Old 09-02-2011, 08:26 AM   #3541
transplantlife's Avatar
Trader Rating: 43 (98%+)
Originally Posted by k_bojar View Post
any one have any info about the new(?) TCX parts RIDE is coming out with?? these are the parts Hara posted on facebook??
like when they'll be available?
got a link?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-02-2011, 10:17 AM   #3542
Korey Harbke's Avatar
Originally Posted by chris1160 View Post
Hi guys,
any tips for getting some steering in high speed sections;
in my opinion it must be an issue of weigth balance between front and rear, but without the needed result...
@ korey:
what happend, when i shorten or lenght the shocks (e.g. from 65 to 63,5mm)?!
thanks in advance.
chris
In my experience, the shorter shocks make that end of the car a little more planted and stable. Usually i notice it most upon entry into the corner and in the middle of the corner. Longer will feel more "floaty" and can be an advantage in higher grip conditions just to free the car up a little bit. You can also try a shorter front and a longer rear if you want a little more rotation in the middle of the corner too!!!
Hope that helps some.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-02-2011, 01:34 PM   #3543
frk
frk's Avatar
Default Question for all my teachers!
Hi guys
how to prepare the new tires (just unpacked) before a race on carpet?
Simply degreased and cleaned, or need to use rough paper or something else to prepare them?
Thanks so much
frk is offline   Reply With Quote
Old 09-02-2011, 02:29 PM   #3544
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by frk View Post
Hi guys
Thanks so much
http://nexusracing.net/newsdesk_info...3e39a861112865
Don't forget a couple min of sauce is better than none.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 09-02-2011, 04:36 PM   #3545
Originally Posted by rx7ttlm View Post
Well I should get my TCX later today after class. By tomorrow night it will likely be a TCX /417. If all goes well I have a 417 ver II diff on the way by noon today and in my hands tomorrow. Also what I am guessing are the correct parts to convert the drivetrain using Cyclone TC belts. Hopefully I will have a diff that doesn't leak and is concentric
How did your ver II tamiya diff work out with the tcx??
Old 09-02-2011, 08:43 PM   #3546
louielou's Avatar
Trader Rating: 16 (100%+)
Default servo saver
Originally Posted by transplantlife View Post
How did you ver II tamiya diff work out with the tcx??
can anyone tell me what is a good servo horn to use for a savox servo.
thanks
Luis
Luis
[email protected]
Ebay account LOU840
louielou is offline   Reply With Quote
Old 09-03-2011, 01:06 AM   #3547
AGNO's Avatar
It should work .... but the differential Tamiya uses pulleys 37, then you should replace the front pulley of the spool, use the belts of the TC and replace rear axle shafts with Tamiya ... I prefer to use R-Spec .
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 09-03-2011, 01:12 AM   #3548
AGNO's Avatar
thanks
Luis
The Savox is compatible with Futaba (I use both), so you can use any servo horn, I use Tamiya with 3Racing aluminum horn.
Old 09-03-2011, 01:13 AM   #3549
rx7ttlm's Avatar
worked ok, I am having a bushing machined so I can make more that are true. But the tam diff is 10x better than the spec r I had. Only problem is all the parts to switch. But worth it if you modify the hb spool, the spec r diff I got was extra crappy with nothing right on it so if your going to go there just shoot me the spool and I can make the mods if your not inclined to do it. For the front belt I ended up using a second tensioner on the chassis plate out of spare parts. Tam diff is MUCH smoother than spec r, 1500 in tam diff feels like ~1000 in spec r. Word has it that there is quite a bit of variation however. Pm Korey for the whole explanation lol.
Hope this helps
Old 09-03-2011, 03:10 AM   #3550
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ditto - I have both the shorter and taller 3Racing arms and perfer the shorter one (I think it's 13mm vs 18mm tall)
but this setup works great!! it's the Tamiya heavy duty set, they make it in black and white
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-03-2011, 03:12 AM   #3551
k_bojar's Avatar
got a link?
not off hand - not sure if it's linkable to someone with Facebook
if you got an account, just search for Hara and ask to make him a friend, it's in his galleries
or when l get home from vacation, I can post it then
Old 09-03-2011, 12:47 PM   #3552
Hope this helps
Thank's for the reply!
Old 09-03-2011, 02:56 PM   #3553
spring71's Avatar
Smile
New items for TCX are arrived from Spec-R.
Also, TCX gear diffs, Carbon Gear Set and upper deck ver 2 are back in stock.
www.tqrcracing.com
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 09-03-2011, 04:27 PM   #3554
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
Lou,
Buy the tamiya servo saver kit. I really liked it.
thanks
Luis
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 09-03-2011, 04:48 PM   #3555
to you guys running the exotek xx chassis how do you like it??
