Old 09-25-2011, 06:22 AM   #3691
Trader Rating: 20 (100%+)
Originally Posted by Baldyno5 View Post
Subaru Impeza Type C body is now available in UK from Demon Power Products.
patiently waiting US release........
goots is offline   Reply With Quote
Old 09-25-2011, 06:28 AM   #3692
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ditto....
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-25-2011, 01:06 PM   #3693
It is available on hb web site.
Hi-LowBlow is offline   Reply With Quote
Old 09-25-2011, 01:28 PM   #3694
Airwave's Avatar
Has somebody already tried the new 6-holes pistons ?
I think it could make my car more agile on small technical track... But I've no clue about the oil grade I can start with...
Any idea about that?
Thanks...
Airwave is offline   Reply With Quote
Old 09-25-2011, 01:51 PM   #3695
AGNO's Avatar
Thanks...
I'm using with excellent results on small track and large, use Much more oil 500cps front and rear
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 09-25-2011, 03:19 PM   #3696
Korey Harbke's Avatar
Yup, just type in "Type C" in the search box and it pops right up. The web guy just hasn't added the parts in their respective "places" on the optional parts page.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-25-2011, 07:38 PM   #3697
jag88's Avatar
Thanks...
anybody know the diameter of the holes ?
Thanks.
jag88 is offline   Reply With Quote
Old 09-25-2011, 07:41 PM   #3698
omarwashington's Avatar
While building the car, I found it interesting the front to be a one-way front. Thinking to myself how is the car going to turn that? Would this driving style be for those that like to swing the rear end or drift the rear end in turns?
RCCARS!
omarwashington is offline   Reply With Quote
Old 09-25-2011, 07:51 PM   #3699
hi-tech-redneck's Avatar
Originally Posted by Korey Harbke View Post
Most likely not. Usually when something new is put on the website it still takes a little more time for all the information and inventory status to be put in. Just give it some time. Hiro is doing his best to inform those who take care of the website for everyone so they re easily accessible.
-Korey
wow still shows 68796 as back order been checking every day! i guess there just out?
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 09-25-2011, 11:30 PM   #3700
Thanks.
Still 1.1mm. The diameter of the newer pistons is increased in comparison to tamiya or the older HB pistons. They fit SUPER SUPER DUPER AWESOME in the shock body. Little to no fluid will pass over the edges of the pistons. It will mainly be focused through the piston holes. They seem like they fit a smidge tight, but DO NOT sand the pistons. They smooth out when oil is introduced into the shock .
6 hole pistons are great on tracks where there is a good mix of different kinds of corners. They let the car flop around a little more at low speed, and pack up really good in high speed chicanes and such. They seem really effective on higher grip tracks!
Old 09-25-2011, 11:32 PM   #3701
As for Oil... We actually run fairly thin because the "pack" is more pronounced. It sounds funky, but you'll understand more when you actually try them. I started with Losi 35wt as per Hiro's suggestion, and settled on 37.5wt. Some people have run thicker from what I've noticed, but losi oil runs pretty thick for what it is.
Old 09-29-2011, 12:15 PM   #3702
jag88's Avatar
Korey (or Hiro) would these pistons be a good choice on a car with the new 2mm lower shock towers ? I run on a 90 x 36 carpet that as the night goes by the grip comes way up.
I was thinking that maybe it would be too aggressive (?).
17.5 blinky.
Thanks.
Old 09-29-2011, 07:26 PM   #3703
I like that. "Or Hiro". It makes me feel way cooler than him :P
I'd try them. I know Ty used 1.2mm 3 hole pistons at Carpet Nats, and the traction was still really high. I feel these make the car feel smoother than the 6 hole pistons, but I still feel the 6 hole pistons are worth trying . And yes they are good with the lowered towers.
-Korey
Old 09-29-2011, 10:23 PM   #3704
LOSI123's Avatar
Trader Rating: 63 (100%+)
Hey guys are there steel drive shafts for the front or rear of this car made by HB that direct fit no mods?
LOSI123 is offline   Reply With Quote
Old 09-29-2011, 11:03 PM   #3705
Jamesalex's Avatar
Thumbs up
LOSI123,
There are two options
The Hotbodies ones 68794 - UNIVERSAL DRIVE SHAFT 46mm (STEEL/46mm/1pc)
Or
The HPI 88914 - Steel Drive Shaft Pro D 46mm (2 pcs)
www.cmcc.org.uk
www.mmrflux.co.uk
www.hpiracing.co.uk
www.hotbodiesonline.com
Jamesalex is offline   Reply With Quote
