Old 09-23-2011, 12:22 PM   #3676
Trader Rating: 17 (100%+)
Originally Posted by jag88 View Post
Korey, it sounds like we're saying the same thing. Would you agree ?
If so, then with a 1.5 degree FF block and a +1 degree FR block any guess as to how the .5 degee remaining angle is divided ? 1/2 on a side or 1/4 degree on a side ?
Thanks.
I find all of this a bit confusing. I would think that the remaining .5 degree would be split equally (.25 degree) per side. As I have not actually measured the parts...it is only a educated guess.
I believe .7mm or .8mm is equal to 1 degree so if you have the blocks can you measure to clarify?
Thanks.
Art
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-23-2011, 01:40 PM   #3677
Fred Hubbard's Avatar
Hi Hiro, Korey and Art
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-23-2011, 03:38 PM   #3678
jag88's Avatar
Thanks.
Art
Yea, I'm confused too. I'm sorry I don't have the blocks, actually I was hoping someone could clarify this before I bought them. Degrees or millimeters and resultant angles ... I'm sure someone will figure it out.
jag88 is offline   Reply With Quote
Old 09-23-2011, 07:02 PM   #3679
Here you go again. lol
Originally Posted by Hi-LowBlow View Post
Hi jag88,
I think the number "0.5+" and "1.0+" on the new FR/RF blocks are for "mm" not for degrees. So 0.5+ is simply 0.5mm wider than the stock block and 1.0+ is 1.0mm wider.
The combo "1.0+" FR w/1.5deg FF that you mentioned is not the same as the 1.5deg blocks combo as the hinge pin width (center to center)on the "1.0+" block is 43mm while the 1.5deg block is 44mm. If you need to widen the hinge pins to 44mm, you still need to use the 1.5deg block on FR. We are also making wider than "1.0+" so we can just simply throw it in without any modification.
Hope it helps.
Hi-LowBlow is offline   Reply With Quote
Old 09-23-2011, 07:03 PM   #3680
Talking
Hi Fred!
Old 09-23-2011, 07:17 PM   #3681
jag88's Avatar
Hi jag88,
Hope it helps.
Originally Posted by Korey Harbke View Post
As far as I know, they are rated in additional degrees. Think of the normal FR and RF blocks as "0". using a +1 deg block will make it the same as a 1 deg toe block. They just don't require any grinding to install, which is pretty neato.
-Korey
lol ... sorry Hiro, but when the two great 'HotBodies experts' are contradicting each other then it's time to step back and wait ... lol
Thanks.
Old 09-23-2011, 07:29 PM   #3682
Korey Harbke's Avatar
To be perfectly clear, I didn't say what I said was absolute fact... Just that as far as I know, they were rated in what would be equivalent to the degrees on a block. I don't have my equipment with me where I live during school, so I can't measure and do some math to confirm for you. Hiro would most likely know more than myself, because he is directly involved in research and development. It's honestly just something I have never thought or worried about when it comes to tuning the car, so I don't have a for sure answer to give everyone.
As far as how much toe on each side, I'm pretty sure if the toe block says 3 deg, its 3 deg per side. A quick check would be to look at 3 deg of camber, then compare that to 3 degrees of rear toe. If it were truly only 1.5 per side, the wheels wouldn't look so aggressively toed in like they normally are. But again, I don't have any of my equipment to confirm that.
Hopefully that clears some things up, or helps some.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-23-2011, 07:36 PM   #3683
Sorry for the confusion. But +1 FR block is 43.00mm which is 1mm wider than the stock one. "+1" is not rated for degree, it's simply 1mm wider.
Thanks.
Old 09-24-2011, 06:33 AM   #3684
jag88's Avatar
-Korey
Thanks.
Thanks guys, the world is right again ..... lol
Old 09-24-2011, 03:02 PM   #3685
omarwashington's Avatar
Originally Posted by goots View Post
How heavy diff oil is everyone putting in their gear diffs?
gear diff? I thought it only had ball diff
RCCARS!
omarwashington is offline   Reply With Quote
Old 09-24-2011, 05:19 PM   #3686
Gear diffs are made by a company called Spec-R. It's an aftermarket option that some people like. The ball diff that comes in the car is very good, and I still say everyone should try it before moving to a gear diff .
-Korey
Old 09-24-2011, 09:29 PM   #3687
Trader Rating: 20 (100%+)
-Korey
I second that. The pro spec diff in the TC was just perfect. Now that I have the TCX im gnna compare laptimes and handling ball vs gear w/ 1k n 3k oil.
To be honest I dont know how a gear diff can be any better than a well built ball diff.
I also have been reading some posts in the Spec R gear diff review thread and honestly it looks like more maintenance than a ball diff. Oil leaks and stripping gears are my concern.
goots is offline   Reply With Quote
Old 09-24-2011, 09:39 PM   #3688
Talking
Ball diff with ceramic balls and loctite last forever, weigh less, and can handle a lot more power than gear diffs ! I guess manufacturers wanted to sell something different than ball diffs, and got some to switch, but not me ..
bertrandsv87 is offline   Reply With Quote
Old 09-24-2011, 09:53 PM   #3689
Send a message via AIM to DJGonzo69
I've had my gear diff on the rear first & a spool on the front since May. Did not have any issues with gears. I even bought an exta pair of gears since Ive heard of people stripping the gears. They are still in the package. I used Associated 80wt which is close to 1000cst. I felt the rear tracked better on the start compared to my ball diff. Im not the best when builing the ball diff, so the gear diff helped alot in this area. About 2 months later I picked up a gear diff for the front. I'm using 500K Kyosho oil. I noticed alot of turn in once I switched to the gear diff on the front. I ranthe gear diffs through 17.5 & Mod 5.5 motors. About 2 weeks ago was the first time I opened up my rear gear diff & added alittle bit of oil. Did not see any wear on the gears. So Im happy with it. So my own experience is very little maintenance. I'm picking up a second set for my new TCX.
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 09-25-2011, 04:10 AM   #3690
Baldyno5's Avatar
Smile
Subaru Impeza Type C body is now available in UK from Demon Power Products.
Baldyno5 is offline   Reply With Quote
