Old 07-27-2010, 05:25 AM   #346
Originally Posted by Dusttt View Post
I see Tower Hobbies dropped the preorder price from $549 to $499 over the weekend. Must mean they are getting closer.
Can we expect lower price, like $470 on arival date or that's it?
tomislav is offline   Reply With Quote
Old 07-27-2010, 03:54 PM   #347
Hello guys,
I thought i should share some tips for the TCX building with you guys.
1. Front Sway bar Holder
When you install the sway bar holder on the bulkheads, I recommend you to shave the fitted groove a little bit for better sway bar fit especially for larger size such as 1.2mm and 1.3mm. Please see a picture attached. Without doing this, it might be too tight for those sway bars.
2. Recommendation of 46mm drive shafts
The kit comes with black composit diff outdrives. We will also have aluminum diff outdrives but with using those composit diff outdrives, you will be able to use the 46mm drive shafts in the rear as well. 46mm drive shafts don't fit with the option aluminum outdrives as they require to use with the plastic pin blades. Those composit outdrives are very strong and durable enough to use in modified racing. And the main benefit is that we can use 46mm drive shafts in the rear.
Hi-LowBlow is offline   Reply With Quote
Old 07-27-2010, 04:05 PM   #348
Korey Harbke's Avatar
Man... I was hoping Hiro woul dbe using a samurai sword to cut that...
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-27-2010, 04:09 PM   #349
KDR
Thanks for the building tip Hiro-San. Nice photo also.
-Steve
Steve B.
HB Team Driver*Sweep Racing Tires*Speed Passion Team Driver
hotbodiesonline.com
KDR is offline   Reply With Quote
Old 07-27-2010, 04:10 PM   #350
KDR
Duh...... it's a 1/10 scale sword.
Steve B.
hotbodiesonline.com
Old 07-27-2010, 04:16 PM   #351
If you don't want messing up the sway bar holder, you can also add a 0.5mm shim (each side) in between the bulkheads and sway bar holder to get more clearance.
Old 07-27-2010, 04:18 PM   #352
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Which one???
Korey
Which shirt should i get?
Thanks in advance.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-27-2010, 04:33 PM   #353
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Both! Get both shirts...
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 07-27-2010, 10:00 PM   #354
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Hebiki View Post
Korey
Thanks in advance.
The one on the right is my pick....LOL
STLNLST is offline   Reply With Quote
Old 07-27-2010, 11:55 PM   #355
ekim628's Avatar
Nice tips Hiro, im so glad you are looking out for us. These small tips will help make building a lot easier. Now i just need a TCX to try this on hahaha!!!!
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 07-28-2010, 12:33 AM   #356
Thraex's Avatar
Can you tell why you would want to use the 46mm drive shafts in the rear?
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 07-28-2010, 03:25 AM   #357
AGNO's Avatar
Originally Posted by RC MARKET View Post
this week arrive around $4xx
Upcoming sales forecast?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-28-2010, 08:28 AM   #358
From the testing result, they make totally different feeling of driving characteristic as they have different plunge point in the outdrives.
It should feel like more consistent feeling just like using the longer camber links. I personally think they provide some more forgiveness on the car too. I recommend you to try those your self and pick the best one for the situation.
Also, i personally think the composit diff outdrives work better on carpet than the aluminum one. Feels like more consistent traction with them.
Hope it helps a bit.
Thanks,
Old 07-28-2010, 08:44 AM   #359
locked's Avatar
Some guys like a long shaft in the rear.
Not that there's anything wrong with that.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 07-28-2010, 09:55 AM   #360
g26er is offline   Reply With Quote
