Old 08-13-2011, 03:33 PM   #3406
AGNO's Avatar
Originally Posted by RC MARKET View Post
where to see this item ?
Here
http://www.rctech.net/forum/9373408-post3220.html
It was also seen on the official website HB/HPI Europe, along with other options, is now gone....
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-13-2011, 07:24 PM   #3407
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by cheehtae View Post
Thinking of getting aTCX, my question is are the c hubs, arms and knuckles still the weak point? Thanks in advance.
i think it depends...i'm still running the original (as in out of the box when i bought it), arms, c-hubs...but i did change my knuckles to aluminum ones..
I'm definitely not the cleanest driver and had my fair share of big crashes - and the cars been solid...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-13-2011, 07:25 PM   #3408
Trader Rating: 4 (83%+)
Default tcx
i am thinking of purchasing one of these...how do they compare to the tc6...the tc6 has alot of traction and that is what i want crazy traction....i will run it in blinky. i want it to be crazy hooked up..and i will run it on carpet...
obi wun is offline   Reply With Quote
Old 08-13-2011, 11:50 PM   #3409
Suspended
Trader Rating: 86 (100%+)
the kit chassis wont work for you. maybe an aftermarket one will.
the tc6 has alot of flex compare to tcx. but part support for tcx is pretty bad. you may have to wait for long time, i mean long time around 3-8 months for the upgrade parts
littlealex is offline   Reply With Quote
Old 08-14-2011, 04:09 AM   #3410
mac853's Avatar
Questions??
For Cyclone DCJ
& TA06 Gear Diff fit for TCX to use , but need change TAMIYA Drive shaft .
I saw the gasket and gears of Tamiya TA06 diff are so similar as that of Sakura, could they share the parts?
Best regards
mac853 is offline   Reply With Quote
Old 08-14-2011, 09:13 AM   #3411
RC MARKET's Avatar
Best regards
can't !
RC MARKET is offline   Reply With Quote
Old 08-14-2011, 10:11 AM   #3412
mac853's Avatar
Questions??
can't !
About the width, does it fit perfectly in the bulkhead, as what i saw, i guess it is a little bit shorter than the TCX ball diff, maybe must put little bit shim.
Best regards
Old 08-15-2011, 11:55 AM   #3413
gashuffer's Avatar
Trader Rating: 48 (100%+)
What's the diameter of the solid axle? I have some out drive cups that I want to use. I would rather just buy the axle than the whole spool set.
T-Sal
gashuffer is offline   Reply With Quote
Old 08-15-2011, 12:38 PM   #3414
Korey Harbke's Avatar
I wouldn't jump to the conclusion that the stock chassis is BAD. The stock chassis is actually very good, but it makes the overall setup of the car more critical. The Exotek chassis broadens that window for your setup, so it isn't perfect the car still works pretty good.
Both chassis sets have their place, and are both very good in their intended conditions.
Hope that helps some
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 08-15-2011, 01:58 PM   #3415
That's interesting to hear.
We have worked on the option chassis and spent so much time because it was
"really" hard to make it better than the original chassis. Yes, the kit chassis is that great from our testing.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 08-15-2011, 02:42 PM   #3416
redskin666's Avatar
Originally Posted by Mike Haynes View Post
I have been using the top ones, these are a must have
Hey Mike, do you know if the TOP axle covers are a direct fit on HB drive shafts?
redskin666 is offline   Reply With Quote
Old 08-15-2011, 02:54 PM   #3417
Suspended
Thanks,
i think, traction makes difference. do you drive on high traction asphalt?
Old 08-15-2011, 02:56 PM   #3418
RaceAce701's Avatar
Trader Rating: 83 (99%+)
yes they do
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-15-2011, 03:38 PM   #3419
We run on multiple different track conditions for testing. The kit stock chassis works really well on low bite of-course with the flex and also on the high bite as now we want almost the same amount (may be even more) of flex for the high bite condition. The chassis works really well on both conditions.
On the other hand, the new option narrower chassis (#68760) has a bit different flex characteristic. We found that the new chassis gives the car more aggressive drive feel compare to the stock one. You might feel kind of hard to drive but for some condition it works really well. I think it's nice to have both the stock one and the optional one as setup parts.
Thanks,
Old 08-15-2011, 04:20 PM   #3420
Mike Haynes's Avatar
I have found my tcx's to be very locked in cars, i really wish i could make them turn more for my tastes on pavement but they are competative for sure.
As an aside i am going to sell a few of them lol, coming up on carpet id like to put together a fresh kit. If anyone is interested please pm me.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
SEO by vBSEO 3.5.0
