Old 09-14-2011, 11:27 PM   #3616
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Teddy View Post
What is the effect on the car handling by using the outer hole? (on rear hub)
Did they use this solution only for carpet?
Personal preferance really. Hara generally always uses outer hole, at the same race Andy used shorter rear link inside and outside! so just try it and see if you like it. Long rear link should be a touch harder to drive, but have more corner speed. Short link has more mid corner steering and the car should be easier to drive
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-15-2011, 09:08 AM   #3617
Is it not the other way around? It is on a tamiya
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 09-15-2011, 09:32 AM   #3618
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
The car is easier to drive with the outside hole on the hub, gives more on throttle steering (less camber gain), more corner speed etc. That is what they have been using for asphalt also.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 09-15-2011, 10:10 AM   #3619
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
The carbon weave on Hara's chassis looks nice.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 09-15-2011, 10:19 AM   #3620
rx7ttlm's Avatar
Funny your in meth valley? Smells like weed here... lol. Hara chassis is schweet. Pretty sure not hot bodies tho lol.
Old 09-15-2011, 10:58 AM   #3621
Hi, ,guys great thread, i┤ve been reading it for a while now. I hope someone can help me with this. Today I went to my lhs for a bottle of 35wt shock oil. The guy gave me a bottle of 350 weight (hot bodies brand). The obvious question is. Are they both the same or did the guy take me for a fool. Thanks in advance.
goyoloco is offline   Reply With Quote
Old 09-15-2011, 11:26 AM   #3622
Oils measured in hundreds should be equivalent across different brands but the old 'wt' measurement wasn't so the 350 could be equivalent to anywhere between 25 and 45 of your old oil. I'm sure if you mention your old brand on here someone could link you to a chart so you can get a better idea
markrobinson is offline   Reply With Quote
Old 09-15-2011, 11:29 AM   #3623
Thanks Mark, The old brand is actually hpi an the new one is hot bodies, the thing is that i checked it on the web and hot bodies does not go under 250 with it┤s shock oils.
Old 09-15-2011, 12:16 PM   #3624
Dude, its a dang valley of drugs here. Went to Eugene last week to pick up my Volkswagen, it wasn't that bad, just lots of weed (College, lol) I feel like Portland is better than both these places.
Old 09-15-2011, 06:31 PM   #3625
Not from what i have found, Hara also said the same thing to me at TITC
Antoni Caretti
Old 09-15-2011, 10:12 PM   #3626
Suspended
Trader Rating: 86 (100%+)
how much rebound do you guys use on your tcx?
littlealex is offline   Reply With Quote
Old 09-15-2011, 11:40 PM   #3627
Hiro, help us!
moraccio is offline   Reply With Quote
Old 09-16-2011, 01:01 AM   #3628
rx7ttlm's Avatar
Start with 0 rebound...
Old 09-16-2011, 05:21 AM   #3629
hi-tech-redneck's Avatar
what aftermarket chasse is that in the pic?the 2 piece fr and rf blocks look cool, i want one of those! i heard someone said it was german made anyone have any info on it?
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 09-16-2011, 06:37 AM   #3630
Hi,
it's no aftermarket chassis produced in great numbers.
I designed this chassis last september and got the first three prototypes ready for the ETS Opener in Kastellaun/Germany.
I switched to this chassis already in the training heats and had a pretty good feeling because grip and balance (improved position for the heavier 6200 LRp Lipo) have been much better compared to the kit chassis.
After taking a close look at the performance of my car, Freddy and Dominik (the german HB Teamdrivers) also switched to "my" chassis an used it since then
At this years ETS final in Andernach, Hara and Andy had a look at my chassis and i asked Hara if he would test the chassis for me and give me some feedback and his opinion about the chassis... (You just need a world class driver to get really good test results....)
Looks like the perfomance of the chassis is even better than i expected ...
regards
Marcel
Marcel is offline   Reply With Quote
