spool with the appropriate conversion.
Old 10-03-2011, 04:34 PM   #3730
masterhit's Avatar
Ah! I can definitely see how that could be a problem with the +1 blocks.
I was getting ready to try the + blocks this coming weekend, thanks for the information!
At one point they mentioned 46mm DCJs. I wonder if they are still coming?
Mike Slaughter
Old 10-03-2011, 06:35 PM   #3731
LOSI123's Avatar
Trader Rating: 63 (100%+)
Does the TCX come with steel front spool outdrives? or POM plastic as the website says.
LOSI123 is offline   Reply With Quote
Old 10-03-2011, 08:32 PM   #3732
Dog Bone's Avatar
Mine came with steel.
Ken Miller
T4 2015
CRC Twenty5
Old 10-03-2011, 08:39 PM   #3733
Korey Harbke's Avatar
It's a typo. They come with Steel outdrives that are pretty solid. The broken set just shown is the first I've seen of the new ones. I've been running the extended POM outdrives and noticed they seem much more durable than they previously were in the shorter versions (not sure why).
I do remember a few years ago at the ROAR paved nationals I had a problem running DCJ's, wider blocks and lots of sweep on the cyclone TC. I broke a set of the steel outdrives and made everyone go OOOOOO and AHHHHH at my part shattering capabilities . I ended up taking the DCJ's out and running normal universals and the issue never came up again. At this time we didn't have the extended outdrives though.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-03-2011, 11:48 PM   #3734
Trader Rating: 20 (100%+)
Attachment 815922 Attachment 815925
Hb multidiff is a direct fit to 44mm DCJ. No modding. Works perferct. I've been running this setup since I got the car.
goots is offline   Reply With Quote
Old 10-04-2011, 12:20 AM   #3735
AGNO's Avatar
I-Korey
Yes, that's right,the new out drives POM are much more durable, but the problem with DCJ is identical to steel out drive, are too short.
The new out drive POM are great for use with the original CVD 46 mm very durable and chattering very little, does not exist.
